CaesarPL
If I'm right, then you can NOT use in the same time auto-positioning and separately designed blocks.
Either
config['auto_positioning'] = 0;
config['use_favorites'] = 0;
or stick to your Favorites
Either
hdpop38
Thanks a lot for your help, now it's work fine.
next step to custom my dashboard
yfands
- Domoticz version: latest B
I started using Dashticz and like it very much but a question: Domoticz combines for instance the temp/humidity sensor into one 'block'. Dashticz on th e other hand splits the values into 2 'blocks'. I like the option but find it easier to see if both the values are in 1 block and it saves space. Can I suggest to make it optional? Both values can be adjacent or right adjusted in a column, in the case of temp/humidity/baro there are even 3 values.
Frank
Frank
levynger
hi, anyone knows how to modify the color in custom.css for loaded local images (fan.png) for instance?
the .fa.fa-xxxxx seems to only affect downloaded images..
blocks[1]['image'] = 'bulb_off.png';-
Stephan83
I'm quite new to Domoticz and to dashticz. At this moment I am creating a dashticz dashboard and I run into an issue when I try to switch a scene (Alles uit).
The button does not appear in the screen, while other blocks (lamps and a power meter) do work.
I tried all of the following settings:
None of the tried options is working. I also read that
If I look into domoticz the IDX of my scene is 5. If I just use the the url
What am I doing wrong?
var blocks = {}
blocks['s5'] = {} //Alles uit
blocks['s5']['width'] = 6;
blocks['5'] = {} //Alles uit
blocks['5']['width'] = 6;
blocks[5] = {} //Alles uit
blocks[5]['width'] = 6;
var columns = {}
columns[4] = {}
columns[4]['blocks'] = ['s5',5,s5]
columns[4]['width'] =4;
var screens = {}
screens[1] = {}
screens[1]['background'] = 'bg2.jpg';
screens[1]['columns'] = [4]
should be the right one.blocks['s5'] = {} //Alles uit
all my lights do go off as expected.http://x.x.x.x:x/json.htm?type=command¶m=switchscene&idx=5&switchcmd=On
HW:Raspberry Pi 3 B, Pi B,Nano w, Aeon Labs Aeotec Gen 5 Z-Wave USB,P1,RFLink,Fibaro dimmers,Fibaro RGBW, Fibaro wallplug,Harmony Companion,GPIO switches, EUROtronic Spirit
SF:Raspbian Stretch,Domoticz 4.97,HaBridge 5.2.1,Dashticz V2.0
- EdwinK
- Domoticz version: BETA
Can confirm this happening.
*and now I unconfirm it, because it was fixed by making sure that the column was actually added to a screen. Like this
In my case it was about column 5, that was omitted in the screens settings.
columns[5] = {};
columns[5]['blocks'] = ['s2'];
columns[5]['width'] = 2;
screens[2] = {}
screens[2]['background'] = 'background.jpg';
screens[2]['columns'] = [4,5,6]
CaesarPL
In my case this one works fine
Are you sure that you have switched auto positioning to Off?
var blocks = {}
blocks['s1'] = {}
blocks['s1']['width'] = 4
columns[1] = {}
columns[1]['blocks'] = ['blocktitle_1',24,100,103,21,22,166,'s1'];
columns[1]['width'] = 6;
screens[2] = {}
screens[2]['columns'] = [1,7,9];
Stephan83
That was indeed the trick! Auto positioning was turned on
Thanks for the verry quick response!
Ingmar
The easiest thing in my opinion is to open the .png file and change the color in photoshop for example. Otherwise you would have to try a color overlay, maybe this helps https://stackoverflow.com/questions/177 ... ansparencylevynger wrote: Tuesday 26 September 2017 22:02 hi, anyone knows how to modify the color in custom.css for loaded local images (fan.png) for instance?the .fa.fa-xxxxx seems to only affect downloaded images..Code: Select all
Synology NAS with stable release, AEON Z-wave, RFXCOM, Toon, Echo Dot, HAbridge, HarmonyHUB, Dashticz.
gwaelod
Re: Weather radar for UK locations
Did you get anywhere with this..garethhowell wrote: Friday 30 June 2017 11:59 Has anybody on here found the right strings for buienradar to show weather in the UK?
I can find the URL for Cambridge, but I can't find a suitable image.
There is a UK Met Office datapoint for weather radar at https://www.metoffice.gov.uk/datapoint/ ... -map-layer but its well beyond my skills to do anything with it.
