See viewtopic.php?f=67&t=17242&start=200#p151132woody4165 wrote: Saturday 21 October 2017 11:04 Hi Ingmar
How did you reduce the height of that block?
Can you show settings for the icon and blocks in css file?
Dashticz - Show your dashboard and how-to's!
Ingmar
Re: A little help to make my dashboard awesome
Synology NAS with stable release, AEON Z-wave, RFXCOM, Toon, Echo Dot, HAbridge, HarmonyHUB, Dashticz.
woody4165
Thanks Ingmar!
woody4165
Finally my tablet is on the wall. Fixed with two side supports printed with a 3d printer.
Since in that part of wall there is an interspace, I have inserted a 433Mhz relay connected with Domoticz/RFLink and created on the tablet with Macrodroid app two macros, one when the charging reaches 80% and one when it drops to 20% and send HTTP/GET action to domoticz to activate the charger, depending on it to have the tablet not charging every time.
The dashboard is very similar to the Ingmar one (thanks Ingmar for inspiration).
Some "bugs" that I noticed are the fact that when there is a block like xxx_1, the [switch] fuction does not work, either if I define the block with xxx_1 or xxx.
I don't see anymore the icons for sunrise/sunset, but just time for both.
Any advise on these two issues?
yfands
- Domoticz version: latest B
Hai woody4165,
yep only in "else if".. A white or black screen is mostly a typo (syntax error) look for missing } ] or ;
but Ierlandfan said it already, there a some strange things going on with the beta versions latests and previous.
Ierlandfan
Yep, I am on latest beta which magically started to work (sort of) no menu and I lost switches and a few other things . I din't do anything. Just left my the page alone for 24 hours or so. Probably caching issue, Eventhough I ctrl-F5 and F5 éd. Anyway, just wait for another version.
MikeF
- Domoticz version: V2022.2
Here's my attempt:
CONFIG.js:
I don't seem to be able to switch title and date on multi-value devices
- I've tried:
and
Also, if anyone has a transparent Raspberry Pi image I'd be grateful!
CONFIG.js:
- Spoiler: show
- Spoiler: show
- I've tried:
blocks[211] = {}
blocks[211]['switch'] = true;Code: Select all
blocks['211_1'] = {}
blocks['211_1']['switch'] = true;
blocks['211_2'] = {}
blocks['211_2']['switch'] = true;
blocks['211_3'] = {}
blocks['211_3']['switch'] = true;- EdwinK
- Domoticz version: BETA
Must be a big screen
MikeF
Nah - iMac 21.5-inch. Browser (Firefox) occupying about 2/3rds width...
- htilburgs
Hardware:
yfands
Still having issues with the lastest Beta Latest commit f4d1f5a 4 days ago (21/10/2017) regarding Temp & Humidiy sensors.
see http://www.domoticz.com/forum/viewtopic ... 00#p154374 (bug report) and
http://www.domoticz.com/forum/viewtopic ... 00#p154381 (bug report)
is this just me or ?
One issue solved
blocks[xxx]['show_lastupdate'] = false; //if you want to show the last update specific for this block
if you use:
blocks[xxx]['hide_lastupdate'] = false/true; this works..
I studied the latest Master version and I can't debug where the image I want it to display is being processed, In my opinion it isn't.
So I cut and pasted and coded some in the main,js with following results:
"Zwembad" is a Temp sensor only and processed accordingly, the other sensors are Temp/Hygro sensors with:
My own image.
Temp & Humidy in one (1) block.
Status of battery in text in % and icon. (icon will flash if < 20%)
and last seen will turn red if (in my case) there is no value received within 15 minutes.
Unfortunately The impact on main.js is to extensive to share, but maybe an inspiration for team Rob.
I thought a LCD theme was nice..
One issue solved
if you use:
My own image.
MikeF
@htilburgs Thanks!
woody4165
Really nice @yfands, more than nice.
This is what's missing for temp/hum sensors and you added also the battery status. Really fantastic!
If I can help anyone in testing or (small) coding, let me know.
- EdwinK
Again, really nice @yfands. Hope this too will one day be in Dashticz.
landi
My Dashticz panel on old iPad:
Actual HW setup:
- Logitech squeezebox
- Netatmo weather station
- Denon AVR
- Broadlink RM2 Pro (for sending RF and IR codes)
- LightwaveRF switches
- RFXCOM 433 (controlling RF and lightwave)
- USB Zwave controller
- Danfoss radiator valves (Z-wave)
- INODE (inode.pl) electricity meter + inode LAN
custom.css:
Actual HW setup:
- Denon AVR
custom.css:
- Spoiler: show
- Spoiler: show
- Spoiler: show
- ipad1s.jpg (131.44 KiB) Viewed 7036 times
- ipad2s.jpg (213.35 KiB) Viewed 7036 times
- ipad3s.jpg (141.39 KiB) Viewed 7036 times
- EdwinK
yfands wrote: Friday 13 October 2017 10:34 Hai Rob,
Nice work, I like Dashticz very much.
But I have way to many 'items' for 1 dashboard, so by creating more dashboards (screens) I'll keep swiping, so In my opinion there was only one thing missing, a mainmenu, I can now jump to the desired screen by a click/touch.
So with a little change in main.js I was able to create a menu with buttons, once clicked/touched will slide to the desired screen.
Maybe another option for Dashticz, but I like to see it in an ordered fashion, something in Config.js saying var Menu{} etc..
Or maybe keep the dashboard 'look', and create a mainmenu in the topbar.
Frank
I've been playing with this, and although it looks great, I rather go back to the original Dashticz for now. Do I need to change stuff in main.js again?
- EdwinK
MikeF wrote: Wednesday 25 October 2017 16:27 Nah - iMac 21.5-inch. Browser (Firefox) occupying about 2/3rds width...
Much bigger then my 7inch Nexus7 tablet
- htilburgs
I like a as simple as possible dashboard. I have tried several setups, but wasn't sattisfied.
After I choose for a Microsoft Surface RT tablet to use as the dashboard, I've started all over to fit the important buttons on the screen.
I came to the conclusion that buttons have to be simple and kids (wife) proof. This is my new simplified dashboard.
config.JS
config.JS
- Spoiler: show
- Spoiler: show
Hardware:
yfands
EdwinK wrote: Saturday 04 November 2017 23:13yfands wrote: Friday 13 October 2017 10:34 Hai Rob,
Frank
@Edwin,
Just download the latest master or beta and install, the menu should be gone.
Rgds
Frank
robgeerts
- Domoticz version: 3.7067
Great dashboards!!
dagger38
- Domoticz version: 3.8153
Trouble setting up camera Velleman :
I own a velleman CAMIP5N1 ip cam.
In the setup i can give in all the variables , ecxept the url for the image?
If i put snapshot.jpg , no image is generated?
Anyone know the correct setup for this camera?
My system:
1 Raspberry Pi 3
1 Rfx-Trx 433 module
1 Milight module
1 aeotec Zwave stick
1 Philips Home Bridge
3 Qubino ZMNHBDx Flush 2 Relays
2 FIBARO System FGS223 Double Relay
1 Niko home system
1 Raspberry Pi 3
1 Milight module
1 Niko home system
