dzvents Light timer example [Solved]
BakSeeDaa
I believe I have seen a dzvents Light timer script example somewhere but now I can't seem to find it.
Looking for a simple script to turn the light on in a room for a certain amount of time when the door gets opened. Except for the light device and the door switch, there is also a light switch involved. If the light is toggled on by the light switch, the light should not turn off automatically (or as an alternative, the lights should turn off after a much longer time).
Cheers!
EDIT: I made a script for this purpose. See my script in this post.
Cheers!
Last edited by BakSeeDaa on Friday 10 November 2017 13:15, edited 1 time in total.
- emme
- Domoticz version: latest
Re: dzvents Light timer example
..mmh.. so...
here a sum of the rules:
- door open ==> light on by timer
- light button press ==> light on NOT by timer
- other switch ==> light on NOT by timer
correct?
I think you can do it only if the 2 switches are not directly connected to the light
...by my understanding this can be sone in this way:
hope it will work with short corrections
MY intention is:
if door is open switch on for n secs...
if a key in pressed ON, do not consider anymore the timer and leave the light on
so, the light can be turned off ONLY by pressing one of the 2 switches
...for delaying the timer I had this idea: if one of the switches has been pressed I will delay the timer....
hope this would help... and work!!!!
correct?
on = { devices = {'doorSwitch', 'switchLight1', 'switchLight2', 'timerSwitch'},
data = { switchPressed = { initial = false} },
execute = function(dz, devName)
local lightTimer = 90 -- timer in secs
local longDelay = 90 -- much longer delay
local timerSwitch = dz.devices('timerSwitch')
local roomLight = dz.devices('roomLight')
if devName.name == 'doorSwitch' and devName.state == 'On' then
roomlight.switchOn().checkFirst()
timerswitch.switchOn().afterSec(lightTimer)
elseIf ((devName.name == 'switchLight1') or (devName.name == 'switchLight2')) and devName.state == 'On' then
dz.data.switchPressed = true
elseif devName.name == 'timerSwitch' and devName.state == 'On' then
if dz.data.switchPressed == true then --longer delay
timerSwitch.switchOff().silent()
timerSwitch.switchOn().afterSec(longDelay)
dz.data.switchPressed = false
elseif ((devName.name == 'switchLight1') or (devName.name == 'switchLight2')) and devName.state == 'Off' then
roomlight.switchOff().checkFirst()
if dz.data.switchPressed == true then dz.data.switchPressed = false end
MY intention is:
"We always done this way"
tlpeter
I use .switchOff().afterMin(5)
- emme
that command cannot be deleted... so.. if you press the switch (that means that you do not want to switchoff the light automatically anymore) the light will go off anyway
I strongly hope one day we would be able to interact much better with Domoticz scheduler...
tlpeter
Aaah, i did not read well enough i see.
BakSeeDaa
Thanks @emme for your script example.
Below is a script that I currently use. It keeps a table of the lights that you wish to control so it's easily to adopt to any number of lights, each with different values. Each light has a "Door Device", a door switch that typically turns the light on for a shorter period of time when the door gets opened. Each light also has a "Switch Device" which is a manual light switch that typically turns the light on for some longer time (or turns it off).
In my setup, I use a Fibaro Single Switch 2 (Z-wave). Then the name of the light is the same as the switch device as you can see below in the script.
The script is not supposed to work for every kind of setup. You can use it as an example, adopt it, change it and/or extend it and make it your own.
Prerequisites:
Table key .string. The Domoticz device name of the light device.
['enabled'] boolean. Whether this definition should be used or not.
['doorDevice'] string. The Domoticz device name of the lights door device as described above.
['switchDevice'] The Domoticz device name of the lights switch device as described above.
['minutesDoor'] = number. Number of minutes that the light shall be turned on after opening the door.
['minutesSwitch'] number. Number of minutes that the light shall be turned on after using the light switch manually.
Prerequisites:
- A Domoticz virtual text device always showing the ambient light level . The text must always be one of "Dark", "Bright" or "Shady". In the example below it's simply named "Ambient light level". My script doesn't take care of the logic behind this virtual text device. Note, it has nothing to do with the day state, e.g. if it's day or night.
- dzVents version 2.3.0 or higher.
