Dashticz - Install picoreplayer
capman
Post by capman »
freakshock wrote: ↑
Wed Aug 09, 2017 12:22 pm
A possible alternative is using Logitech media server with a Spotify plugin (I use Spotty).
This way you can use a standard mediaplayer block in Dashticz. That way you can use back, stop, play/pause and next buttons.
I also made a selector switch that can choose playlist within Spotty (all manual config unfortunately).
Of course you would need a server to run LMS.
by capman » Wed Aug 09, 2017 7:46 pm
Could you please explain this how to do this ? Thanks.
by pvm » Wed Aug 09, 2017 10:02 pm
Can you open a new topic for this? (Install picoreplayer) more in New topic :)
So I did , open a new topic. :D It's possible to using the Logitech media server with a spotify plugin. Could someone explain how to do this ?
pvm
Domoticz version: 4.10538
Re: Dashticz - Install picoreplayer
Post by pvm »
Picoreplayer website:
https://sites.google.com/site/picoreplayer/home
LMS is Logitech Media Server which is... A media server :)
This comes as optional part of the picoreplayer package. In that media server you can install the spotty plugin which enables you to play Spotify.
The picoreplayer itself is the client of this LMS. You can have multiple clients to one LMS and sync them.
There's also a synology package of LMS.
This should get you going.
More LMS client hardware is available....
The headphone jack of the pi has bad audio quality... I'm using a hifiberry amp
capman
Post by capman »
So do I. I also have a synology nas with LMS installed and 2 raspberry's with hifiberry amp on it. So these are the players. I also have a raspberry with just a screen on where raspian jessie with pixel is running. I use this with dashticz on >> http://www.domoticz.com/forum/viewtopic ... 00#p134385
But what I want now is to control one of my players with dashticz. Tomorrow I try your solution with spotty. It's already installed as a plugin in LMS.
Thanks for the feedback 8-)
pvm
Post by pvm »
Ah, so last step is adding them to dashticz then....
capman
Post by capman »
pvm wrote:Ah, so last step is adding them to dashticz then....
Yes Image , but how that is the question. So if someone can help, please do.
Verstuurd vanaf mijn ONEPLUS A5000 met Tapatalk
freakshock
Post by freakshock »
If you have the LMS players already integrated in Domoticz, adding them to Dashticz is easy.
Just like any other block, define the block and add the idx to a column:
For instance:
blocks[126] = {} //LMS entire house
blocks[126] ['width' ] =8;
columns[2] = {}
columns[2]['blocks'] = [126,1,2]
columns[2]['width'] = 5;
capman
Post by capman »
That was easy ! So now I become this.
How to fine tune it more to become bigger buttons (play, pause,stop,...) ? And to choose from some playlist , favourites ? Maybe albumart ? ;)
@pvm
Is it possible 2 become something like this in Dashticz (it's from your frontpage :) )
http://www.domoticz.com/forum/viewtopic ... ipt#p39828
I have asking this also in the feature request topic.
http://www.domoticz.com/forum/viewtopic ... 60#p134389
freakshock
capman wrote: Saturday 12 August 2017 13:47
That would be nice indeed.
The button size I found out myself and added it to the wiki:
http://www.domoticz.com/wiki/Dashticz_V ... er_buttons
capman
Post by capman »
Super , thanks. Now 4 the other things :D . Maybe that 'pvm' can help ?
pvm
Post by pvm »
I do not have the ability to test now (just moved into a new house, not all home automation is up and running)
You can have a look at the lms web interface and right click, inspect element. It might show you a link to be used on dashticz
EdwinK
Post by EdwinK »
Adding LMS to dashticz? I just copied the IDX number to the column I wanted it to be in
capman
Post by capman »
EdwinK wrote: Sunday 13 August 2017 12:44 Adding LMS to dashticz? I just copied the IDX number to the column I wanted it to be in
Yes, I have this also done. But I want something more than just the button to stop and play etc...(see some post higher). Choose of radiostation or my music collection , and albumart of what is playing would be so much nicer (read cooler) 8-) .
pvm
Post by pvm »
Did you see anything usefully in 'inspect element'?
capman
Post by capman »
Maybe this
<img src="/music/27b0a6ff/cover 96x96 p.png" width="96" height="96">
When I click on it with right mouse and I take 'open adres on another tabpage' , I came to this url
http://192.168.178.29:9002/music/27b0a6ff/cover_96x96_p.png
With show me the albumart from what is playing at the moment.
