Setting up the hardware works ok, in the device section I see among others
1. Temp + Humidity + Baro followed by the sensor types THB1 - BTHR918, BTHGN129 and the data 10.4 C, 98 %, 993 hPa.
Adding this device to the dashboard I would expect to see these three values, or not ?
What I see, is the 993 hPa only plus a rain prediction.
What do I have to do to see all three values from that device.
Checking the forecast I always get a location in Oslo, even when I added my own location when creating the WU hardware device
2. Adding the REMOT-ZXT-120 gives me :
6 devices, 1 for heating, 1 cooling, 1 for mode, 1 for fan, 2 unused
Acting the heating and cooling devices does work, but they do not remember the settings, i.e. they stay as zero
The fan and mode does not do anything.
What do I have to do here to make that work ?
Ideally the result would be a device on the dashboard with all the entries.
Weather Underground / Remotec ZXT
Re: Weather Underground / Remotec ZXT
The WU problem :
Regardless what I use as 'Location' in the hardware definiton ( either something like IROGALAN46 or pws:IROGALAN46 or just a cityname ),
I get messages : WUnderground: Error: No cities match your search query.
The Remotec issue is still there.
