Dutch Newspaper: poor security for public camera’s. Specific Domoticz-install also vulnerable!
manjh
Domoticz version: 2025.2
Re: Dutch Newspaper: poor security for public camera’s. Specific Domoticz-install also vulnerable!
Post by manjh »
R0yk3 wrote: Thursday 21 September 2017 13:42 Why not use a vpn connection?
Sounds like a better solution.
Hans
dervogt
Post by dervogt »
how about using the login page of domoticz together with the well documented reverse nginx proxy setup from the wiki, this is as secure as you can get at this moment of time.....
jannl
Domoticz version: 2026.1.x
Post by jannl »
That is indeed the best solution I think, but a bit harder to configure for a lot of people
manjh
Post by manjh »
jannl wrote: Thursday 21 September 2017 14:14 That is indeed the best solution I think, but a bit harder to configure for a lot of people
Well, after upgrading my Domoticz server HW to a R-Pi-3, I have a spare type-2 laying around. I'll have a go at setting that up as VPN server.
Or is it safe enough to run VPN on the same Pi as Domoticz?
Somehow it "feels" like a better solution to keep them separate, but.... :oops:
Hans
jannl
Post by jannl »
Seperate seems better. My VPN runs on my router (Fritzbox)
manjh
Post by manjh »
jannl wrote: Thursday 21 September 2017 15:44 Seperate seems better. My VPN runs on my router (Fritzbox)
Ah, there's an idea! I have a modem from my supplier that might hack it, and if that doesn't I can always try my own router (Netgear R9000). Thanks for the tip! I hadn't thought of that. :)
Hans
Jan Jansen
Domoticz version: Stable
Post by Jan Jansen »
Why do you think it seems? What are the real risks?
jannl
Post by jannl »
As long as the vpn is not the first entry point, other hosts might get exppsed. Also depending on the security of your router.
Verstuurd vanaf mijn SM-G930F met Tapatalk
Jan Jansen
I installed Domoticz and Openvpn on 1 rpi. In my router I only opened the openvpn port. At this point I'm a noob but I thought I'm safe. Now I'm beginning to doubt. Is that doubt right?
jannl
Post by jannl »
You are safe enough. No one will ever be 100% safe. Keep everything updated and you are good.
R0yk3
Post by R0yk3 »
manjh wrote: Thursday 21 September 2017 17:08
I let my (ziggo) router put in Bridge modus. So my router (r7000 with merlin firmware) handles directly the VPN requests. Works like a charm behind that i have my domoticz behind a password no https.
Raspberry PI 3, raspbian, ZwaveMe, RFLink
manjh
Post by manjh »
I decided to go the safe way: installed a VPN server, added it to my Domoticz R-Pi3.
Installation was really simpel: PiVPN. Check it out, it installs itself and only asks for a few minor things.
CPU load on the R-Pi did not increase much, it used to be at a steady 3%, now at 4.5%. Still well within safety margins.
Hans
Derik
Post by Derik »
how can i install fal to ban on my rpi near domoticz?
Egregius
Domoticz version: v2024.7
Post by Egregius »
apt-get install fail2ban?