Where should I put this code "<img src="/music/27b0a6ff/cover 96x96 p.png" width="96" height="96">" in dashticz 2 see the cover ?
Properly in the "custom.js" ? I don't know where 2 start :oops:
pvm
Post by pvm »
The image URL changes with each song...
The link to a favorite playlist possibly does not
MarceldeJongNL
Domoticz version: 3.5108
Post by MarceldeJongNL »
Players:
aa%3Aaa%3A18%3A28%3A8b%3A29
aa%3Aaa%3Aaa%3A76%3A0c%3A4c
Current playing cover:
http://URL:PORT/music/current/cover.jpg?player=aa%3Aaa%3A18%3A28%3A8b%3A29
Gives a JPG with the cover for that player
http://URL:PORT/status.html?player=aa%3Aaa%3Aaa%3A76%3A0c%3A4c
Gives this status page:
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN"
"http://www.w3.org/TR/html4/loose.dtd">
<html>
  <head>
    <title>Squeezebox Music Player RP-N14 </title>
    <link rel="stylesheet" href="/slimserver.css" type="text/css">
    <link rel="stylesheet" href="/skin.css" type="text/css">
  </head>
  <body bgcolor="#FFFFFF">
	<h3>Squeezebox Music Player RP-N14</h3>
  	<form method="get" action="/index.html" target="_top">Current player: <select name="player">
<option selected value="aa:aa:aa:76:0c:4c">RP-N14</option>
<option  value="aa:aa:18:28:8b:29">Woonkamer-Apple-TV</option></select><input class="stdclick" type="submit" value="Change"></form>
   <div id="playingStatus">
    Now Playing
    1 of 10:
   </div>
   <div class="playingSong"><a href="/songinfo.html?item=34247&amp;player=aa%3Aaa%3Aaa%3A76%3A0c%3A4c" target="browser">Bodyrock</a>
    from <a href="/clixmlbrowser/clicmd=browselibrary+items&amp;mode=tracks&amp;linktitle=Album%20(Music%20from%20Porcelain)&amp;album_id=1860&amp;player=aa%3Aaa%3Aaa%3A76%3A0c%3A4c/" target="browser">Music from Porcelain</a>
     by <a href="/clixmlbrowser/clicmd=browselibrary+items&amp;mode=albums&amp;linktitle=Artist%20(Moby)&amp;artist_id=9569&amp;&amp;artwork=1&amp;player=aa%3Aaa%3Aaa%3A76%3A0c%3A4c/" target="browser" class="browseItemLink"><span style="display:inline">Moby</span></a>
    <span class="playingSongControls"><a href="status.html?p0=playlist&amp;p1=delete&amp;p2=0&amp;player=aa%3Aaa%3Aaa%3A76%3A0c%3A4c&amp;start=0"><span>(Delete)</span></a></span>
   </div>
<hr><a href="status.html?p0=playlist&amp;p1=jump&amp;p2=-1&amp;player=aa%3Aaa%3Aaa%3A76%3A0c%3A4c">Prev</a>
<a href="status.html?p0=playlist&amp;p1=jump&amp;p2=%2b1&amp;player=aa%3Aaa%3Aaa%3A76%3A0c%3A4c">Skip</a>
    <b>Play</b>
    <a href="status.html?p0=pause&amp;player=aa%3Aaa%3Aaa%3A76%3A0c%3A4c">Pause</a>
