Domoticz does not open port 8080
MasWetens
Dear Domoticz,
I installed Domoticz already several times using the following command:
"Sudo curl -L install.domoticz.com | (sudo) bash"
When I check the installation using:
"wget localhost"
Isn't the port 8080 showing up, but I set in de setting that popped up when I installed it at port 8080.
What can I do to solve this problem????
"wget localhost"
pvm
- Domoticz version: 4.10538
Re: Domoticz does not open port 8080
wget localhost:8080Synology NAS, slave PI3, ZWave (Fibaro), Xiaomi zigbee devices, BTLE plant sensor, DzVents, Dashticz on tablet, Logitech Media Server
MasWetens
When I do
Get I a return as follows:
Thank you for your reaction pvm.
wget localhost:8080Code: Select all
--2017-09-04 16:55:52-- http://localhost:8080/
Resolving localhost (localhost)... ::1, 127.0.0.1
Connecting to localhost (localhost)|::1|:8080... failed: Connection refused.
Connecting to localhost (localhost)|127.0.0.1|:8080... failed: Connection refused.-
Elvana
Hi, I had the same issue.
As a NOOB it took me some time to work this out... which is why I am sharing the following in boring detail.
On a new 16 GB SDcard I had installed Raspbian Stretch from https://www.raspberrypi.org/downloads/raspbian/
Upon starting the partition size was automically adjusted.
After opening a terminal window I ran sudo raspi-config and changed password, timezone, ssh access and screen resolution and overscan (last three under interfacing options).
Then rebooted in the terminal window by issuing
I then installed Domoticz "The Easy Way" according to https://www.domoticz.com/wiki/Installin ... e_easy_way with This ran successfully but yielded Domoticz inaccessible (with and without https enabled - no difference).
Like the topic starter - after a reboot I could not access Domoticz on either port 8080 or 443:
I found this topic as well as this other one viewtopic.php?t=18020 and my error message read:
From a browser window on the raspberry I downloaded the armhf version of libssl.so.1.0.0 from https://packages.debian.org/jessie/libssl1.0.0
In a terminal window I installed the package:
stopped and restarted Domoticz (a reboot should also work):
then checked availability of Domoticz on port 8080:
after this I could also access Domoticz from other devices.
sudo rebootCode: Select all
sudo curl -L install.domoticz.com | sudo bashLike the topic starter - after a reboot I could not access Domoticz on either port 8080 or 443:
pi@domoticzR1:~ $ wget localhost:8080
--2017-09-12 11:10:09-- http://localhost:8080/
Connecting to localhost (localhost)|127.0.0.1|:8080... failed: Connection refused.I found this topic as well as this other one viewtopic.php?t=18020 and my error message read:
sudo service domoticz.sh status
● domoticz.service - LSB: Home Automation System
Loaded: loaded (/etc/init.d/domoticz.sh; generated; vendor preset: enabled)
Active: active (exited) since Tue 2017-09-12 11:08:28 CEST; 6min ago
Docs: man:systemd-sysv-generator(8)
Process: 1100 ExecStop=/etc/init.d/domoticz.sh stop (code=exited, status=0/SUCCESS)
Process: 1110 ExecStart=/etc/init.d/domoticz.sh start (code=exited, status=0/SUCCESS)
CGroup: /system.slice/domoticz.service
Sep 12 11:08:27 domoticzR1 systemd[1]: Starting LSB: Home Automation System...
Sep 12 11:08:28 domoticzR1 domoticz.sh[1110]: /home/pi/domoticz/domoticz: error while loading shared libraries: libssl.so.1.0.0: cannot open shared object file:
Sep 12 11:08:28 domoticzR1 systemd[1]: Started LSB: Home Automation System.In a terminal window I installed the package:
pi@domoticzR1:~ $ cd Downloads
pi@domoticzR1:~/Downloads $ sudo dpkg -i libssl1.0.0*
Selecting previously unselected package libssl1.0.0:armhf.
(Reading database ... 122756 files and directories currently installed.)
Preparing to unpack libssl1.0.0_1.0.1t-1+deb8u6_armhf.deb ...
Unpacking libssl1.0.0:armhf (1.0.1t-1+deb8u6) ...
Setting up libssl1.0.0:armhf (1.0.1t-1+deb8u6) ...Code: Select all
pi@domoticzR1:~/Downloads $ cd ..
pi@domoticzR1:~ $ sudo service domoticz.sh stop
pi@domoticzR1:~ $ sudo service domoticz.sh start
pi@domoticzR1:~ $ wget 127.0.0.1:8080
--2017-09-12 12:01:53-- http://127.0.0.1:8080/
Connecting to 127.0.0.1:8080... connected.
HTTP request sent, awaiting response... 200 OK
Length: 90327 (88K) [text/html]
Saving to: ‘index.html’
index.html 100%[===================>] 88.21K --.-KB/s in 0.002s
2017-09-12 12:01:53 (57.4 MB/s) - ‘index.html’ saved [90327/90327]
hello,
sorry for this simple question...
how did you put libssl.so.1.0.0 in the download directory?
wich version of this lib did you use?
