Salus Ti500 Thermostat
DomoticJack
Post by DomoticJack »
I would like to integrate the Salus Ti500 thermostat in Domoticz.
The unit is communicating through Z-wave from boiler unit to control unit and also has an App for remote control through the LAN-gateway.
Has anybody already managed to integrate it in Domoticz?
haihh
Re: Salus Ti500 Thermostat
Post by haihh »
Have you managed to find a solution?
I have the same thermostat. It is a cool device which works nicely at 868 MHz. It would be an even cooler device if it was implemented in Domoticz. My guess is that it won't work with OpenZwave (but I am no expert). Maybe it is possible to capture some commands which are send from the smartphone app. By resending them you could switch on/off the thermostat with a dummy switch.
Thanks and regards,
Huub
DomoticJack
Hello Huub,
No results yet.
I got also no support from Salus who are saying that they don't plan any domotic integration in the future.
You can switch your salus switchbox on/off through an external switch but you don't have control over the temperature.
It should be an easy to integrate device because you have full app control over a cloud server but i'm didn't find a way on how to do and don't get any support from experienced users also.
Br.
Jack
numanx
Domoticz version: 3.8153
Post by numanx »
I want to integrate Domoticz with Salus IT500 so far I've found only a script that works with Amazon Alexa, can anyone help me with making it work in LUA script?
Link: https://github.com/azw409/alexa-salus-i ... r/index.js
