[MyDomoAtHome] Support thread
journeyman
Re: [MyDomoAtHome] Support thread
Post by journeyman »
I Have Working Mydomoathome.
My problem is that my Domoticz is growing up, its already around 300devices. Part of them is virtual for events purpuse and I dont need them in imperihome.
I would like to create separete user for mydomoathome to make it lighter and work faster.
For now in Domoticz im allowing all devices from 127.0.0.1 without login.
When im turning this option off, or changing config of mydomoathome
 from      "host": "127.0.0.1", to 192.168.2.200 (my RBP IP)
And try with authentication
  "app_name": "MyDomoAtHome",
        "auth": { "username": "xxx", "password": "xxx" },
   "domoticz": {
        "ssl": false,
        "port": "8080",
	"path": "/",
        "username": "xxx",
	"password": "xxx"
  "port": 2742,
  "passcode": ""
I'm getting:
{"devices":[{"id":"S00","name":"Unable to connect to Domoticz","type":"DevGenericSensor","room":"Utility","params":[{"key":"Value","value":"http://127.0.0.1:8080/json.htm"}]},{"id":"S01","name":"Please add this gateway in Setup/settings/Local Networks","type":"DevGenericSensor","room":"Utility"}]}
What is wrong?
epierre
Post by epierre »
Hi All,
I've been away a bit it seems ;-)
First the repository has moved to https so upgrade your apt source list with https on the url (see wiki).
There's been a lot of questions here, yesterday I released 0.2.11 with fixes for shutters. I would suggest you test this version and tell me if this issue still exist.
For any issues remaining, can you point your post or better open a ticket on github ? https://github.com/empierre/MyDomoAtHome/issues
Many thanks !
ImperiHome & MyDomoAtHome on top of:
868.42Mhz - Vera Lite - Fibaro SS-101, S-211, K-101, FWP - Fortress SSA2
433Mhz - Cubie Domoticz + RFXtrx + Oregon || Foscam 9821W
2,4Ghz - Cubie MySensors Gateway + COV + TempHumidity + Pressure + WaterMeter
epierre
Post by epierre »
sisaenkov wrote: Wednesday 31 May 2017 8:25 Hello.
Got this error after MDAH start:
May 31 09:19:04 pi MDAH[7508]: info: Domoticz server: http://127.0.0.1:8080/json.htm
May 31 09:19:04 pi MDAH[7508]: info: Node version: 6.10.3
May 31 09:19:04 pi MDAH[7508]: info: MDAH version: MyDomoAtHome 0.2.8
May 31 09:19:04 pi MDAH[7508]: info: OS version: Linux linux 4.4.46-v7+
May 31 09:19:04 pi MDAH[7508]: info: Hostname: pi 172.16.1.31 in /root /usb/mydomoathome
May 31 09:19:04 pi MDAH[7508]: info: MDAH port: 3002
May 31 09:19:05 pi MDAH[7508]: /usb/mydomoathome/app/mdah.js:427
May 31 09:19:05 pi MDAH[7508]: params.push({"key": "Value", "value": ret[lvl].toString()});
May 31 09:19:05 pi MDAH[7508]: ^
May 31 09:19:05 pi MDAH[7508]: TypeError: Cannot read property 'toString' of undefined
May 31 09:19:05 pi MDAH[7508]: at DevMultiSwitch (/usb/mydomoathome/app/mdah.js:427:51)
May 31 09:19:05 pi MDAH[7508]: at Request._callback (/usb/mydomoathome/app/mdah.js:2406:45)
May 31 09:19:05 pi MDAH[7508]: at Request.self.callback (/usb/mydomoathome/app/node_modules/request/request.js:200:22)
May 31 09:19:05 pi MDAH[7508]: at emitTwo (events.js:106:13)
May 31 09:19:05 pi MDAH[7508]: at Request.emit (events.js:191:7)
May 31 09:19:05 pi MDAH[7508]: at Request.<anonymous> (/usb/mydomoathome/app/node_modules/request/request.js:1067:10)
May 31 09:19:05 pi MDAH[7508]: at emitOne (events.js:101:20)
May 31 09:19:05 pi MDAH[7508]: at Request.emit (events.js:188:7)
May 31 09:19:05 pi MDAH[7508]: at IncomingMessage.<anonymous> (/usb/mydomoathome/app/node_modules/request/request.js:988:12)
May 31 09:19:05 pi MDAH[7508]: at emitNone (events.js:91:20)
May 31 09:19:05 pi MDAH[7508]: error: Forever detected script exited with code: 1
May 31 09:19:07 pi MDAH[7508]: error: Script restart attempt #10
looks like it is linked to your evice encoding, is that utf8 ? (russian) ?