    <a href="status.html?p0=stop&amp;player=aa%3Aaa%3Aaa%3A76%3A0c%3A4c">Stop</a>
<br>Repeat:
<b>off</b>/<a href="status.html?p0=playlist&amp;p1=repeat&amp;p2=1&amp;player=aa%3Aaa%3Aaa%3A76%3A0c%3A4c&amp;start=0">one</a>/<a href="status.html?p0=playlist&amp;p1=repeat&amp;p2=2&amp;player=aa%3Aaa%3Aaa%3A76%3A0c%3A4c&amp;start=0">all</a>
<br>Shuffle:
<b>off</b>/<a href="status.html?p0=playlist&amp;p1=shuffle&amp;p2=1&amp;player=aa%3Aaa%3Aaa%3A76%3A0c%3A4c&amp;start=0">songs</a>/<a href="status.html?p0=playlist&amp;p1=shuffle&amp;p2=2&amp;player=aa%3Aaa%3Aaa%3A76%3A0c%3A4c&amp;start=0">albums</a>
<br>
    Player:
               <b>on</b>/<a
               target="_top" href="index.html?player=aa%3Aaa%3Aaa%3A76%3A0c%3A4c&amp;p0=power&amp;p1=0">off</a>
<br><br>
Volume:
  <a href="status.html?p0=mixer&amp;p1=volume&amp;p2=0&amp;player=aa%3Aaa%3Aaa%3A76%3A0c%3A4c&amp;start=0">1</a>
  <a href="status.html?p0=mixer&amp;p1=volume&amp;p2=10&amp;player=aa%3Aaa%3Aaa%3A76%3A0c%3A4c&amp;start=0">2</a>
  <a href="status.html?p0=mixer&amp;p1=volume&amp;p2=20&amp;player=aa%3Aaa%3Aaa%3A76%3A0c%3A4c&amp;start=0">3</a>
  <a href="status.html?p0=mixer&amp;p1=volume&amp;p2=30&amp;player=aa%3Aaa%3Aaa%3A76%3A0c%3A4c&amp;start=0">4</a>
  <a href="status.html?p0=mixer&amp;p1=volume&amp;p2=40&amp;player=aa%3Aaa%3Aaa%3A76%3A0c%3A4c&amp;start=0">5</a>
  <a href="status.html?p0=mixer&amp;p1=volume&amp;p2=50&amp;player=aa%3Aaa%3Aaa%3A76%3A0c%3A4c&amp;start=0">6</a>
  <a href="status.html?p0=mixer&amp;p1=volume&amp;p2=60&amp;player=aa%3Aaa%3Aaa%3A76%3A0c%3A4c&amp;start=0">7</a>
  <a href="status.html?p0=mixer&amp;p1=volume&amp;p2=70&amp;player=aa%3Aaa%3Aaa%3A76%3A0c%3A4c&amp;start=0">8</a>
  <b>9</b>
  <a href="status.html?p0=mixer&amp;p1=volume&amp;p2=90&amp;player=aa%3Aaa%3Aaa%3A76%3A0c%3A4c&amp;start=0">10</a>
  <a href="status.html?p0=mixer&amp;p1=volume&amp;p2=100&amp;player=aa%3Aaa%3Aaa%3A76%3A0c%3A4c&amp;start=0">11</a>
<html>
<head>
	<title>Music Library</title>
<link rel="shortcut icon" href="/favicon.ico" type="image/x-icon"/>
<link rel="icon" href="/favicon.ico" type="image/x-icon"/>
<meta http-equiv="Content-Type" content="text/html; charset=utf-8"/>
<link rel="stylesheet" type="text/css" href="/slimserver.css?r=1453293926"/>
<link rel="stylesheet" type="text/css" href="/skin.css?r=1453293926"/>
<link rel="apple-touch-icon" href="/html/images/apple-touch-icon.png"/>
	<script TYPE="text/javascript">// useful global vars for javascripts needing info from template toolkit on page loads.
