Hi All,
Can someone tell me when you what use:
timer = {'at nighttime'}
timer = {'at daytime'}
and
domoticz.time.isNightTime
domoticz.time.isDayTime
Timer will always trigger every minute when its nighttime or daytime.
isNightTime and isDayTime you can use for specific devices to let them do something on day or night?
If im wrong tell me... im struggling with those to haha
nighttime / daytime
poudenes
- Domoticz version: 3.8993
nighttime / daytime
dannybloe
Re: nighttime / daytime
The timer = {'at nighttime'} trigger indeed triggers your execute function every minute between sunset and sunrise. domoticz.time.isNightTime returns true if the current time is between sunset and sunrise. So you you can use that if you need to check that in your script (e.g. when a switch is pressed and you want to do something different when it is at night).