Derik
mmm Dear all
Wich API do i need?;
https://developers.google.com/maps/get- ... authuser=2
I used mutiple...
Only i see no gm in my srceen, and i use:
And this settings [ changed something ]
I used a api, months before that was working fine.
After install the latest beta, no maps to see in my dash
I used mutiple...
columns[4] = {}
columns[4]['blocks'] = ['trafficmap','traffic','train'];
columns[4]['width'] = 12;
config['gm_api'] = 'AIzaSyDP2b06TEalfbyswwPUw0Ci1RGfuE69c';
config['gm_zoomlevel'] = 4;
config['gm_latitude'] = 52.8745659;
config['gm_longitude'] = 3.1139102;
"last update'still visible
I use block below, but "last updated"is still visible
Do I have to set something else too ?
blocks[8]= {}
blocks[8]['title'] ='slaapk schemerlamp';
blocks[8]['show_lastupdate'] = false;
blocks[8]['width'] = 4;-
garethhowell
- Domoticz version: 3.9317
Sadly, not. I parked it for now as I am still trying to work out why Google Maps won't display on my V2 dashboard when it worked perfectly on V1.gwaelod wrote: Saturday 30 September 2017 13:30Did you get anywhere with this..garethhowell wrote: Friday 30 June 2017 11:59 Has anybody on here found the right strings for buienradar to show weather in the UK?
Gareth
garethhowell
Could it be because the zoom, lat and long values are not quoted (i.e. '52.8745659';)Derik wrote: Thursday 05 October 2017 19:50 mmm Dear all
I used mutiple...
Only i see no gm in my srceen, and i use:And this settings [ changed something ]Code: Select all
columns[4] = {} columns[4]['blocks'] = ['trafficmap','traffic','train']; columns[4]['width'] = 12;I used a api, months before that was working fine.Code: Select all
config['gm_api'] = 'AIzaSyDP2b06TEalfbyswwPUw0Ci1RGfuE69c'; config['gm_zoomlevel'] = 4; config['gm_latitude'] = 52.8745659; config['gm_longitude'] = 3.1139102;
Ingmar
Re: "last update'still visible
Try
blocks[8]['hide_lastupdate'] = true;Synology NAS with stable release, AEON Z-wave, RFXCOM, Toon, Echo Dot, HAbridge, HarmonyHUB, Dashticz.
Im having the same issue with traffic map from google maps, have been reading on the forum for solutions but none has worked.
Latest stable version of dashticz, correct API, no ' ' on lang, long and zoomlevel.
- EdwinK
I believe you need them in the ' ' things.
Can't check, I don't use maps on my dashboard.
Thanks, that helped.
Little strange ? Two parameters for one toggle ?
No newsfeeds anymore
I used the lines of code as shown in the first two blocks of code in my config.js . Which ran perfectly.
After the last update I had to add the code in the third block.
Now I don't get any newsfeed anymore. Anyone knows what is wrong ?
Without the crossorigin part, same result.
blocks['news_1'] = {}
blocks['news_1']['width'] = 6;
blocks['news_1']['feed'] = 'https://crossorigin.me/http://www.nu.nl/rss/algemeen';
blocks['news_2'] = {}
blocks['news_2']['width'] = 6;
blocks['news_2']['feed'] = 'https://crossorigin.me/http://feeds.feedburner.com/tweakers/nieuws';
blocks['news_2']['image'] = 'tweakers.png';Code: Select all
columns[4] = {}
columns[4]['width'] = 5;
columns[4]['blocks']=['default_news_url','news_1','news_2'];
config['default_news_url'] = 'http://www.nu.nl/rss/algemeen';
aschaake
- Domoticz version: 4.10427
Ik krijg die variabelen ook niet aan de gang... (couldn't get it working with the variables too)
Ik vond ergens in dit draadje een oplossing die er omheen werkt: (found this in this thread:)
var maps = {}
maps.plaatsnaam = { height: 450, width:12, latitude: 52.151828, longitude: 5.418363, zoom:13 }
en dan maps.plaatsnaam opnemen in een column om te tonen (then add maps.plaatsnaam in your column part)
Voorbeeld: (example:)
columns[3] = {}
columns[3]['blocks'] = ['clock',maps.plaatsnaam]
columns[3]['width'] = 4;
Ik snap er helemaal niks van waarom het met de variabelen niet werkt. Maar dit is even mijn work around.
var maps = {}
columns[3] = {}