	var webroot       = "/";
	var player        = "aa%3Aaa%3Aaa%3A76%3A0c%3A4c";
	var playerid      = "aa:aa:aa:76:0c:4c";
	var url           = "status_header.html";
	var statusroot    = "status_header.html";
	var browserTarget;
	browserTarget = "browser";
	var orderByUrl    = '';
</script>
	<script TYPE="text/javascript" src="/html/common.js?r=1453293926"></script>
</head>
<body onload="javascript:to_currentsong()">
<div id="playList">
		<span id="currentPlaylistLabel">The current playlist:</span>
		<span id="currentPlaylistCommands">	<a href="edit_playlist.html?player=aa%3Aaa%3Aaa%3A76%3A0c%3A4c&amp;saveCurrentPlaylist=1" target="browser" >
	Save</a> <span class="bar">|</span> 	<a href="status.m3u?player=aa%3Aaa%3Aaa%3A76%3A0c%3A4c" target="playlist">
	Download</a> <span class="bar">|</span> 	<a href="status_header.html?p0=playlist&amp;p1=clear&amp;player=aa%3Aaa%3Aaa%3A76%3A0c%3A4c" target="status" >
	Clear</a></span>
	<div class="browsedbList">
					<a name="currentsong"></a>
<div class="odd"  id="currentListItem">
	<div class="browsedbListItem">
		<span class="exboldlisting">
			from
				<a href="/clixmlbrowser/clicmd=browselibrary+items&amp;mode=albums&amp;linktitle=Album%20(Music%20from%20Porcelain)&amp;album_id=1860&amp;player=aa%3Aaa%3Aaa%3A76%3A0c%3A4c/index.html?index=0" target="browser">Music from Porcelain</a>
		</span>
		<div class="playlistControls">
			<a href="/status_header.html?p0=playlist&amp;p1=jump&amp;p2=0&amp;start=0&amp;player=aa%3Aaa%3Aaa%3A76%3A0c%3A4c" target="status"><img src="/html/images/b_play.gif" width=13 height=13 alt="Play" title="Play"></a>
			<a href="/status_header.html?p0=playlist&amp;p1=move&amp;p2=0&amp;p3=%2B1&amp;start=0&amp;player=aa%3Aaa%3Aaa%3A76%3A0c%3A4c" target="status"><img src="/html/images/b_down.gif" width=13 height=13 alt="Down" title="Down"></a>
			<a href="/status_header.html?p0=playlist&amp;p1=move&amp;p2=0&amp;p3=%2D1&amp;start=0&amp;player=aa%3Aaa%3Aaa%3A76%3A0c%3A4c" target="status"><img src="/html/images/b_up.gif" width=13 height=13 alt="Up" title="Up"></a>
			<a href="/status_header.html?p0=playlist&amp;p1=delete&amp;p2=0&amp;start=0&amp;player=aa%3Aaa%3Aaa%3A76%3A0c%3A4c" target="status"><img src="/html/images/b_delete.gif" width=13 height=13 alt="Remove from playlist" title="Remove from playlist"></a>
		</div>
	</div>
</div>
<div  class="even" >
		<span class="exlisting">
		<a href="/songinfo.html?item=31675&amp;player=aa%3Aaa%3Aaa%3A76%3A0c%3A4c" target="browser">It's All Right (Original Stereo Mix)</a>
			from
				<a href="/clixmlbrowser/clicmd=browselibrary+items&amp;mode=albums&amp;linktitle=Album%20(The%20Authorized%20Bang%20Collection)&amp;album_id=1732&amp;player=aa%3Aaa%3Aaa%3A76%3A0c%3A4c/index.html?index=0" target="browser">The Authorized Bang Collection</a>
