Xiaomi Air Purifier 2
mozo78
Re: Xiaomi Air Purifier 2
Post by mozo78 »
Julz wrote:Hi all,
I'm having trouble getting the bash script to feed updates via JSON to my Raspberry Pi. I can trigger the bash script manually and it seems to update the temperature sensor and PM2.5 sensor values the first time but then the temperature sensor updates to 0.0C and the PM2.5 sensor doesn't update again. I'm pretty sure I've set up the script to trigger at boot via a call to my 'startup.sh' script in my /etc/rc.local but after bootup is complete, doing a 'screen -list' doesn't show any sessions running unlike when I manually execute my startup.sh. Any suggestions?
TIA!
I had the same problem, but this helped me:
http://raspberrypituts.com/raspberry-pi ... planation/
ToneStrife
Post by ToneStrife »
I have miiio working, I want to use the Wifi plugs.
I have read about power-plug and power-switch in the miio wiki but I don't know which commando should I use.
Anyone with an adapted script for the plugs can help me? I have the IPs but after that I'm a little bit stucked.
DAVIZINHO
Post by DAVIZINHO »
I have a synology NAS with Node.js v4 because i don´t know how to upgrade to v6 :-(
I run this comand: "miio --discover --sync" and obtain this error:
[code]
admin@synology:~$ miio --discover --sync
/usr/local/lib/node_modules/miio/cli/index.js:10
const { Browser, Devices } = require('../lib/discovery');
SyntaxError: Unexpected token {
at exports.runInThisContext (vm.js:53:16)
at Module._compile (module.js:373:25)
at Object.Module._extensions..js (module.js:416:10)
at Module.load (module.js:343:32)
at Function.Module._load (module.js:300:12)
at Function.Module.runMain (module.js:441:10)
at startup (node.js:140:18)
at node.js:1043:3
admin@synology:~$
[/code]
any idea??
thanks a lot and sorry for my poor english :-(
DAVIZINHO
Post by DAVIZINHO »
hello,
Its imposible to me make this works in:
- synology: I cant upgrade the node.js :-(
- raspberry pi zero: the miio not works :-(
But it works perfect for me in a raspberry pi2 with raspbian!! :-D
Andree
Post by Andree »
hi,there's a way to making this work on Windows?
tho071088
Domoticz version: Stable
Post by tho071088 »
I'm having some problems :
This works :
/var/domoticz/scripts/external/xiaomiAirPurifierControl.sh 192.168.0.55 off
sudo /var/domoticz/scripts/external/xiaomiAirPurifierControl.sh 192.168.0.55 off
This does not work :
Pushing the button on Domoticz
I don't have any errors thrown in the log.
Capture d’écran 2017-10-22 à 20.13.53.png (98.92 KiB) Viewed 6571 times
Capture d’écran 2017-10-22 à 20.13.28.png (14.76 KiB) Viewed 6571 times
Any ideas ?
Thanks for your help :)
Domoticz Beta on Rasbperry Pi 3
RFLink / YeeLight / Xiaomi Devices / 433MHz / SonOff via MQTT
tho071088
Post by tho071088 »
New problem for me :
Domoticz:/var/domoticz/scripts/external/xiaomiAirPurifier.js 192.168.0.55 power off
Sending Power off command
(node:21561) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 1): SyntaxError: Unexpected token o in JSON at position 0
No idea what to do with this.
Any advise ?
tho071088
Post by tho071088 »
All solved
tho071088 wrote: Tuesday 24 October 2017 22:45 New problem for me :
Any advise ?
This one was my fault, wrong command sent.
For the other one, I had to make the require this way :
Not working :
const miio = require('miio');
Working :
const miio = require('../../../../usr/lib/node_modules/miio');
MsbS
Post by MsbS »
tho071088 wrote: Wednesday 25 October 2017 6:41 For the other one, I had to make the require this way :
Not working :
Working :
Could you replace the relative path ('../..') with a single / ? Basically :
const miio = require('/usr/lib/node_modules/miio');
For me the script from the first post does nothing - I ran the miio sync command (got no output), when I run the examples with 'node airpurifier.js IP command', nothing happens.
tho071088
Post by tho071088 »
MsbS wrote: Wednesday 25 October 2017 14:36
Not working :
Working :
No, just a / will not work, already tried
If nothing is displayed, you have to add some lines to the JS file.
process.on('uncaughtException', function (error) {
console.log(error.stack);
Andree
Post by Andree »
Sorry, there is no way for Windows?
MsbS
Post by MsbS »
tho071088 wrote: Wednesday 25 October 2017 14:42 If nothing is displayed, you have to add some lines to the JS file.
Unfortunately, this did not help. I think there's something wrong with node or with miio in my case.
- when I tried 'npm install --save miio', I got a whole lot of errors.
- doing this with sudo ('sudo npm install --save miio') worked, but I still got warning about the version of node:
wanted: {"node":">=6.0.0"} (current: {"node":"4.8.2","npm":"1.4.21"})
- When I run 'miio --discover --sync', it gives me no output at all, where can I find a logfile to check what went wrong?
tho071088
Post by tho071088 »
MsbS wrote: Thursday 26 October 2017 9:31
You have to update node a new version.
Try
sudo apt-get update && sudo apt-get upgrade && sudo apt-get install node
Are you on Raspbian Jessie ?
MsbS
Post by MsbS »
tho071088 wrote: Thursday 26 October 2017 9:47 You have to update node a new version.
Try
I'm on Raspbian Stretch - the newer one. Did update, upgrade, install. I get: 'node is already the newest version (0.3.2-7.4).'
tho071088
Post by tho071088 »
MsbS wrote: Thursday 26 October 2017 10:17
Try
I'm on Jessie and node 6, there is maybe an issue with miio and node 7.
This is outside of my skills, sorry.
MsbS
Post by MsbS »
OK, I think I have this sorted out. I'll leave it here for others who can be struggling.
The key was to install the correct version of nodejs, as per this page:
https://nodejs.org/en/download/package- ... tributions
So, running:
curl -sL https://deb.nodesource.com/setup_6.x | sudo -E bash -
sudo apt-get install -y nodejs
DAVIZINHO
Post by DAVIZINHO »
hello.
what kind of virtual sensors you create for aqi?
i can obtain the aqi data but not works the update to domoticz comand. allways 0 :-(
curl -s "http://192.168.1.4:8080/json.htm?type=c ... alue=${aqi}"
any idea?
tho071088
Post by tho071088 »
DAVIZINHO wrote: Friday 03 November 2017 19:17 hello.
any idea?
Custom Sensor type worked for me
DAVIZINHO
Post by DAVIZINHO »
tho071088 wrote: Friday 03 November 2017 20:44
any idea?
Works! thanks!
MsbS
Post by MsbS »
My Purifier (using the script from this thread) sometimes sends strange values to the T+H IDX (temperature 0, humidity 0). Did anyone have similar issue? For now, I added an 'if', which does not send the 0/0 data, but maybe there is a better fix.
The aqi reading is correct, no strange values (unless the reading of 10 aqi means broken data - I get that a lot).
