Domotics touchscreen remote
ledfreak3d
Domoticz version: 3.8025
Post by ledfreak3d »
been tinkering around with my esp8266 and nextion display and came up with this
Latest Version
https://www.youtube.com/watch?v=c9OlHDThYEU&t
version 1
https://www.youtube.com/watch?v=8l1OMS5RgYA
version 2
https://www.youtube.com/watch?v=cjk7dPBZKyQ
version 3
https://www.youtube.com/watch?v=eGgEL6HHckQ
its still a work in progress but it turned out realy nice
also supports ota updates via a web interface
Unleashe the magic smoke ;)
blauwebuis
Domoticz version: current
Re: Domotics touchscreen remote
Post by blauwebuis »
Very nice. Is that a custom front end?
EdwinK
Post by EdwinK »
I like the Star Trek one :)
jackslayter
Domoticz version: stable
Post by jackslayter »
Need !!
RPi2 + RFLink, Domoticz
Chacon - micromodule 200w, remote 3b, 2x module 1000w, remote 16b, smoke detector, door contact, 2x 3500w plug
Oregon - 3x Thgr122Nx / OWL - CM180 / TRC02_2 RGB / Cheap - PiR, door contact, Temp Hum / 4x REVOLT NC5461
heggink
Domoticz version: 12451
Post by heggink »
Those displays are pretty magnificent. Not cheap tho for the bigger ones.
P1 meter & solar panel
dannybloe
Post by dannybloe »
This is awesome! I do like the star trek one the best. Didn't know about that display. Cool stuff.
bilbolodz
Post by bilbolodz »
ledfreak3d wrote: Sunday 17 September 2017 20:21 been tinkering around with my esp8266 and nextion display and came up with this
Are you going to share your project?
ledfreak3d
Yep sure are
for anybody that's wants it just contact me
new version has had a lot of updates both in the code as in the gui
rbo0567
Domoticz version: v4.9701
Post by rbo0567 »
Is it possible to use it as an alarm keypad? Are you considering to implement that in your project?
I would really like this because I can't find a nice and good featured alarm keypad to use with domoticz.
ledfreak3d
not sure but I can investigate
if its possible to send json commands for the keypad then it should be possible
ledfreak3d
Latest version is here
now has a couple of new options
-ftp server onboard for uploading config files
-config can be changed via build in webserver
-battery status is reported back to domoticz.
-voice updates are possible now via the remote hw info will folow
-battery last atleast a full day with a 2600 mAh Lipo
https://github.com/ledfreak3d/Domoticz-remote-
alexsh1
Domoticz version: v3.8975
Post by alexsh1 »
ledfreak3d wrote: Tuesday 13 February 2018 21:24
Which Nextion display do you use please?
Could you share your 3D enclosure files as well?
Many thanks
ledfreak3d
Hi.
I use the 3.5 inch version
there is a case i designed for it on thingiverse.
make sure you download the version with the usb port cutout
https://www.thingiverse.com/thing:1708255
ledfreak3d
tontze
Domoticz version: Beta Ch
Post by tontze »
Very nice !
Smartthings
zigbee2mqtt
RFLink 433mhz / Nrf 2.4Ghz
Mi Light
esp8266MiLight Hub
dannybloe
Post by dannybloe »
Is this also a nice solution to create a security panel with?
ledfreak3d
should be possible i think
ledfreak3d
need some help with gui optimization and code cleanup and add some features and need some people for testing
BigDog
Domoticz version: V3.9269
Post by BigDog »
WOW i really would like this one!
it it easy to adjust to personal situation?
and the "how to make it" is it good to do for a beginning electronica person , i can make some prints but not so advanced and i need a schematics
1X Raspberry4B : Domoticz Version 2023.1 [Linux 5.10.63-v7l+ armv7l]
1X Conbee II : 2.25.3 - 26720700
1X RFXtrx433 USB Firmware:183
1X Mysensors Gateway 1.5 -3
6X ESP8266: Tosmota firmware
Zigbee : 6 Operators, 13 Sensors
BigDog
Post by BigDog »
question: do you guysd know where to get a printed version of this "Nextion housing for 3.5 inch"
or some place where to get a good housing for this project?