		 by <a href="/clixmlbrowser/clicmd=browselibrary+items&amp;mode=albums&amp;linktitle=Artist%20(Van%20Morrison)&amp;artist_id=8996&amp;&amp;artwork=1&amp;player=aa%3Aaa%3Aaa%3A76%3A0c%3A4c/" target="browser" class="browseItemLink"><span style="display:inline">Van Morrison</span></a>
		</span>
			<a href="/status_header.html?p0=playlist&amp;p1=jump&amp;p2=1&amp;start=0&amp;player=aa%3Aaa%3Aaa%3A76%3A0c%3A4c" target="status"><img src="/html/images/b_play.gif" width=13 height=13 alt="Play" title="Play"></a>
			<a href="/status_header.html?p0=playlist&amp;p1=move&amp;p2=1&amp;p3=%2B1&amp;start=0&amp;player=aa%3Aaa%3Aaa%3A76%3A0c%3A4c" target="status"><img src="/html/images/b_down.gif" width=13 height=13 alt="Down" title="Down"></a>
			<a href="/status_header.html?p0=playlist&amp;p1=move&amp;p2=1&amp;p3=%2D1&amp;start=0&amp;player=aa%3Aaa%3Aaa%3A76%3A0c%3A4c" target="status"><img src="/html/images/b_up.gif" width=13 height=13 alt="Up" title="Up"></a>
			<a href="/status_header.html?p0=playlist&amp;p1=delete&amp;p2=1&amp;start=0&amp;player=aa%3Aaa%3Aaa%3A76%3A0c%3A4c" target="status"><img src="/html/images/b_delete.gif" width=13 height=13 alt="Remove from playlist" title="Remove from playlist"></a>
		</div>
	</div>
</div>
<div class="odd"  >
		<a href="/songinfo.html?item=35878&amp;player=aa%3Aaa%3Aaa%3A76%3A0c%3A4c" target="browser">If You Asked Me To</a>
			from
				<a href="/clixmlbrowser/clicmd=browselibrary+items&amp;mode=albums&amp;linktitle=Album%20(Knuffelrock%20Top%20100%20(2016))&amp;album_id=1934&amp;player=aa%3Aaa%3Aaa%3A76%3A0c%3A4c/index.html?index=0" target="browser">Knuffelrock Top 100 (2016)</a>
		 by <a href="/clixmlbrowser/clicmd=browselibrary+items&amp;mode=albums&amp;linktitle=Artist%20(Celine%20Dion)&amp;artist_id=9290&amp;&amp;artwork=1&amp;player=aa%3Aaa%3Aaa%3A76%3A0c%3A4c/" target="browser" class="browseItemLink"><span style="display:inline">Celine Dion</span></a>
		</span>
			<a href="/status_header.html?p0=playlist&amp;p1=jump&amp;p2=2&amp;start=0&amp;player=aa%3Aaa%3Aaa%3A76%3A0c%3A4c" target="status"><img src="/html/images/b_play.gif" width=13 height=13 alt="Play" title="Play"></a>
			<a href="/status_header.html?p0=playlist&amp;p1=move&amp;p2=2&amp;p3=%2B1&amp;start=0&amp;player=aa%3Aaa%3Aaa%3A76%3A0c%3A4c" target="status"><img src="/html/images/b_down.gif" width=13 height=13 alt="Down" title="Down"></a>
			<a href="/status_header.html?p0=playlist&amp;p1=move&amp;p2=2&amp;p3=%2D1&amp;start=0&amp;player=aa%3Aaa%3Aaa%3A76%3A0c%3A4c" target="status"><img src="/html/images/b_up.gif" width=13 height=13 alt="Up" title="Up"></a>
			<a href="/status_header.html?p0=playlist&amp;p1=delete&amp;p2=2&amp;start=0&amp;player=aa%3Aaa%3Aaa%3A76%3A0c%3A4c" target="status"><img src="/html/images/b_delete.gif" width=13 height=13 alt="Remove from playlist" title="Remove from playlist"></a>
		</div>
	</div>
</div>
<div  class="even" >
		<a href="/songinfo.html?item=35634&amp;player=aa%3Aaa%3Aaa%3A76%3A0c%3A4c" target="browser">Heading up High (Years Remix)</a>
