best thermostat for domoticz
italoc
Post by italoc »
i need to buy a smart thermostat, i and i would like to buy a thermostat that works with domoticz and homekit...
which is the best product?
thanks
maomanna
Re: best thermostat for domoticz
Post by maomanna »
would be nice if you tell something about your CV system.
Is it openTherm, on/off etc.
albamatti
Domoticz version: 2020.1
Post by albamatti »
I use ThermoSmart. Is OpenTherm and can be used through HomeKit and with Siri
italoc
Post by italoc »
albamatti wrote:I use ThermoSmart. Is OpenTherm and can be used through HomeKit and with Siri
this one https://www.robbshop.nl/thermosmart-ope ... hermostaat ??
italoc
Post by italoc »
maomanna wrote:would be nice if you tell something about your CV system.
it isn't openTherm, I have 3 on/off thermostat
emme
Domoticz version: latest
Post by emme »
for my small bathroom I'm looking for a thermostat which is supposed to activate only a heater...
actually I have a virtual SP and a shedule that trigger a heater lamp until a rf433 thermometer rise to the wanted temp... that's fine.. it works... BUT... I cannot phisically (manually) setup the temp unless I do not do that acting to domoticz (in any way)
My intention would be to create a device (ESP8266 on NodeMCU) with a display showing the actual temp, the setpoint, date/time and 3 buttons: up/down/reset
the main problem is that I don't know how to do that :D :D :D
"We always done this way"
blauwebuis
Domoticz version: current
Post by blauwebuis »
What's the best option for an on-off heater?
blauwebuis
Wow, I just discovered the Smart Virtual thermostat plugin for Domoticz. It looks awesome!!
https://www.domoticz.com/wiki/Plugins/S ... ostat.html
tlpeter
Post by tlpeter »
Which uses python and python doesn't work anymore (in the beta's)
cyberclwn
Domoticz version: 2024.4
Post by cyberclwn »
blauwebuis wrote: Thursday 14 September 2017 12:27 What's the best option for an on-off heater?
Not sure if it is "the best" option, but i use a couple of these http://www.homewizard.nl/smartwares-dra ... kraan.html.
Don't use any of the scheduling posibilities on the valve, i just let domoticz set the temperature (14 at night, 19 at day) if it is lower then what i want (with a seperate thermometer).
This is to reduce the switch moment, no need to turn valve to 19 degrees if it is 22 (in summer) already ...
3xPi 2B (Domoticz "live", Domoticz "sandbox", PhotoFrame)
RFXCom433(E), KaKu, Oregon Scientific, Keyes 2-relay, Logitech Media Server, MiLight, Smartwares heating controller(2x), IR Send/Receive, Keyes PIR, XH-M131 DuskSensor, DHT22/11
timh1004
Post by timh1004 »
I‘m using the Smart Thermostat by Netatmo. It is not the cheapest, but it looks great, works very well and has an out of the box support by Domoticzs.
https://www.netatmo.com/product/energy/thermostat