epierre
Post by epierre »
sundansx wrote: Friday 09 June 2017 8:38 Ok, figured out my problem above: MyDomoAtHome does not support door locks (DevLock in API)...it rolls them in with door and windows sensors. I changed the .js to support locks and now Imperihome brings up the correct icon and button/state widget. Working great now. If anyone else is fighting this, let me know and I will submit a patch...heck I might submit a patch anyway.
The fact that no one replied to my post suggests that this middleware is not very popular - Door locks flat out do not work at all on current GIT code.
very few have a door lock in fact ;-)
I'm interrested by it (patch) of course !
epierre
Post by epierre »
nizaga wrote: Sunday 09 July 2017 18:36 Hi!
I am trying to add TWO domoticz to imperihome via IIS but it seems not to be possible, right?
I can add system 1 without any problem (imperihome latest running on IOs iphone latest), I can add system 2 without any problem but both can't run together.
System 1 is running on RPI2 latest domoticz stable, system 2 is running latest beta.
I want to have two systems since some features are not able yet in the stable and i don't want to update my production system.
So, is it possible to run two domoticz in imperihome via IIS?
right now no, or I should rewrite a lot to memorize which system the data is from, a bit of work ! better running MDAH on two sepearate ports, one for each system, and give both url to imperihome that will merge both so it will work as you wanted
epierre
Post by epierre »
febalci wrote: Saturday 15 July 2017 0:16 Hi,
aside from 2 issues, mydomoathome works perfectly in my installation. The problems are:
1. Using ZWave flush shutter modules. I set up them in domoticz as "Blinds Percentage Inverted". In imperihome i can see them with only up and down buttons, no dimmer like slider. So i can only open or close the shutters, not make a percentage value.
2. Using Sony Bravia plugin. Sony Bravia 4K Status switch is a TV icon Media Player" switch where i can switch the TV on and off. However this item doesnot transfer to Imperihome, it is simply missing. The volume and source buttons are working OK.
Can anyone help? Thanks...
can you give me the concerned device for :
http://domoticz_ip:8080/json.htm?type=devices&filter=all&used=true&order=Name
epierre
Post by epierre »
gerardosamara wrote: Thursday 03 August 2017 15:44 Hi , Before installing the Imperihome GW MyDomoAtHome in the new stable Domoticz release 8153 on last raspbian jessie , I looked a the related Wiki part
https://www.domoticz.com/wiki/ImperiHome
=> The wiki has to be updated
looks like you reported things in github, is the wiki correct now ?
epierre
Post by epierre »
journeyman wrote: Thursday 24 August 2017 14:00 Hello,
   "domoticz": {
        "ssl": false,
        "port": "8080",
	"path": "/",
        "username": "xxx",
	"password": "xxx"
  "port": 2742,
  "passcode": ""
you need this also for domoticz password: "auth": { "username": "admin", "password": "admin" } (and thus no "username": "xxx",
"password": "xxx" )
sisaenkov
Domoticz version: 3.8
Post by sisaenkov »
epierre wrote: Friday 01 September 2017 15:57 looks like it is linked to your evice encoding, is that utf8 ? (russian) ?
I don't remember how I fix it.
epierre
Post by epierre »
zes00 wrote: Thursday 16 February 2017 21:03 Hi.
Does anyone know why some of my devices show up as "no group" in the imperihome app? Seems to be only the "dimmer" devices in domoticz that isnt recognized as a switch/dimmer in imperihome. the "no group" tab isnt in my IOS app(only scenes, switches and utility), so its kinda annoying only being able to access my devices from android(which I do not use).
is there something I could have done wrong when setting up domoticz/MDAH gateway? what could I try to do to fix this?
