triggerInfo.trigger unavailable?
emme
Domoticz version: latest
Post by emme »
Ciao,
on beta 8648 I'm having some issue using the triggerInfo table:
here is the code:
	on = { devices = { 'v*CTRL', 'TCM_vBagnetto' } },
	execute = function(dz, devVol, trgInfo)
	    local dbg = dz.LOG_FORCE
	    for k, v in pairs(trgInfo) do
	        dz.log('VOLUMIO: '..k..', '..v..' '..trgInfo.trigger, dz.LOG_FORCE)
and got this as a result:
2017-10-27 09:07:58.049 Error: dzVents: Error: ...ticz/scripts/dzVents/generated_scripts/dzVolumioCTRL.lua:7: attempt to concatenate field 'trigger' (a nil value)
...why trigger is no longer available?
"We always done this way"
Doler
Re: triggerInfo.trigger unavailable?
Post by Doler »
Just my guess: trigger holds information on timer events and since your example triggers only on devices it will return nil.
Mark
Mark: Domoticz latest Beta on Virtual machine (Proxmox) running Debian Trixie - Z-Stick 7 - RFXCom - P1 - SolarEdge - Dahua - Philips Hue - Docker - Zigbee2mqtt (latest, docker) via python plugin - Zwave-js-ui (latest, docker) - dzVents - Nodered
emme
Post by emme »
uuuh... :cry: :cry: :cry: :roll:
triggerInfo.trigger: which timer rule triggered the script in case the script was called due to a timer event
my fault!!! (I've red it more than one, but I would red what I wanted to read :(
...it would be nice to have the triger info extended to all rules...
dannybloe
Post by dannybloe »
That would be nice but that is very hard to do. At least that is what I remember ;-)
