Controlicz - Easy Domoticz to Alexa Integration Topic is solved
Madgeni
Re: Easy Domoticz to Alexa Integration
Thanks - could you give me a screengrab from Devices? So Setup>Devices? I need the type/subtype
sach
Hey Nick,
same issue here with this device: But strangely, this one is fine:
sgeaglef15
Hi, here u goMadgeni wrote: Wednesday 01 November 2017 14:26 Thanks - could you give me a screengrab from Devices? So Setup>Devices? I need the type/subtype
- 8EDDF6B9-7E6C-4493-BFA4-24D3D1D9B89D.jpeg (102.3 KiB) Viewed 5831 times
Madgeni
ok, so that's odd, it should be there. Can you PM your email address, and i'll see what's up
Madgeni
Thanks - can you PM me your email address?sach wrote: Wednesday 01 November 2017 15:25 Hey Nick,
Madgeni
Can you just double check that the device is in a Room Plan?sgeaglef15 wrote: Wednesday 01 November 2017 14:24 Hi Madgeni,
Here you go, please see attachment.
sach
Works now.
Thanks mate
Thanks mate
sgeaglef15
Hi Madgeni,Madgeni wrote: Wednesday 01 November 2017 17:18Can you just double check that the device is in a Room Plan?sgeaglef15 wrote: Wednesday 01 November 2017 14:24 Hi Madgeni,
Yes it in the living room room plan and as well as overall floor plan.
It is an active switch (I can actuate the switch from the floor plan, just Alexa cannot see it)
sgeaglef15
Hi Madgeni,
One thing I like to point out most of my switches (switch > Xiaomi Gateway > domoticz)
This tp link switch is slight different (switch > domoticz direct [as a virtual switch])
joshmosh
Good morning !
And now to a totally different topic
First of all: everything works pretty well, thank you. And yes, I have left a positive review for Controlicz
My question: I have a number of temperature sensors based on DHT22. They show temperature as well as humidity.
I can ask for the temperature of a sensor - > works well, but how do I ask for the humidity ? I have tried (I live in Germany)
"Feuchte", "Feuchtigkeit", "Luftfeuchte", "Luftfeuchtigkeit", but all without success. Is this a general problem or is it just
because that it does not work in German ?
Thanks a lot in advance
Josh
Josh
Madgeni
Hi @joshmosh -
i don't believe you can access Humidity at the moment - as soon as new functionality is available, i'll make sure it's in there.
@sgeaglef15 - can you PM your email address, and i'll take a look
fergalom
hey @Madgeni, seem to have an issue with controllicz/alexa picking up new/changed devices - specifically a thermostat and temperature.
They are both in a room plan etc.
EDIT: Nevermind, just figured it out, needed to add the new devices to my domoticz user that controllicz has access to. - doh!
sgeaglef15
Hi Madgeni, that was it!!! Need to add new devices to domotcz user.
Swifty
Thanks - I get that bit working ok, so I can create a group called 'bedroom', added all the bedroom devices, then tell alexa to turn the bedroom on/off.Madgeni wrote: Tuesday 31 October 2017 15:58 they seem to work fine from the app - added in a scene and a couple of switches to a group called 'Test' - then added one of my Echos, and could say 'Alexa Test on' and it turned everything in the group on
However, the Amazon blurb for the feature suggests you should be able to do things like 'alexa, turn on the light' - then because I've spoken to the echo in the 'bedroom' group, it will find the 'light' devices in that group and switch those on (as opposed to everything in the bedroom group'.
That doesn't seem to work though... so i've either misunderstood the Amazon description for groups, or it's just plain not working
Essentially, I'm trying to get a setup where alexa is aware of the rooms, and devices in each room, and also which room a given echo is in. So that more natural commands can be used.
Heres what I'm talking about; https://www.amazon.co.uk/gp/help/custom ... =201749250
sach
That feature does not work outside of the US just yet.Swifty wrote: Thursday 02 November 2017 14:27
farhanito
hi @madgeni,
what's proper device type/subtype for a door lock? it's a Yale ZigBee doorlock (as dummy switch)
this is the only thing that isn't working for me..
- Screenshot_2017-11-02-22-35-57-641_com.amazon.dee.app.png (53.88 KiB) Viewed 5697 times
- Screenshot_2017-11-02-22-34-54-670_com.amazon.dee.app.png (51.1 KiB) Viewed 5697 times
Swifty
Oh right - that's pretty lame.. I have a UK amazon account and the Alexa app even states "try saying: dim the lights on your living room echo, to only dim the living room"
Where have you seen its US only? - I'd like to check if there is an eta for UK support.
sach
Couple of UK Alexa groups on Facebook
Swifty
Ah OK, well thanks for the info.. Hopefully they will release for UK soon, as it will make things much slicker.
I don't really get why they do the whole feature release thing in US months before anywhere else..