As I can't create a virtual dimmer I can't reproduce your issue unless I have your domoticz.db
Looked at the code this should work, can you update to latest versions and tell me, if not I do need your domoticz.db sent to [email protected]
thanks
journeyman
epierre wrote: Friday 01 September 2017 16:06
   "domoticz": {
        "ssl": false,
        "port": "8080",
	"path": "/",
        "username": "xxx",
	"password": "xxx"
  "port": 2742,
  "passcode": ""
"password": "xxx" )
I know, in my config i have real login ang password (no xxx) but its still not working.
epierre
Post by epierre »
@journeyman no the semantic is:
"domoticz": {
"ssl": false,
"port": "8080",
"path": "/",
"port": 2742,
"passcode": ""
febalci
Post by febalci »
epierre wrote: Friday 01 September 2017 16:02
Thanks for the help. Using 0.2.15 now, the problem still exists. You can find below the results:
1. Example for one of the shutters:
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"BatteryLevel" : 255,
"CustomImage" : 0,
"Data" : "Closed",
"Description" : "",
"Favorite" : 0,
"HardwareID" : 16,
"HardwareName" : "Home ZWave",
"HardwareTypeVal" : 21,
"HaveDimmer" : true,
"HaveGroupCmd" : true,
"HaveTimeout" : false,
"ID" : "00000201",
"Image" : "Light",
"IsSubDevice" : false,
"LastUpdate" : "2017-08-29 09:18:04",
"Level" : 0,
"LevelInt" : 0,
"MaxDimLevel" : 100,
"Name" : "Sinema Panjur",
"Notifications" : "false",
"PlanID" : "3",
"PlanIDs" : [ 3 ],
"Protected" : false,
"ShowNotifications" : true,
"SignalLevel" : "-",
"Status" : "Closed",
"StrParam1" : "",
"StrParam2" : "",
"SubType" : "Switch",
"SwitchType" : "Blinds Percentage Inverted",
"SwitchTypeVal" : 16,
"Timers" : "false",
"Type" : "Light/Switch",
"TypeImg" : "blinds",
"Unit" : 1,
"Used" : 1,
"UsedByCamera" : false,
"XOffset" : "0",
"YOffset" : "0",
"idx" : "138"
2. Sony TV Status:
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"CustomImage" : 2,
"Data" : "Off",
"Description" : "",
"Favorite" : 1,
"HardwareID" : 4,
"HardwareName" : "Sony Bravia 4K TV",
"HardwareType" : "Sony Bravia TV (with Kodi remote)",
"HardwareTypeVal" : 94,
"ID" : "00040001",
"Image" : "TV",
"LastUpdate" : "2017-09-03 22:18:06",
"Level" : 0,
"LevelInt" : 0,
"MaxDimLevel" : 15,
"Name" : "Sony Bravia 4K TV - Status",
"PlanID" : "0",
"PlanIDs" : [ 0 ],
"Status" : "Off",
"StrParam1" : "",
"StrParam2" : "",
"SubType" : "AC",
"SwitchType" : "Media Player",
"SwitchTypeVal" : 17,
"Timers" : "false",
"Type" : "Lighting 2",
"TypeImg" : "Media",
"Unit" : 1,
"Used" : 1,
"XOffset" : "0",
"YOffset" : "0",
"idx" : "38"
sylar
Domoticz version: 4.10311
Post by sylar »
Hello there. I'm a new user of MyDomoAtHome. For now, almost everything is working well, except some devices are missing: some temperature/humidity sensors, switches, do not appear in Imperihome, while being visible on http://NAS_IP:3002/devices. I'm using the docker image on a Synology NAS.
epierre
Post by epierre »
sylar wrote: Monday 04 September 2017 21:33 Hello there. I'm a new user of MyDomoAtHome. For now, almost everything is working well, except some devices are missing: some temperature/humidity sensors, switches, do not appear in Imperihome, while being visible on http://NAS_IP:3002/devices. I'm using the docker image on a Synology NAS.
