email thermostat value problem
Nomader
Post by Nomader »
i am trying to send an email whenever the thermostat changes state, i use the following:
commandArray[1]={['SendEmail']='Thermostat_value_has_changed# My new setpoint is {{utilitydevice[245]}} degrees #[email protected]'}
the email is sent ok but all i get is:
and not the actual value.. the idx is correct
i also tried
{{temperaturedevice[245]}}
but no luck either
SweetPants
Re: email thermostat value problem
Post by SweetPants »
You need to construct the message the LUA way. Google is your friend.
Hint, you have to concatenate strings/values like <string> .. <value as string> .. <string>.\
What happens if you print {{utilitydevice[245]}}, what do you see in the log?