- dzVents and Lua knowledge at least at an intermediate level. You need to understand what the script does, the code and how to debug it.
local lights = {
['Bathroom lights'] = {['enabled'] = true, ['doorDevice'] = 'Bathroom Door', ['switchDevice'] = 'Bathroom lights', ['minutesDoor'] = 4, ['minutesSwitch'] = 60},
['External lights'] = {['enabled'] = true, ['doorDevice'] = 'Entrance Door', ['switchDevice'] = 'External lights', ['minutesDoor'] = 3, ['minutesSwitch'] = 70},
local LIGHT_AMB_DEV = 'Ambient light level' -- Ambient light level virtual text device
local function getTriggerDevices()
local tDevs = {}
local tDevsIndexed = {}
for lightDev, lightData in pairs(lights) do
if lightData.enabled then
tDevs[lightDev] = 1
tDevs[lightData.doorDevice] = 1
tDevs[lightData.switchDevice] = 1
tDevs[LIGHT_AMB_DEV] = 1
for k, _v in pairs(tDevs) do table.insert(tDevsIndexed, k) end
return(tDevsIndexed)
local function getPData()
local pData = {}
pData[lightDev] = {history = true, maxItems = 1}
return(pData)
local triggerDevices = getTriggerDevices()
local pData = getPData()
active = true,
logging = {
level = domoticz.LOG_INFO, -- Select one of LOG_INFO, LOG_DEBUG, LOG_ERROR, LOG_FORCE to override system log level
marker = "lightTimer"
devices = triggerDevices,
timer = {'every minute'}
data = pData,
execute = function(domoticz, device, triggerInfo)
local LIGHT_LEVEL_TEXT_DARK = 'Dark'
local LIGHT_LEVEL_TEXT_BRIGHT = 'Bright'
local LIGHT_LEVEL_TEXT_SHADY = 'Shady'
for lightDevName, lightData in pairs(lights) do
local pData = domoticz.data[lightDevName]
if pData.size == 0 then pData.add('off') end -- Initialize data if necessary
local hValue = pData.getLatest() -- Get the value for the latest history item
-- Calculate the remaining time
local remainingMinutes = (hValue.data == 'door')
and (lightData.minutesDoor - hValue.time.minutesAgo)
or (hValue.data == 'switch' and (lightData.minutesSwitch - hValue.time.minutesAgo) or 0)
if remainingMinutes > 0 then domoticz.log(lightDevName..', '..hValue.data..': '..'remainingMinutes: '..remainingMinutes, domoticz.LOG_INFO) end
if triggerInfo.type == domoticz.EVENT_TYPE_DEVICE then
if device.name == lightData.doorDevice and device.active
and (domoticz.devices(LIGHT_AMB_DEV).text ~= LIGHT_LEVEL_TEXT_BRIGHT) then
if (remainingMinutes <= lightData.minutesDoor) then
pData.add('door')
-- Currently the checkFirst() option does not work combined with the .silent() option for all kind of devices
if not domoticz.devices(lightDevName).active then
domoticz.devices(lightDevName).switchOn().silent()
domoticz.log(device.name .. ' opened. Switching on: '..lightDevName, domoticz.LOG_INFO)
elseif device.name == lightData.switchDevice and device.active --then
and domoticz.devices(lightData.doorDevice).lastUpdate.secondsAgo > 2 then
pData.add('switch')
if domoticz.devices(lightDevName).active then
domoticz.log(device.name .. ' switched. Switching on: '..domoticz.devices(lightDevName).name, domoticz.LOG_INFO)
elseif (device.name == lightData.switchDevice and not device.active)
or (device.name == LIGHT_AMB_DEV and device.text == LIGHT_LEVEL_TEXT_BRIGHT and hValue.data == 'door') then
pData.add('off')
elseif triggerInfo.type == domoticz.EVENT_TYPE_TIMER then
if remainingMinutes <= 0 then
domoticz.devices(lightDevName).switchOff().silent()
domoticz.log(lightDevName .. ', time came to an end. Turning off '..domoticz.devices(lightDevName).name, domoticz.LOG_INFO)
Last edited by dannybloe on Wednesday 01 November 2017 14:16, edited 1 time in total.
Reason: Fixed dzVents version typo
stephanvdplas
- Domoticz version: 2023.1
Since 2.4.0: cancelQueuedCommands(): Cancels queued commands. E.g. you switch on a device after 10 minutes: myDevice.switchOn().afterMin(10). Within those 10 minutes you can cancel that command by calling: myDevice.cancelQueuedCommands().emme wrote: Thursday 26 October 2017 17:20that command cannot be deleted... so.. if you press the switch (that means that you do not want to switchoff the light automatically anymore) the light will go off anyway
I strongly hope one day we would be able to interact much better with Domoticz scheduler...![]()
- Running LMS, Domoticz and Dashticz on a windows 11 laptop.
- LMS (11 players) / Hue (26 lights, 2 switches) / Z-wave (14 devices) / Toon (unrooted) / Chromecast
- emme
Re: dzvents Light timer example [Solved]
I know, my post is dated 2017 while .cancelqueuedcommands is 2018
