String concat in Blocky
I would like to concat 2 strings with blocky (to send using notification).
I would like to send to the notifcation something like that : "notification at " + time
I can not use operator "logic" "AND" to use with 2 texts ""
Is is possible to use concatenation in blocky ?
"te" + "xt" = "text"
Thanks.
Thanks.
Re: String concat in Blocky
I can't believe that this basic and essential function (concat 2 simple texts) is not possible in blocky in Domoticz !
IT's possible in blocky but not in Domoticz's blocky.
What a pity.
What a pity.
Well, it's an Open Source project. if you want it in, you can try adding it in yourself
Unfortunately, I'm not able to do that.
I don't know why the "create text with" function of Blocky is not present in Domoticz.
Life is full of choices, you can always request for this to be implemented, but many developers do this in their spare time, so don't expect a quick implementation of this feature
Ouate, have you tried an expression with {{ and }} ?
It's described here: https://www.domoticz.com/wiki/Events#Th ... _interface
Unfortunately, time is not an expression listed there, but you could first set time as a user variable and then refer to it as {{variable[1234]}} where 1234 is the Idx of this user variable. I haven't tried it myself, but thought it was worth a shot.
Thank you domonator.domonator wrote: ↑Monday 02 October 2017 22:17 Ouate, have you tried an expression with {{ and }} ?
It's a very interesting thing.
I didn't know that.
I will test it soon.
Thanks again for your help.
I regret the near hostile responses you have got from others from what I see as reasonable comment, I would agree with you: It is a real pity that more of the standard Blockly functionality is not available in Domoticz.
Generally there are many ways that one can contribute to open source. One can not only write it, but one can document it, one can test it, and one can report bugs. Most often I find I report bugs into a hostile environment where a bug report is seen as personal criticism. Not all of us can program and very few of us can program very well. But the "if you don't like it fix it" response you have received here is not constructive. A feature request is *also* one way to contribute to open source.
Thank you.psb777 wrote: ↑Sunday 15 October 2017 15:04I regret the near hostile responses you have got from others from what I see as reasonable comment, I would agree with you: It is a real pity that more of the standard Blockly functionality is not available in Domoticz.
I appreciate your comment.
That's exactly the feeling I had when I read the answer....
- Shaggie_NB