			from
				<a href="/clixmlbrowser/clicmd=browselibrary+items&amp;mode=albums&amp;linktitle=Album%20(Pacha%20Ibiza%20Summer%202016)&amp;album_id=1925&amp;player=aa%3Aaa%3Aaa%3A76%3A0c%3A4c/index.html?index=0" target="browser">Pacha Ibiza Summer 2016</a>
		 by <a href="/clixmlbrowser/clicmd=browselibrary+items&amp;mode=albums&amp;linktitle=Artist%20(Armin%20van%20Buuren%20Feat.%20Kensington)&amp;artist_id=10135&amp;&amp;artwork=1&amp;player=aa%3Aaa%3Aaa%3A76%3A0c%3A4c/" target="browser" class="browseItemLink"><span style="display:inline">Armin van Buuren Feat. Kensington</span></a>
		</span>
			<a href="/status_header.html?p0=playlist&amp;p1=jump&amp;p2=3&amp;start=0&amp;player=aa%3Aaa%3Aaa%3A76%3A0c%3A4c" target="status"><img src="/html/images/b_play.gif" width=13 height=13 alt="Play" title="Play"></a>
			<a href="/status_header.html?p0=playlist&amp;p1=move&amp;p2=3&amp;p3=%2B1&amp;start=0&amp;player=aa%3Aaa%3Aaa%3A76%3A0c%3A4c" target="status"><img src="/html/images/b_down.gif" width=13 height=13 alt="Down" title="Down"></a>
			<a href="/status_header.html?p0=playlist&amp;p1=move&amp;p2=3&amp;p3=%2D1&amp;start=0&amp;player=aa%3Aaa%3Aaa%3A76%3A0c%3A4c" target="status"><img src="/html/images/b_up.gif" width=13 height=13 alt="Up" title="Up"></a>
			<a href="/status_header.html?p0=playlist&amp;p1=delete&amp;p2=3&amp;start=0&amp;player=aa%3Aaa%3Aaa%3A76%3A0c%3A4c" target="status"><img src="/html/images/b_delete.gif" width=13 height=13 alt="Remove from playlist" title="Remove from playlist"></a>
		</div>
	</div>
</div>
<div class="odd"  >
		<a href="/songinfo.html?item=33336&amp;player=aa%3Aaa%3Aaa%3A76%3A0c%3A4c" target="browser">ruda - 07. Enrique Iglesias - Hero</a>
		</span>
			<a href="/status_header.html?p0=playlist&amp;p1=jump&amp;p2=4&amp;start=0&amp;player=aa%3Aaa%3Aaa%3A76%3A0c%3A4c" target="status"><img src="/html/images/b_play.gif" width=13 height=13 alt="Play" title="Play"></a>
			<a href="/status_header.html?p0=playlist&amp;p1=move&amp;p2=4&amp;p3=%2B1&amp;start=0&amp;player=aa%3Aaa%3Aaa%3A76%3A0c%3A4c" target="status"><img src="/html/images/b_down.gif" width=13 height=13 alt="Down" title="Down"></a>
			<a href="/status_header.html?p0=playlist&amp;p1=move&amp;p2=4&amp;p3=%2D1&amp;start=0&amp;player=aa%3Aaa%3Aaa%3A76%3A0c%3A4c" target="status"><img src="/html/images/b_up.gif" width=13 height=13 alt="Up" title="Up"></a>
			<a href="/status_header.html?p0=playlist&amp;p1=delete&amp;p2=4&amp;start=0&amp;player=aa%3Aaa%3Aaa%3A76%3A0c%3A4c" target="status"><img src="/html/images/b_delete.gif" width=13 height=13 alt="Remove from playlist" title="Remove from playlist"></a>
		</div>
	</div>
</div>
<div  class="even" >
		<a href="/songinfo.html?item=28042&amp;player=aa%3Aaa%3Aaa%3A76%3A0c%3A4c" target="browser">Used To Have It All</a>
			from
