Using the RGB color picker
moroen
Post by moroen »
I'm struggling with the RGB color picker. Creating the device is easy enough, using Type=241, SubType=1 and Switchtype=7, but the values returned in onCommand makes no sense to me. When just dumping out the values to the log I get:
2017-10-29 23:23:57.344  (IKEA) RGB - Command: Set Color Level: 214 Hue: -1
2017-10-29 23:23:57.450  (IKEA) RGB - Command: Set Brightness Level: 62 Hue: -1
I might be missing something obvious, the information returned looks like HSV-color, but as Hue always is -1 one vital component is missing?
Any help or pointers would be greatly appreciated!
Regards,
M
Dnpwwo
Re: Using the RGB color picker
Post by Dnpwwo »
@moroen,
I can't speak for how the colour picker works but from a Python Framework perspective I believe I just past the supplied values straight through to the plugin. You may well be the first to use it though so no guarantees! :shock:
miroslavpetrov
Post by miroslavpetrov »
@moreon
I am also looking for a solution to use the color picker in a lua or python script. However, from what I've read in the forum so far, it is impossible due to limitations in Domoticz.
Automation Hardware:
Domoticz on Raspberry Pi 3 with HomeBridge.
Zigbee2MQTT + Xiaomi sensors
Fibaro HomeCenter 2 + Fibaro Dimmer2 & Double Switch2 + Aeon Multisensor 6 + Remotec ZXT-120
Eastron SDM230
elgringo
Domoticz version: Left
Post by elgringo »
I was wondering if you got the RGB colorpicker to work with a python plugin.
poudenes
Domoticz version: 3.8993
Post by poudenes »
miroslavpetrov wrote: Tuesday 31 October 2017 11:15 @moreon
I use dzVents and this command:
domoticz.devices(livingroom).setRGB(255, 255, 255) to set a color to a bulb
