Custom signal
iLLiac4
Custom signal
Post by iLLiac4 »
I want to send a custom signal to one doorbell since recording the switch does not transmit the right signal.
I can trigger the doorbel with rfxmngr and now i want to add this signal as button. Is this possible at all?
Lighting4 command
Packettype    = Lighting4
subtype       = PT2262
Sequence nbr  = 74
Code          = 030000 decimal:196608
S1- S24  = 0000 0011 0000 0000 0000 0000
Pulse         = 234 usec
Signal level  = 0  -120dBm
Packettype        = Receiver/Transmitter Message
subtype           = Transmitter Response
Sequence nbr      = 74
response          = ACK, data correct transmitted
