Which ios version do you use ?? I notice that from the 11.x beta I have problems. At 10.x everything will work properly.SwordFish wrote:I have been using this not for a while and i thought lets use it again. But i have everything setup but it won't send me notification when a leave the house or coming home and the switch also don't get triggerd. I have the paid version and can access domoticz from the outside whit Pilot.
Is there something i'm doining wrong?
Pilot: Home Automation Control (iOS app)
Re: Pilot: Home Automation Control (iOS app)
- Domoticz version: V4.11375
I solved it. Had removed pilot from the phone (10.3.3) and installed it again. Now its all working.bing69 wrote:Which ios version do you use ?? I notice that from the 11.x beta I have problems. At 10.x everything will work properly.SwordFish wrote:I have been using this not for a while and i thought lets use it again. But i have everything setup but it won't send me notification when a leave the house or coming home and the switch also don't get triggerd. I have the paid version and can access domoticz from the outside whit Pilot.
Thanks for the reply.
Only one thing, is it possible to narraw the radius in a update? I like the idea to have a 10 to 20 meter radius around the house.
it's a little bit more, i think about 70 'a 80 meterSwordFish wrote:I solved it. Had removed pilot from the phone (10.3.3) and installed it again. Now its all working.bing69 wrote:Which ios version do you use ?? I notice that from the 11.x beta I have problems. At 10.x everything will work properly.SwordFish wrote:I have been using this not for a while and i thought lets use it again. But i have everything setup but it won't send me notification when a leave the house or coming home and the switch also don't get triggerd. I have the paid version and can access domoticz from the outside whit Pilot.
a 10/20m radius would kill battery life, so I had to make it a bit wider!SwordFish wrote:I solved it. Had removed pilot from the phone (10.3.3) and installed it again. Now its all working.bing69 wrote:Which ios version do you use ?? I notice that from the 11.x beta I have problems. At 10.x everything will work properly.SwordFish wrote:I have been using this not for a while and i thought lets use it again. But i have everything setup but it won't send me notification when a leave the house or coming home and the switch also don't get triggerd. I have the paid version and can access domoticz from the outside whit Pilot.
https://d.pr/i/rD1KoCDynamic wrote:I'm very interested as an early Pilot-user, but the screenshot doesn't work anymore?
There you go, with a fresh look (still such an early build, don't mind the bloat).
Domoticz on iOS: Pilot: Home Automation Control
Hi Patoo,since a week the localization icon on the status bar is always active. If i remove localization permission on Pilot the icon disappears. Apply to both the beta and the app store version.
Do you have an idea for this?
The icon is not full, there are only the outlines
Hi Andree,Andree wrote: ↑Saturday 19 August 2017 20:40 Hi Patoo,since a week the localization icon on the status bar is always active. If i remove localization permission on Pilot the icon disappears. Apply to both the beta and the app store version.
It is always been this way
outlined location icon means that the geofencing is activated.
Mmmm...use pilot since 6/7 month but only from last week the icon remain active for 24h!
Even the weather app use the localization but the icon not remain always active!
What is the version of iOS you're using?
Sorry,i cant see the message..
Same problm with iPhone 6s iOS 10.2 and iPhone 7 iOS11b7.
@all...I'm the only one have this problem?
Hi everyone,
I am looking for people to beta-test the incoming version of Pilot. Should be out in a day or 2!
Would help if you are already using the latest beta of iOS 11 (or GM).
Cheers mates
Cheers mates
- gielie
- Domoticz version: latest β
Im on the gm, i would test it for you.
- Aeotec MultiSensor 6
- FIBARO FGS223
- FIBARO FGWPE Wall Plug
- Neo CoolCam Power plug
- Popp Smoke Detector
- Toon
- Kodi Media Server
- FIBARO FGS223
- Toon
- Kodi Media Server
Good Can you PM me the email address associated to your apple ID?
And me too. You should have my ID already.
Do you recieve my Pm??
Hi patoo i'm beta tester for the previus beta.
I'm glad to try the new beta,iPhone 7 11GM and iPhone 6s with 10.3.3!
It's possible?
It's possible?
Yes don't worry, I also got your PM
Getting a bit longer than usual, hope to have the beta ready as soon as possible.
Yep,ok!patoo77 wrote:Yes don't worry, I also got your PM
I'm wait,thank you so much!
Funny thing happened, Apple reviewed the AppStore version before the beta version. XD
I am pleased to let you all know that Pilot 2.2 is now available.
It brings full support for iOS 11, and has a pretty new text search field so that you can filter your devices.
Let me know how it goes!
I am still planning to do a beta, but it should be for the next big release of Pilot (2.3).
Don't forget to leave a review on the App Store if you enjoy this app!
My iPhone SE running latest iOS 10 had updated the app and now it won't start anymore (the splash screen comes up for a second or two). Tried to restart the phone, but would not like to reinstall the app as I have reorganized all the devices which was a huge work. Also updating to iOS 11 is not an option until I verify that it doesn't break anything critical.
Is there something I could do, for example is there some crash report somewhere I could send to you for reference?
