Dashticz - Save CONFIG.js automatically with PHP
robgeerts
Domoticz version: 3.7067
Post by robgeerts »
In latest BETA-version, the config will be saved automatically to CONFIG.js with PHP.
Please backup your config.js ;)
Make sure your CONFIG.js is writable.
If it doesnt save the file, you will still get the screen where you can copy the config!
dutchdevil83
Domoticz version: latest
Re: Dashticz - Save CONFIG.js automatically with PHP
Post by dutchdevil83 »
Wow, nice work. Going to try it in a moment. You had a good vacation?
Just tested:
1) When clicking the settings icon and clicking save it saves so this is good
2) When going into EDIT mode my changes aren`t save to the config file and still have to this manually
Hardware
1x Raspberry Pi
1x Razberry Z-Wave
1x RFXtrx433E
1x Toon
1x GoodWe Solarpanels
2x FGSD-002 Smoke Detector
1x FGBS-001 Binaire Sensor (RFID lezer)
7x FGMS-001 Motion Sensor
3x ZW089 Verzonken Deursensor
7x NC Wallplug
&lots of KaKu stuff
EdwinK
Post by EdwinK »
It doesn't seem to save. If I change anything in settings and click 'save', the page refreshes, but no changes visible. I do believe I have PHP enabled on the webserver.
robgeerts
Post by robgeerts »
You do believe or are you sure? ;)
And is the file writable (chmod)
pvm
Domoticz version: 4.10538
Post by pvm »
Nice job, did a quick test by changing the dashboard title, that works.
Changing contents of the dashboard by f.e. adding a clock is not saved (beta version downloaded today ("Latest commit 957b89e 2 days ago"))
I started from default installation with only the correct IP set. After the first test I also tried to change config['auto_positioning'] to 0 (was on 1 before), but that also did not solve the issue. Will it be possible to switch auto_positioning from the web-config-interface in the future?
(for users with issues, I'm running Dashticz on my Synology nas, made the file write-able for the 'http' user by right clicking on the file in 'File Station')
EdwinK
Post by EdwinK »
pvm wrote: Tuesday 03 October 2017 15:08 (for users with issues, I'm running Dashticz on my Synology nas, made the file write-able for the 'http' user by right clicking on the file in 'File Station')
You mean, like this?
Screen Shot 2017-10-03 at 17.42.20.png (46.44 KiB) Viewed 6471 times
pvm
Post by pvm »
Yes, hope it helps you. Can you change the dashboard title now?
EdwinK
Post by EdwinK »
Nope. Tried, but nothing changes.
Maybe it's the PHP version I'm using. It's 5.6 (if I'm not mistaken) on Synology.
EdwinK
Post by EdwinK »
It does seem to change the config.js file, but doesn't show when page is reloaded. Something to figure out next time.
Reading through the config.js file, it looks like all config blocks are there at least twice (last count 5 times, because I tried it several times), one with the new settings, and below that are the old settings. So, first the title is defined as Control-Center, but... in the second (old) part the title is defined as ControlCenter. I think the latest read by the browser is what it is going to use for the page.
EdwinK
Post by EdwinK »
//var _EDIT_MODE = true;
var config = {}
config['domoticz_ip'] = 'http://192.168.0.10:8084';
config['app_title'] = 'ControlCenter';
config['domoticz_refresh'] = '15';
config['default_news_url'] = 'http://www.nu.nl/rss/algemeen';
config['news_scroll_after'] = 7;
config['standby_after'] = 'false';
config['auto_swipe_back_to'] = 1;
config['auto_swipe_back_after'] = 0;
config['auto_slide_pages'] = 0;
config['slide_effect'] = 'slide';
config['standard_graph'] = 'day';
config['language'] = 'nl_NL';
config['timeformat'] = 'YY-MM-DD HH:mm';
config['calendarformat'] = 'dd DD.MM HH:mm';
config['calendarlanguage'] = 'nl_NL';
config['calendarurl'] = 0;
config['boss_stationclock'] = 'RedBoss';
config['gm_api'] = 'SECRET';
config['gm_zoomlevel'] = '11';
config['gm_latitude'] = '51.860067';
config['gm_longitude'] = '4.412692';
config['wu_api'] = '17318c1fc1678195';
config['wu_city'] = 'Rhoon';
config['wu_name'] = 0;
config['wu_country'] = 'NL';
config['idx_moonpicture'] = 1;
config['switch_horizon'] = 0;
config['host_nzbget'] = 0;
config['spot_clientid'] = 'More Secret–';
config['sonarr_url'] = 0;
config['sonarr_apikey'] = 0;
config['sonarr_maxitems'] = 0;
config['garbage_company'] = 'recyclemanager';
config['garbage_icalurl'] = 0;
config['garbage_zipcode'] = '3161LH';
config['garbage_street'] = 'Jonkerhof';
config['garbage_housenumber'] = '27';
config['garbage_maxitems'] = 1;
config['selector_instead_of_buttons'] = 1;
config['auto_positioning'] = 0;
config['use_favorites'] = 0;
config['last_update'] = 0;
config['hide_off_button'] = 1;
config['hide_topbar'] = 0;
config['edit_mode'] = 0;
config['hide_seconds'] = 0;
config['hide_seconds_stationclock'] = 0;
config['use_fahrenheit'] = 0;
config['use_beaufort'] = 1;
config['translate_windspeed'] = 0;
config['static_weathericons'] = 0;
config['hide_mediaplayer'] = 0;
config['app_title'] = 'Control-Center';
config['gm_api'] = 'TOP SECRET';
config['spot_clientid'] = 'MY EYES ONLY';
And everytime I save the from the webbrowser a new block like this is added
robgeerts
Post by robgeerts »
Could you send me your complete config.js?
