Replace ZWave Fibaro Relay Switch with a RFLink solution
433Mhz opensource Receiver & Transmitter.
jin
Post by jin »
I'm trying to replace expensive ZWave FGS-211 Fibaro modules with the corresponding cheap RFLink versions.
From my knowledge, exist two RFLink compatible types:
1) 1CH AC220V 433MHz
2) 1Key 433MHZ
searching into various online shops (Ebay, Aliexpress, etc...) I found these relays at very affordable price...
But I have only a doubt:
They doesn't support external push button like the Fibaro FGS-211
Because exist many 1CH variants, someone have already experience with these relays used for in-wall light switch?
Can paste some url where can be purchased these RFlink modules?
Any help is appreciated.
With kind regards
Westcott
Re: Replace ZWave Fibaro Relay Switch with a RFLink solution
Post by Westcott »
You can get Wifi switches such as Sonoff which have pushbuttons, and 2-way communications.
jin
Post by jin »
Hi Westcott,
thank you very much for the answer.. Sonoff is really appealing and it's really cheap, but, if I understand well, it can't be connected to the existing in-wall push button like the Fibaro Relay Switch?
Sonoff doesn't have the S1 input configurable as monostable or bistable... I'm right?
mattia81
Post by mattia81 »
Hi! Have you found a solution? ;)
jin
Post by jin »
I'm sorry, no solution right now, I still must use the expensive zwave devices
