TOON died within Domoticz
Maglor
Re: TOON died within Domoticz
OK... I was also having some issues with the connection... and for me, it came suddenly.
But then I remembered I changed my password to a stronger one.
Looks like the connection can't be set up if you are using special characters in the password. (or 16 characters is to much).
I changed the password to a 12 characters A-Z a-z 0-9 one, and it worked perfectly.
Just wanted to throw it in here, Maybe it helps some people or the developer to troubleshoot.
- EdwinK
- Domoticz version: BETA
Thanks. Unfortunately no solution for me.
- Mooseknuckle
Thanks for the tip but also no luck for me. The stupid thing is that when I stop en start Toon in the hardware tab it works but only once, after that I get "error login". I'm glad setting the setpoint still works from Domoticz.
RPI 3, Philips Hue,Toon Thermostat, Harmony Smart Control, Yeelights
Mysensors wifi gateway + sensors, RFXtrx433E, Kaku stuff, Xiaomi gateway + sensors
Domoticz controlled DIY ambilight, Selectplus chime, Mi-light led controller
SteGe
Nope, had the hope this was working for me, but unfortunately it didn't.... Really hope that some developer want to implement the API of Toon in Domoticz....
Synology DS3615xs | Raspberry pi 3b |
RFXtrx433E | MySensors | Z-wave | Philips Hue | Ikea Tradfri |
Sunscreen | Power switches | Toon | Harmony | UE Smartradio |
Weatherstation | Doorbell | Letterbox reader | Lux | Temp | Humidity | Motion |
- EdwinK
I hope so too, but seeing the agreement, you can only get around 1.000 users, after that you need to pay Quiby/Eneco. I've asked the developer of Domticz about this earlier.
dressie
- Domoticz version: V2020.2
My logfile is filled with this:
2017-08-03 22:10:16.134 Error: ToonThermostat: retrieveToonState request not successful, restarting..!
2017-08-03 22:16:49.126 Error: ToonThermostat: retrieveToonState request not successful, restarting..!
2017-08-03 22:23:22.323 Error: ToonThermostat: retrieveToonState request not successful, restarting..!
Everything works though, controlling it and receiving power and gas usage updates. Does this still got to do with the max of 1000?
- EdwinK
Nope. The max. of 1000 users is for the new API that Eneco uses. Your error is something else, but... if things are working, I wouldn't touch it.
Plantje
Hey... did you get rid of your Toon? As I see it is striked through
- EdwinK
Nope, still have it, but since it doesn't work with Domoticz anymore. Until it's working again, I keep it striked through.
Plantje
Understandable. I hardly ever use my Toon. Perhaps that will increase again as soon as it becomes winter.
I hope domoticz will be able to pull in the weekly program as well
- EdwinK
Plantje wrote:Understandable. I hardly ever use my Toon. Perhaps that will increase again as soon as it becomes winter.
Toon is off here as well. I hope before winter comes that Toon and Domoticz work again
tlpeter
Did you ever fix this as i have the same.dressie wrote: Thursday 03 August 2017 22:33 My logfile is filled with this:
Toon works (installed yesterday) but i want to know why this is happening.
dressie
Nope, my logfiles are still filled with these lines. Everything works, I even re-installed the hardware, but I keep getting these errors.tlpeter wrote: Saturday 12 August 2017 7:33Did you ever fix this as i have the same.dressie wrote: Thursday 03 August 2017 22:33 My logfile is filled with this:
tlpeter
It is a strange error and it looks like it is a Domoticz issue. Maybe too many calls in a certain amount of time.
But if it works then it is fine for me.
Thanks.
Thanks.
Martijn85
- Domoticz version: Stable
I have the same message: Error: ToonThermostat: retrieveToonState request not successful, restarting..!
Also here toon (in Domoticz) is working fine!
- EdwinK
You know what... all of a sudden Toon devices are showing up again!!!
Cause for celebration, or better wait and see
tlpeter
I have only one issue.
In the morning then Toon switches from sleep to whatever is set but in Domoticz it stays on sleep.
I can set it manually form Domoticz or on Toon and then it switches but somehow the first switch from sleep doesn't seem to work.
tlpeter
And it is down again but i cannot even login to mijn eneco anymore.
- EdwinK
Down here too
tlpeter
This must be a login problem as i cannot login to eneco website either.