Many thanks for your answers
koowee
here is one way how you can do it
http://www.domoticz.com/forum/viewtopic ... 20#p150258
Many thanks for your help. I did it but I still become this page : Apache2 Debian Default Pagekoowee wrote: Wednesday 13 September 2017 7:27 here is one way how you can do it
Any idea?
SweetPants
Ehhh "Apache2 Debian Default page" suggests you have apache installed too. Domoticz has it's own web server (not apache). Does that run on 8080 too? Try starting domoticz manually with a different "-www port"wegen wrote: Wednesday 13 September 2017 17:15Many thanks for your help. I did it but I still become this page : Apache2 Debian Default Page Any idea?
I really need your help. Could you contact me private?SweetPants wrote: Wednesday 13 September 2017 19:20Ehhh "Apache2 Debian Default page" suggests you have apache installed too. Domoticz has it's own web server (not apache). Does that run on 8080 too? Try starting domoticz manually with a different "-www port"wegen wrote: Wednesday 13 September 2017 17:15Many thanks for your help. I did it but I still become this page : Apache2 Debian Default Page Any idea?
I still don't get it:
I followed those steps:
Install Raspbian desktop edition
activate ssh by creating ssh file in boot
connect via putty, user pi
run command
run command
I cannot reach my roboticz at the adress: 192.168.1.112:8080
ping on 192.168.1.112 works
I use RPI3
pi@raspberrypi:~/domoticz $ wget 192.168.1.112:8080
--2017-09-17 20:20:40-- http://192.168.1.112:8080/
Connecting to 192.168.1.112:8080... failed: Connection refused.Install Raspbian desktop edition
run command
sudo curl -L install.domoticz.com | sudo bashCode: Select all
cd domoticz
./updatereleaseCode: Select all
wget http://mirrordirector.raspbian.org/raspbian/pool/main/o/openssl/libssl1.0.0_1.0.1t-1+deb8u6_armhf.deb
sudo dpkg -i libssl1.0.0_1.0.1t-1+deb8u6_armhf.debCode: Select all
sudo curl -L install.domoticz.comping on 192.168.1.112 works
I use RPI3
jandirkv
- Domoticz version: 3.9117
I have also a problem with remote access. Port 8080 is open and forwarded in my router to the Domoticz ip. But when I try to access I get routed to the login page of my router.
jandirkv
I finale have a solution. The problem was My router. I have a new one and all my problems are solved. Thanks for all the help
SweetPants
Please be aware this (HTTP) is highly insecure. Better switch to HTTPS (443) and use Certificates or a VPN connection.jandirkv wrote: Thursday 03 May 2018 17:53 I have also a problem with remote access. Port 8080 is open and forwarded in my router to the Domoticz ip. But when I try to access I get routed to the login page of my router.
Tonio16
- Domoticz version: 4.9700
Hello
I have two domoticz at home. One on a Pi B+ and a second on a Pi 3+.
Today, for less than 1 hour, I have the offline page on the Pi 3+. Just after I finaly set up the Synology monitoring: https://www.domoticz.com/wiki/NAS_Monitoring#Synology
I also made an apt-get update/upgrade this afternoon but it was working fine after though I made several reboots.
If i do the wget:
but the service is running
If i do the wget:
wget localhost:8080
--2018-08-01 21:45:53-- http://localhost:8080/
Résolution de localhost (localhost)… ::1, 127.0.0.1
Connexion à localhost (localhost)|::1|:8080… échec : Connexion refusée.
Connexion à localhost (localhost)|127.0.0.1|:8080… échec : Connexion refusée.
domoticz@raspberrypi:~ $ sudo /etc/init.d/domoticz.sh status
Active: active (exited) since Wed 2018-08-01 21:25:14 CEST; 25min ago
Process: 528 ExecStart=/etc/init.d/domoticz.sh start (code=exited, status=0/SUCCESS)
aoû 01 21:25:13 raspberrypi systemd[1]: Starting LSB: Home Automation System...
aoû 01 21:25:14 raspberrypi domoticz.sh[528]: 2018-08-01 21:25:14.741 Stat…Cuz
aoû 01 21:25:14 raspberrypi domoticz.sh[528]: 2018-08-01 21:25:14.754 Stat…:51
aoû 01 21:25:14 raspberrypi domoticz.sh[528]: 2018-08-01 21:25:14.766 Stat…cz/
aoû 01 21:25:14 raspberrypi domoticz.sh[528]: domoticz: Domoticz is startin…...
aoû 01 21:25:14 raspberrypi domoticz[548]: Domoticz is starting up....
aoû 01 21:25:14 raspberrypi domoticz[588]: Domoticz running...
aoû 01 21:25:14 raspberrypi systemd[1]: Started LSB: Home Automation System.
Hint: Some lines were ellipsized, use -l to show in full.
Koensk
This looks the same with me. But from another pc I cannot connect. Hows that possible?
2017-09-12 12:01:53 (57.4 MB/s) - ‘index.html’ saved [90327/90327]-
jornm
To make i easier for people to help you troubleshoot run the command:
sudo netstat -lpn
and paste the result.