I fear the docker image to be very old...
epierre
Post by epierre »
@febalci the DevShutter only have stoppable or pulsable with a percentage.
I would need this device in open or intermediary position to see what to use.
Also what action do domoticz propose for it ?
for the Media Player, what do you expect here ? ISS definition is for playing music, I would need the data in different position.
Remember here you can interface a kodi diretly from imeprihome.
epierre
Post by epierre »
I can't understand why you would have this issue, can you update to a recent version and recheck ?
febalci
Post by febalci »
epierre wrote: Wednesday 06 September 2017 21:52 @febalci the DevShutter only have stoppable or pulsable with a percentage.
Remember here you can interface a kodi diretly from imperihome.
Dear epierre,
For the shutters, since am using "Blinds Percentage Inverted" it exists in Domoticz like this:
At the moment in Imperihome i see this:
As you see it is only open or close, no place to set percentage or stop the blinds.
If i set it to "Venetian Blinds EU", in imperihome stop button also comes into view, but since there's no inverted type of Venetian blinds in Domoticz, open means close, close means open which confuses me a lot.
Maybe when transferring "Blinds Percentage Inverted" option to Imperihome, the percentage value could be used like it is in the next visual where i could use it for the Volume of TV:
For the reference, the open, half closed and closed modes of the shutter gives these:
 OPEN
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "CustomImage" : 0,
         "Data" : "Open",
         "Description" : "",
         "Favorite" : 0,
         "HardwareID" : 16,
         "ID" : "00000C01",
         "Image" : "Light",
         "LastUpdate" : "2017-09-08 07:00:30",
         "Level" : 100,
         "LevelInt" : 100,
         "Name" : "Ebeveyn Panjur",
         "PlanID" : "3",
         "PlanIDs" : [ 3 ],
         "Status" : "Open",
         "StrParam1" : "",
         "StrParam2" : "",
         "Timers" : "true",
         "Unit" : 1,
         "Used" : 1,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "171"
	  HALF-CLOSED
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "CustomImage" : 0,
         "Data" : "Set Level: 50 %",
         "Description" : "",
         "Favorite" : 0,
         "HardwareID" : 16,
         "ID" : "00000C01",
         "Image" : "Light",
         "LastUpdate" : "2017-09-08 10:25:46",
         "Level" : 50,
         "LevelInt" : 50,
         "PlanID" : "3",
         "PlanIDs" : [ 3 ],
         "Status" : "Set Level: 50 %",
         "StrParam1" : "",
         "StrParam2" : "",
         "Timers" : "true",
         "Unit" : 1,
         "Used" : 1,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "171"
	  CLOSED
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "CustomImage" : 0,
         "Data" : "Closed",
         "Description" : "",
         "Favorite" : 0,
         "HardwareID" : 16,
         "ID" : "00000C01",
         "Image" : "Light",
         "LastUpdate" : "2017-09-08 10:26:46",
         "Level" : 0,
         "LevelInt" : 0,
         "PlanID" : "3",
         "PlanIDs" : [ 3 ],
         "StrParam1" : "",
         "StrParam2" : "",
         "Timers" : "true",
         "Unit" : 1,
         "Used" : 1,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "171"
And as for the Sony Bravia, i set the mode to "On/Off" in Domoticz, since i do not use the Kodi Remote and all works well now.
Thank you once again for your support...
epierre
Post by epierre »
@febalci as I see it I should add a special case on "HaveDimmer" : true else on close I cannot see if there are other actions.
BTW I did not see the images you sent => you can send them to [email protected] so I can see what you have in DZ.
Ok will do for the bravia someting on that. IH proposes listing media, play/stop.... so many things that I don't even know if domoticz handles it in fact...
BTW you can also use the ticket I made for you : https://github.com/empierre/MyDomoAtHome/issues/149
febalci
Post by febalci »
epierre wrote: Friday 08 September 2017 10:05 @febalci as I see it I should add a special case on "HaveDimmer" : true else on close I cannot see if there are other actions.
Thanks, for the images i corrected the links in the forum them and sent it to your email.
