bigmak
- Domoticz version: 4.10693
Guys, just 2 questions:
1. Am i right that we have an update with Aqara water leak detector? https://github.com/domoticz/domoticz/pu ... 178515e9d2
2. How to update Domoticz to install this water leak detector?
Thank you!
Thank you!
chatainsim
- Domoticz version: v4.11307
You have to wait until Gizmocuz approve the commit.bigmak wrote: Tuesday 12 September 2017 11:07 Guys, just 2 questions:
Thank you!
Mace
- Domoticz version: 3.8153
Updated to the newest beta today, removed the Gateway and added it again and now works flawlessly!Mace wrote: Tuesday 12 September 2017 7:30 My Xiaomi works great in Domoticz with the attached sensors (human body, temp&humidity sensors), but when I want to trigger something on the device itself(fe ring the doorbell), I'm getting an error:
'Error: XiaomiGateway: unable to write command - Invalid Key"
Search thru a lot of posts, but can't find an answer on how to solve this. I'm currently on the latest Beta, I was running on the latest stable production version, upgrading to beta didn't help.
TigroEHOT
Try to check the passphrase for the gateway in the app, and check it in the domoticz plugin setup. It's probably nessesary to generate new password for the gateway and edit it in the plugin. Worked for me.Mace wrote: Tuesday 12 September 2017 7:30 My Xiaomi works great in Domoticz with the attached sensors (human body, temp&humidity sensors), but when I want to trigger something on the device itself(fe ring the doorbell), I'm getting an error:
Mace
@TigroEHOT: See my post directly above yours....I indeed removed it, refreshed my password and it worked again!
xbox2610
Hi everyone I wanted to ask if by accident there are working problems with aqara human body sensor and domoticz?
thank you
thank you
- mvveelen
Does anyone know how I can connect the Xiaomi gateway to my new router (with new SSID) without resetting and having to add all sensors again?
chatainsim
I have some issue with body sensor (1st gen) that doesn't detect motion but it's not related to Domoticz has I also can't see the motion in Mi Home.xbox2610 wrote: Thursday 14 September 2017 22:17 Hi everyone I wanted to ask if by accident there are working problems with aqara human body sensor and domoticz?
thank you![]()
chatainsim
I'm also interested to know if there is a way.mvveelen wrote: Thursday 14 September 2017 22:35 Does anyone know how I can connect the Xiaomi gateway to my new router (with new SSID) without resetting and having to add all sensors again?
chatainsim
I've found this :mvveelen wrote: Thursday 14 September 2017 22:35 Does anyone know how I can connect the Xiaomi gateway to my new router (with new SSID) without resetting and having to add all sensors again?
Can anyone confirm ?You will not lose anything. Reset is not full reset. It keeps the devices and the configuration
martijnm
- Domoticz version: 3.530
You could replace the SSID with your old router's SSID name and apply the same password. All devices who know the SSID and password combination can then login into your new router.mvveelen wrote: Thursday 14 September 2017 22:35 Does anyone know how I can connect the Xiaomi gateway to my new router (with new SSID) without resetting and having to add all sensors again?
- mvveelen
That's not what I want..... SSID and password are changed for a good reason.
pvm
- Domoticz version: 4.10538
Changing SSID should not Ean issue on domoticz side.
I've changed SSID and did set a new gateway code in domoticz (don't remember whether that was required). Without impact on domoticz
xbox2610
Hi everyone I wanted to know if a aqara human body sensor works with the latest version of domoticz (3.8153) or the problem is due to Mi Home application.
Thank you
Thank you
Swifty
Indeed - you do not need to re-add all the devices.chatainsim wrote: Friday 15 September 2017 12:07I've found this :mvveelen wrote: Thursday 14 September 2017 22:35 Does anyone know how I can connect the Xiaomi gateway to my new router (with new SSID) without resetting and having to add all sensors again?Can anyone confirm ?You will not lose anything. Reset is not full reset. It keeps the devices and the configuration
I did this on my two gateways recently, all I had to do was re-enable the lan option of the gateway via the xiaomi app, then re-enter the password in domoticz.
chatainsim
Nice! Thank you.Swifty wrote: Friday 15 September 2017 18:12Indeed - you do not need to re-add all the devices.chatainsim wrote: Friday 15 September 2017 12:07I've found this :mvveelen wrote: Thursday 14 September 2017 22:35 Does anyone know how I can connect the Xiaomi gateway to my new router (with new SSID) without resetting and having to add all sensors again?Can anyone confirm ?You will not lose anything. Reset is not full reset. It keeps the devices and the configuration
- mvveelen
Check. Did the reset and everything's fine. Connected to the new SSID and happy I didn't have to add all sensors again
I'm running the latest beta version of Domoticz (3.8394) using the Xiaomi gateway. Temperature, motion and door/window sensor are working fine within domoticz, but the Smoke detectors do not change state when I test the detectors (when I hold the test button on the smoke detector).
i'm using the Xiaomi mijia Honeywell Fire Alarm Detector. See https://xiaomi-mi.com/sockets-and-senso ... tor-white/
I see the following entry in the log:
It seems that the smoke detector message is received by domoticz, but not parsed? The log of the switch stays empty.
Does anyone have an idea how to fix this?
Thanks in advance.
2017-09-16 15:54:50.913 {"cmd":"report","model":"smoke","sid":"158d00015b01b6","short_id":50435,"data":"{\"density\":\"1\"}"}Does anyone have an idea how to fix this?
Thanks in advance.
deennoo
domoticz is waiting for an alarm message, not a density one, test button just run a test, device doesn't send alarm.
Try it on real smoke, device & gateway will warn, and domoticz will be informed
http://domo-attitude.fr
jackderuiter
Sorry it might have passed the last 96 pages and searching on v3 is a too short phrase
. what are the differences between the V2 and V3 gateway? Both integrate good in domoticz?