pvm
Post by pvm »
I do not see the effect of continuous adding of blocks. I'm not able to add any blocks however.
Do I need to specify columns or should everything be possible from within the web-interface?
(when setting auto positioning to 1 i see my favorites)
When I use the chrome web-interface nothing happens when pressing save after adding some blocks. The save button in the settings screen does generate a lot of calls and a refresh op the page.
Is there any more info I can provide?
My config (changed app_title, / coordinates
var config = {}
config['domoticz_ip'] = 'http://192.168.1.2:8084';
config['app_title'] = 'ABCD';
config['domoticz_refresh'] = 5;
config['standby_after'] = 0;
config['auto_swipe_back_after'] = '10';
config['auto_slide_pages'] = '';
config['standard_graph'] = 'hours';
config['timeformat'] = 'DD-MM-YY HH:mm';
config['calendarurl'] = '';
config['gm_api'] = '';
config['gm_zoomlevel'] = '';
config['gm_latitude'] = '11';
config['gm_longitude'] = '22';
config['wu_api'] = '';
config['wu_city'] = 'Amsterdam';
config['wu_name'] = '';
config['idx_moonpicture'] = '';
config['switch_horizon'] = '';
config['host_nzbget'] = '';
config['spot_clientid'] = '';
config['sonarr_url'] = '';
config['sonarr_apikey'] = '';
config['sonarr_maxitems'] = '';
config['garbage_company'] = '';
config['garbage_icalurl'] = '';
config['garbage_zipcode'] = '';
config['garbage_street'] = '';
config['garbage_housenumber'] = '';
config['garbage_maxitems'] = '';
config['garbage_width'] = '';
config['selector_instead_of_buttons'] = 0;
config['use_favorites'] = 1;
config['last_update'] = 1;
config['hide_off_button'] = 0;
config['edit_mode'] = 1;
config['use_beaufort'] = 0;
config['translate_windspeed'] = 1;
EdwinK
Post by EdwinK »
robgeerts wrote: Friday 06 October 2017 12:25 Could you send me your complete config.js?
Will do.
Blueone
Post by Blueone »
Does someknow know what chmod I have to use to make sure the config.js is writable for the webuser?
Blueone
Post by Blueone »
I tried a lot to write the config automatically to the config.js, it doesn't work om my end. Does anyone have an idea about how to fix this?
Blueone
Post by Blueone »
anyone knows how to do this?
gielie
Domoticz version: latest β
Post by gielie »
in my system the save option doesn't work, before, when i pushed save, i got an page with the settings which i had to copy to the config.js but i don't get this anymore how can i get this back?
- Aeotec MultiSensor 6
- FIBARO FGS223
- FIBARO FGWPE Wall Plug
- Neo CoolCam Power plug
- Popp Smoke Detector
- Toon
- Kodi Media Server
michaelm86
Domoticz version: 3.8153
Post by michaelm86 »
Hi Guys,
i have installed the beta of dashticz on my ubuntu server. But when i lauch it the first time. the changed are not saved to config.js.
i did the following :
- installed ubuntu and comfiguratio
- installed php 7
- installed and configured domoticz (working adn using it)
- git clone https://github.com/robgeerts/dashticz_v2 --branch beta
- sudo chmod 777 -R domoticz/
- sudo cp CONFIG_DEFAULT.js CONFIG.js
- lauched the web browser and accessed the ip of my server http://192.168.116.80:8080/dashticz_v2/
can anyone help me ou? :)
Domoticz 3.8153 on linux laptop ubuntu 17.10 | Toon Thermostat | RFlink usb gateway
DewGew
Domoticz version: V4.10618
Post by DewGew »
michaelm86 wrote: Monday 12 February 2018 10:04 Hi Guys,
- installed php 7
Edit CONFIG.js and put only this and try again:
var config = {}
config['domoticz_ip'] = 'http://ipnumber:port';
michaelm86
Hi DewGew,
I tried this. but is does not work ... :(
when i add the ip and port is does not see it in the config. but when i add the user and ww it sees it.
any other options?
