I am trying to build a homepage that are made for an old smartphone that will be mounted on the wall.
I want to get current temp from my different temp sensors and perhaps wind and rain sensors as well.
Trying to do this by json but I just get day/month or year and not the just the current value.
Could somebody perhaps help me? Mayby I shall use something else but json?
Show current temp/value on homepage
- Egregius
- Domoticz version: v2024.7
Re: Show current temp/value on homepage
Json should do just fine. Maybe my PHP Floorplan could give you some ideas? Altough, the current version is totally based on using apcu cache together with pass2php.
Main thing to do is put the devices you want in a roomplan and query that with json.
Loop thru the reply to display the stuff.
Cribbe
- Domoticz version: 3.5866
So I must do a roomplan for this? I can´t "just" query current temp by json and print that value on a page?
- Egregius
That's the best way because you then only need one api call.
For one device: /json.htm?type=devices&rid=IDX
For all temp devices: /json.htm?type=devices&filter=temp&used=true
For a roomplan: /json.htm?type=devices&used=true&plan=IDX (IDX of the roomplan)
For all used devices: /json.htm?type=devices&used=true
Cribbe
Well so much I have figured out
But if I for exampel do /json.htm?type=devices&rid=IDX I get a reply with lots of values.
I see that "Temp" is one of them, but I can´t figure out the php code for this to show on my webpage.
For example on the webpage:
Pool - (current temp, json script)
Inside - (current temp, json script)
Outside - (current temp, json script)
- Egregius
Give me few minutes to write some code...
- Egregius
//Lets grab all temp devices
$domoticz=json_decode(file_get_contents('http://127.0.0.1:8080/json.htm?type=devices&filter=temp&used=true'),true);
//Check if we got a result
if($domoticz){
//loop thru the result
foreach($domoticz['result'] as $dom){
//set a variable with the name
$name=$dom['Name'];
//if we have a temp device set a variable with the name of the device with it's value
if($dom['Type']=='Temp')${$name}=str_replace(' C','',$dom['Data']);
//echo some data on the page. Ex alex_temp is the name of a thermometer
echo '<table>
<tr><td>Alex</td><td>'.$alex_temp.' °C</td></tr>
<tr><td>Tobi</td><td>'.$tobi_temp.' °C</td></tr>
<tr><td>Living</td><td>'.$living_temp.' °C</td></tr>
<tr><td>Kamer</td><td>'.$kamer_temp.' °C</td></tr>
<tr><td>Badkamer</td><td>'.$badkamer_temp.' °C</td></tr>
</table>';Code: Select all
Alex 21.1 °C
Tobi 21.1 °C
Living 21.1 °C
Kamer 21.2 °C
Badkamer 21.3 °C
Cribbe
Got it to work, but got stuck on one sensor that is both temp & humidity.
I´ve tried this:
But that give me this as result:
Ute 14.2, 71 % °C
I can´t figure out how to give me the result like this (if it is possible):
Ute 14,2 °C, 72% humidity or something similar
I´ve tried this:
<?php
$domoticz=json_decode(file_get_contents('http://192.168.1.77:8080/json.htm?type=devices&filter=temp&used=true'),true);
if($domoticz){
$name=$dom['Name'];
if($dom['Type']=='Temp + Humidity')${$name}=str_replace(' C','',$dom['Data']);
echo '<table>
<tr><td>Ute</td><td>'.$Ute.' °C</td></tr>
</table>';
Ute 14.2, 71 % °C
