I need to create a function that reads everytime a serial port to get a device notification, then I can trigger the plugin's onHeartbeat() function. For some reason the notification on serial port doesn't wait on buffer for more than a half of a second. In order to accomplish that I tried to apply a Thread(target=self.serialReader) method, and it works nicely when I isolate the script. But when I use it with Domoticz, it freezes on exit, even when I put the self.serial_task.join() on onStop or on a onDisconnect trigger.
I'd like to know how to proper use multitasking on a Domoticz python plugin.
Thanks in advance.
Threading conflict on Python Topic is solved
- Dnpwwo
Re: Threading conflict on Python
@brunonar,
You haven't posted your code so I can't give specifics but general feedback is: the framework does not support multi-threading operations as stated in the wiki page (http://www.domoticz.com/wiki/Developing_a_Python_plugin):
To allow the usage pattern that you are describing the framework offers asynchronous objects to handle connectivity to external devices. Have a look at this example to see how to receive async messages on a serial port:https://github.com/domoticz/domoticz/bl ... s/RAVEn.py
also the callbacks are normally called by Domoticz rather than the Python itself.The following things should not be attempted using the Python Framework:
- Use of asynchronous code or libraries. This will not work the way you expect.
- Use of call back functions. This will not work the way you expect.
- Waiting or sleeping. Plugins are single threaded so the whole plugin system will wait.
brunonar
Thank you very much. I'll try the example you provided, but I took a quick look at it and that seems to be what I needed.
