Creating devices for included node Topic is solved
cincuranet
Post by cincuranet »
Hi, I included new node on my Aeotec Z-Stick using the button (not via Domoticz), because it was too far from it and I had to get physically closer. Now I see the node in the list in Hardware, but I don't have any new devices in Devices. Is there a way to create these? I can control the node from OZW Control Panel just fine. So I think I "just" need to somehow create these devices.
Skippiemanz
Domoticz version: 4.10233
Re: Creating devices for included node
Post by Skippiemanz »
cincuranet wrote:Hi, I included new node on my Aeotec Z-Stick using the button (not via Domoticz), because it was too far from it and I had to get physically closer. Now I see the node in the list in Hardware, but I don't have any new devices in Devices. Is there a way to create these? I can control the node from OZW Control Panel just fine. So I think I "just" need to somehow create these devices.
Try sending the heal command trough domoticz. Or wake up the device. The devices should appear in the Un used tab
cincuranet
The device is always on ("Z-Wave+ node Always On Slave"). I tried clicking on "Heal" button now. But even after few minutes not a single device appeared. :(
cincuranet
Just to be sure, I also restarted my Raspberry Pi and for a while I saw "Not all Nodes have been Queried yet, OpenZWave not fully initialized yet!". But no new devices after that.
cincuranet
Ahh, finally solved it. I enabled "Accept new Hardware Devices" and then rebooted my Raspberry Pi. New devices appeared then.
Not sure whether having "Accept new Hardware Devices" off makes a "security" (or any other) difference, but I keep it that way.
