Fish pond pump script
D3LTA
Domoticz version: 3.8153
Post by D3LTA »
Anyone here knows if there is a Fish pond pump script that deals with time and weather data?
i searched everywhere and also tried making my own from some heating scripts but without any luck and working script....
what i'm looking for is a script that sets on the pond pump x time (for example 2 hours and then off) at a x interval (example 2 hours on and 1 hours off and repeats that )
and if the temperature is below a x variable (like 0 degrees) it will not turn in on at all of turns is on continuously
i truly hope some of you could help me out or can give me some examples to work with.
(made serveral bash and python scripts, but i can't seem too figure out this one)
thanks alot
zicht
Domoticz version: 2023.1+
Re: Fish pond pump script
Post by zicht »
In Lua, just give youre some idea;s to get you started with the timing :
time = os.date("*t")
put the time/date table in variable time
 if (time.hour==7 or time.hour==19) and time.min==0 then ....pump on or off  ..... end
time.hour contains the hours of time.
time.min contains the minite of time
if ((time.min% 2)==0) then ..... end
would run every 2 minutes, this can also be done with time.hour.
Dont forget to load the table in time (first sentence)
D3LTA
Post by D3LTA »
thanks for the push in right direction.. will give it a shot tonight.. is it okay if i post my progress here.. so you can maybe help me out a little?
zicht
Post by zicht »
D3LTA wrote: Sunday 24 September 2017 18:25 thanks for the push in right direction.. will give it a shot tonight.. is it okay if i post my progress here.. so you can maybe help me out a little?
See PM and yes you can post it here if you made something, that way others can benefit or think together with you
Egregius
Domoticz version: v2024.7
Post by Egregius »
With pass2php times are quite easy:
<?php
$temp=status('temperature');
$pump=status('pump');
if($temp>25){
	//To hot, let's pump continuosly
	if($pump!='On')sw('pump','On');
}elseif($temp>0){
	//Normal temp
	if($pump=='On'&&timestamp('pump')<time-7200)sw('pump','Off');
	elseif($pump=='Off'&&timestamp('pump')<time-3600)sw('pump','On');
}else{
	//It's freezing cold, don't pump at all
	if($pump!='Off')sw('pump','Off');
D3LTA
Post by D3LTA »
Egregius wrote: Monday 25 September 2017 6:13 With pass2php times are quite easy:
<?php
if($temp>25){
}elseif($temp>0){
	//Normal temp
}else{
that looks very good indeed, but how does it get the var temp and pump? are those the names in domoticz ?
i can read the script and understand it.. but can you explain the "timestamp".. is that a persistant value? or does it read the time variables from domoticz? ("last seen")
How do i implement it?
Egregius
Post by Egregius »
Yes, the names of Domoticz.
You'll need to get pass2php running. All the magic happens there.
D3LTA
Post by D3LTA »
thats no problem, please help me understand the script (timestamps) as i have no php knowledge.
is it also possible to store values? because for example if it freezes for 2 days, and temp gets above 0 again.. it takes for example 5 days before the pump can start again because the ice needs to melddown.
D3LTA
Post by D3LTA »
realy hope you or someone willing to make this a working script... i just don't have the knowledge..yet.. :cry:
Egregius
Post by Egregius »
you can store custom variables with the setstatus() function and read them with the status() function of pass2php.
You could (for example) set a variable 'hasfrozen' to the lowest frost temperature. pass2php automatically remembers the last set time of a var.
Didn't test this, but something like this could be a good direction:
<?php
if($temp>25){
}elseif($temp>8){
	//Normal temp, let's cycle 2 hours on, 1 hour off
}elseif($temp>0){
	//It's cold, did it freeze lately?
	$hasfrozen=status('hasfrozen');
	$hasfrozentime=timestamp('hasfrozen');
	if($hasfrozen<-20){
		//damned that was cold, lets wait 10 days
		if($hasfrozentime<time-(86400*10)){
	}elseif($hasfrozen<-10){
		//damned that was cold, lets wait 5 days
		if($hasfrozentime<time-(86400*5)){
	}elseif($hasfrozen<-5){
		//damned that was cold, lets wait 2 days
		if($hasfrozentime<time-(86400*2)){
	}elseif($hasfrozen<0){
		//Just a litle frost, one day will do
		if($hasfrozentime<time-86400){
	}else{
		//It didn't freeze, lets cycle
}else{
	if($temp<$hasfrozen)setstatus('hasfrozen',$temp);
A lot of information of pass2php can be found at http://www.domoticz.com/forum/viewtopic ... 64&t=12343
D3LTA
Post by D3LTA »
Thank you very much Egregius.. will give it a try
what will happen if it's -11 2 days in a row? it will just stay 5 days with every extra day its still freezing -11 ?
D3LTA
Post by D3LTA »
Anyone willing to help debug and improve this script?
thanks in advance
-- start lua commandarray  = schakel tabel waarin we opdrachten gaan geven
-- functie timedifference = functie di we  verderop aanroepen om te zien hoe lang pomp aan is of uit is.
function timedifference (s)   --- tijdverschil bepalen sinds laatste schakeling in sec
   yearx=string.sub(s, 1, 4) monthx=string.sub(s, 6, 7) dayx=string.sub(s, 9, 10)
   hourx=string.sub(s, 12, 13) minutesx=string.sub(s, 15, 16) secondsx=string.sub(s, 18, 19)
   t1=os.time()
   t2=os.time{year=yearx, month=monthx, day=dayx, hour=hourx, min=minutesx, sec=secondsx}
   difference=os.difftime (t1, t2)
   --print(s.." "..tostring(t).." "..tostring(difference))
   return difference
-- zet de temperatuur in variable zodat we deze later als vooraarde kunnen laten dienen-- bepaal wat er moet gebeuren
local temp = otherdevices_temperature['Temp Ground / Humidity (Twente)']  -- zet temp in waarde, en maak er n getal van ipv string
local laag= 0  -- min temp
local hoog= 25 -- max temp
local timediff=timedifference(otherdevices_lastupdate['vijver-pomp'])
local pompstatus=otherdevices['vijver-pomp']
local pompbeveiliging=false
-- normaal
if temp>laag and temp<hoog then
    max_uit = 3600     -- 3600 sec (1 uur)
    max_aan = 7200    -- 7200 sec (2uur)
-- warm
if temp>laag and temp>hoog then
    max_uit = 1800       -- 1800 sec (30 min)
    max_aan = 10800    -- 10800 sec (3uur)
-- koud
if temp<laag and temp<hoog then
    pompbeveiliging=true
-- Doe wat er moet gebeuren normaal en warm
if pompbeveiliging==false then      -- alleen schakelen als de pompbeveiliging niet actief is
    if otherdevices['pompstatus'] == 'Off' and timediff>max_uit then        -- aanzetten als uit en te lang uit
        commandarray['pompstatus']='On'
    if otherdevices['pompstatus']== 'On' and timediff>max_aan then       -- uitzetten als aan en te lang aan.
        commandarray['pompstatus']='Off'
-- Doe wat er moet gebeuren bij vorst
if pompbeveiliging==true and otherdevices['pompstatus']=='On' then        -- als pompbeveiliging actief is en pomp aan dan pomp uitzetten
return commandArray -- nu gaat domoticz wat we in commandarray hebben geplaatst ook werkelijk uitvoeren
