Old Intertechno Dimmer
Netsurfer24
Post by Netsurfer24 »
I am totally new to Domoticz, so please excuse my Noob question.
I am using the Intertechno 433 MHz system now for nearly 20 years and therefore I have some old socket plugs with dimmer.
The problem I am facing right now is, that those old plugs are switched on AND off by the Off-Button (on Intertechno's remote controls) and if it's switched on, then pressing/ sending the On command will start the dimming (from current level to max, to low) until a second On command will be send.
So of course these plugs do not work with Domoticz (out of the box), as neither the Dimmer, nor the normal On/Off switch work!
Is there a way (by writing a small script or other options) to still use them, or are they simply too old ...? ;)
Many thanks in advance for any help and/ or tips.
Greetings
Gunther
