dzVents set dimmer level
Pappabear
Post by Pappabear »
I'm very new to domoticz and dzvents.
I have a Fibaro motion sensor and a Fibaro dimmer.
I'm already able to switch the light on and off after motion during nighttime but I would love to set the level of the dimmer with dzVents
(as you would do with a "level xx %" block in blocky), any ideas? I tried several things but nothing is working
local LichtHal = domoticz.devices('Licht hal')
		if (timeofday['Nighttime']) then
			if (switch.state == 'On') then
--->				LichtHal set level dimmer
				LichtHal.switchOn()
				LichtHal.switchOff()
Tnx,
Luc
elmortero
Domoticz version: 3.9639
Re: dzVents set dimmer level
Post by elmortero »
you are looking for this:
then
LichtHal.switchSelector(TheLevelYouWantTOSetItTo) --> the level is Numeric
It is explained in the dzVents Wiki
Pappabear
Post by Pappabear »
tnx for the reply
I already managed to do it now with LichtHal.dimTo(percentage)
This probably didn't work before because I used the wrong device name :-(
