sValues vs Current state - Satel Integra
petecz
I am trying to configure notifications via Pushover for alarm events.
I can only configure notifications for 'Current state' values, not for 'sValues'. What's the difference?
Why there is no 'current state' for few outputs?
How to handle it?
How to handle it?
- domoticz.jpg (26.08 KiB) Viewed 2418 times
- domoticz.jpg (208.48 KiB) Viewed 2422 times
petecz
Re: sValues vs Current state - Satel Integra
Or I need other ideas for configuring notifications.... Only 'Arm partition' works at the moment.
Why 'text device' hasn't any current state, how to rewrite it from sValue?
mivo
not everything works in Blockly. This should work in dzVents scripting:
Complete syntax of domoticz.notify() function is on Wiki: https://www.domoticz.com/wiki/DzVents:_ ... object_API:
active = true,
logging = {
level = domoticz.LOG_INFO,
-- trigger on device with name
devices = {'Text device'}
-- check text value of device
if device.text == 'ON' then
-- log for debugging purpose
domoticz.log('Text is ON')
-- send notification, more parameters available - see Wiki
domoticz.notify('Text is ON')
}My toys:
Raspberry Pi 3 + UPS PIco HV3.0 A Stack
Minibian (Raspbian Jessie) + Domoticz beta
RFLink 433 Gateway, 1wire DS18B20 temp sensors (GPIO)
RaZberry module + 2x Comet Z-Wave + Z-wave socket
Plugins: WeMo Switch, UPS PIco HV3.0A on GitHub
petecz
hey it works thanks!
Two questions:
1) how to make else construction in dzVents
/something like
but it doesn't work
2) Why Pushover is not working, despite the sending is done is logs? /email sending works ok/
Two questions:
/something like
active = true,
logging = {
devices = {'Brak zasilania'}
if device.text == 'On' then
domoticz.log('Brak zasilania')
domoticz.notify('Brak zasilania')
else device.text == 'Off' then
domoticz.log('Powrot zasilania')
domoticz.notify('Powrot zasilania')
mivo
Change else to this - normal LUA syntax, nothing specific to dzVents:
I have no experience with Pushover - do you set it in Setup / Settings / Notifications ? Does it send message when click on Test ?
elseif device.text == 'Off' thenMy toys:
petecz
Ok, priority must be set as default level is no notification on smartphonemivo wrote: Thursday 17 August 2017 8:39 Change else to this - normal LUA syntax, nothing specific to dzVents:I have no experience with Pushover - do you set it in Setup / Settings / Notifications ? Does it send message when click on Test ?Code: Select all
domoticz.notify('Brak zasilania','Informacja z systemu alarmowego',domoticz.PRIORITY_NORMAL)-
mivo
IF..ELSEIF should be enclosed by "end" - complete condition part of your original script should be:
endMy toys:
fantom
Hi.
Please write post about Satel Integra in this task: viewtopic.php?f=17&t=4260
I'm author of this module, and sometimes I may help
Fantom
Fantom