This will show what process is listening on which port.
sudo netstat -lpn
m.versteegh
I'm facing the same issue. Seems domoticz is running, but I'm not able to access the GUI. I guess the webserver is not running as shown below by a netstat output. Any hints?jornm wrote: Monday 27 August 2018 17:21 To make i easier for people to help you troubleshoot run the command:
sudo netstat -lpn
Note: Running on a 1st generation Pi, 2B, most recent beta version of domoticz. Domoticz itself is running, at least that what service domoticz status states.
Proto RefCnt Flags Type State I-Node PID/Program name Path
unix 2 [ ACC ] SEQPACKET LISTENING 6398 1/init /run/udev/control
unix 2 [ ACC ] STREAM LISTENING 11525 429/python3 /var/run/fail2ban/fail2ban.sock
unix 2 [ ACC ] STREAM LISTENING 12084 511/systemd /run/user/1000/systemd/private
unix 2 [ ACC ] STREAM LISTENING 12089 511/systemd /run/user/1000/gnupg/S.gpg-agent.extra
unix 2 [ ACC ] STREAM LISTENING 12092 511/systemd /run/user/1000/gnupg/S.gpg-agent.browser
unix 2 [ ACC ] STREAM LISTENING 12094 511/systemd /run/user/1000/gnupg/S.gpg-agent
unix 2 [ ACC ] STREAM LISTENING 12096 511/systemd /run/user/1000/gnupg/S.gpg-agent.ssh
unix 2 [ ACC ] STREAM LISTENING 8263 1/init /run/thd.socket
unix 2 [ ACC ] STREAM LISTENING 8265 1/init /var/run/avahi-daemon/socket
unix 2 [ ACC ] STREAM LISTENING 8268 1/init /var/run/dbus/system_bus_socket
unix 2 [ ACC ] STREAM LISTENING 6065 1/init /run/systemd/private
unix 2 [ ACC ] STREAM LISTENING 8883 362/dhcpcd /var/run/dhcpcd.sock
unix 2 [ ACC ] STREAM LISTENING 8885 362/dhcpcd /var/run/dhcpcd.unpriv.sock
unix 2 [ ACC ] STREAM LISTENING 6085 1/init /run/systemd/fsck.progress
unix 2 [ ACC ] STREAM LISTENING 6087 1/init /run/systemd/journal/stdout
m.versteegh
- waaren
can you see anything in the domoticz logfile ?
what do you see when you do a sudo ps -ef | grep domo from the commandLine ?
m.versteegh
I've initialised logging and rebooted the system, so it's a fresh log. It starts with the items as provided below. The log does contain a error, but that is related to InfluxDB. Based on the log, I would say that it has fired up the server running at 8443.waaren wrote: Monday 31 December 2018 14:42can you see anything in the domoticz logfile ?
The result of sudo ps -ef | grep domo is:
pi 555 524 0 14:38 pts/0 00:00:00 grep --color=auto domoCode: Select all
019-01-01 14:29:50.317 Status: Domoticz V4.10304 (c)2012-2018 GizMoCuz
2019-01-01 14:29:50.327 Status: Build Hash: 30480b21, Date: 2018-12-30 09:37:02
2019-01-01 14:29:50.339 Status: Startup Path: /home/pi/domoticz/
2019-01-01 14:29:51.328 Sunrise: 08:45:00 SunSet: 16:39:00
2019-01-01 14:29:51.328 Day length: 07:54:00 Sun at south: 12:05:00
2019-01-01 14:29:51.328 Civil twilight start: 08:05:00 Civil twilight end: 17:19:00
2019-01-01 14:29:51.328 Nautical twilight start: 07:22:00 Nautical twilight end: 18:02:00
2019-01-01 14:29:51.340 Astronomical twilight start: 06:41:00 Astronomical twilight end: 18:43:00
2019-01-01 14:29:51.347 Status: EventSystem: reset all events...
2019-01-01 14:29:55.066 Status: PluginSystem: Started, Python version '3.5.3'.
2019-01-01 14:29:55.318 Active notification Subsystems: (0/13)
2019-01-01 14:29:55.388 Status: WebServer(HTTP) started on address: :: with port 8080
2019-01-01 14:29:55.603 Status: WebServer(SSL) started on address: :: with port 8443
2019-01-01 14:29:55.645 Status: Proxymanager started.
2019-01-01 14:29:55.709 Status: Camera: settings (re)loaded
2019-01-01 14:29:55.714 Starting shared server on: :::6144
2019-01-01 14:29:55.749 Status: TCPServer: shared server started...
2019-01-01 14:29:55.749 Status: RxQueue: queue worker started...
2019-01-01 14:29:57.753 Status: XiaomiGateway (ID=5): Delaying worker startup...
2019-01-01 14:29:58.254 Status: OpenZWave: using config in: /home/pi/domoticz/Config/
2019-01-01 14:29:58.321 Status: OpenZWave: Starting...
2019-01-01 14:29:58.321 Status: OpenZWave: Version: 1.4-3276-g43740494-dirty
2019-01-01 14:29:59.634 Status: OpenZWave: Driver Ready
