changing colors on a zipato rgbw bulb in LUA
JuanUil
Domoticz version: 4.11083
Post by JuanUil »
Hi there,
I want to use the zipato rgbw bulb as a burglar prevention.
when i put it behind the television and randomly change the colors it looks like some is at home.
Anybody any idea how to do this in LUA?
Thanx in advance
Jan
JuanUil
Re: changing colors on a zipato rgbw bulb in LUA
Post by JuanUil »
Anyone any idea please?
JuanUil
Post by JuanUil »
Realy nobody can help me with this?
mbtr
Domoticz version: 2.3817
Post by mbtr »
Hi there,
I'm not sure about the zipato bulb, but the Fibaro RGBW-controller (often used for LED-strips) can be set by one of the following. I bet one of these could help you as well.
- A scene (commandArray['Scene:MyScene'] in LUA, where the scene is defined using the RGBW-device*
- Individual Set Levels for R, G, B, W (commandArray['device_R'] = 'Set Level 20'), if those devices are available for your bulb
- Calling the Domoticz API from LUA, see this post (I haven't tested thisone)
* Something to remember: You can't detect which scene is activated, so you may want to use User Variables for the purpose of changing scenes.
As far as I'm aware, we don't have a "Set RGBW" operation in LUA at the moment, although I'd love to have it.
Controllers: Raspberry Pi 2B - RFXTrx433E - Aeon ZStick Gen5
Target devices: Fibaro RGBW - Philips Hue - Logitech Harmony - Google Nest
Triggers: Fibaro Motion Sensors - Fibaro Wall Plugs - KaKu Motion Sensors - KaKu Switches - Byron doorbell
JuanUil
Post by JuanUil »
Thanks, I will try this!
verdeel
Post by verdeel »
Hi JuanUil,
Did you get this working in LUA?
verdeel
Post by verdeel »
I've managed to change the color of the bulb using the following command:
commandArray['OpenURL']='http://ip:port/json.htm?type=command&param=setcolbrightnessvalue&idx=IDX&hex=0000FF' --blue
use your own ip:port and device idx
But I'm confused on the correct way to determine hex values for the different colors. When trying the command in a browser The returned status is ok with any hex value, and seems to change between 00000000 and FFFFFFFF. But cannot find any real logic in why a value results in a color. Some regions of the hex value appear to switch the bulb off or to a normal bulb color.
the following were determined using the domoticz color picker
--7fb9ff --lightblue
--ff7f7f --lightred
--824141 --darkred
--ffee00 --darkyellow
--fff99e --lightish yellow
--9effa3 --lightish green
--19ff25 --darker green
--ff19e8 --darker purple
--db34ca --lighter purple
--000000 --off
--ffffff --on (normal light)