				<a href="/clixmlbrowser/clicmd=browselibrary+items&amp;mode=albums&amp;linktitle=Album%20(538%20Hitzone%2080%20(CD2))&amp;album_id=1507&amp;player=aa%3Aaa%3Aaa%3A76%3A0c%3A4c/index.html?index=0" target="browser">538 Hitzone 80 (CD2)</a>
		 by <a href="/clixmlbrowser/clicmd=browselibrary+items&amp;mode=albums&amp;linktitle=Artist%20(Fais%20%26%20Afrojack)&amp;artist_id=7932&amp;&amp;artwork=1&amp;player=aa%3Aaa%3Aaa%3A76%3A0c%3A4c/" target="browser" class="browseItemLink"><span style="display:inline">Fais &amp; Afrojack</span></a>
		</span>
			<a href="/status_header.html?p0=playlist&amp;p1=jump&amp;p2=5&amp;start=0&amp;player=aa%3Aaa%3Aaa%3A76%3A0c%3A4c" target="status"><img src="/html/images/b_play.gif" width=13 height=13 alt="Play" title="Play"></a>
			<a href="/status_header.html?p0=playlist&amp;p1=move&amp;p2=5&amp;p3=%2B1&amp;start=0&amp;player=aa%3Aaa%3Aaa%3A76%3A0c%3A4c" target="status"><img src="/html/images/b_down.gif" width=13 height=13 alt="Down" title="Down"></a>
			<a href="/status_header.html?p0=playlist&amp;p1=move&amp;p2=5&amp;p3=%2D1&amp;start=0&amp;player=aa%3Aaa%3Aaa%3A76%3A0c%3A4c" target="status"><img src="/html/images/b_up.gif" width=13 height=13 alt="Up" title="Up"></a>
			<a href="/status_header.html?p0=playlist&amp;p1=delete&amp;p2=5&amp;start=0&amp;player=aa%3Aaa%3Aaa%3A76%3A0c%3A4c" target="status"><img src="/html/images/b_delete.gif" width=13 height=13 alt="Remove from playlist" title="Remove from playlist"></a>
		</div>
	</div>
</div>
<div class="odd"  >
		<a href="/songinfo.html?item=29251&amp;player=aa%3Aaa%3Aaa%3A76%3A0c%3A4c" target="browser">Mantra</a>
			from
				<a href="/clixmlbrowser/clicmd=browselibrary+items&amp;mode=albums&amp;linktitle=Album%20(Grandmix%202016%20CD%202)&amp;album_id=1581&amp;player=aa%3Aaa%3Aaa%3A76%3A0c%3A4c/index.html?index=0" target="browser">Grandmix 2016 CD 2</a>
		 by <a href="/clixmlbrowser/clicmd=browselibrary+items&amp;mode=albums&amp;linktitle=Artist%20(Michael%20Feiner)&amp;artist_id=7966&amp;&amp;artwork=1&amp;player=aa%3Aaa%3Aaa%3A76%3A0c%3A4c/" target="browser" class="browseItemLink"><span style="display:inline">Michael Feiner</span></a>
		</span>
			<a href="/status_header.html?p0=playlist&amp;p1=jump&amp;p2=6&amp;start=0&amp;player=aa%3Aaa%3Aaa%3A76%3A0c%3A4c" target="status"><img src="/html/images/b_play.gif" width=13 height=13 alt="Play" title="Play"></a>
			<a href="/status_header.html?p0=playlist&amp;p1=move&amp;p2=6&amp;p3=%2B1&amp;start=0&amp;player=aa%3Aaa%3Aaa%3A76%3A0c%3A4c" target="status"><img src="/html/images/b_down.gif" width=13 height=13 alt="Down" title="Down"></a>
			<a href="/status_header.html?p0=playlist&amp;p1=move&amp;p2=6&amp;p3=%2D1&amp;start=0&amp;player=aa%3Aaa%3Aaa%3A76%3A0c%3A4c" target="status"><img src="/html/images/b_up.gif" width=13 height=13 alt="Up" title="Up"></a>
			<a href="/status_header.html?p0=playlist&amp;p1=delete&amp;p2=6&amp;start=0&amp;player=aa%3Aaa%3Aaa%3A76%3A0c%3A4c" target="status"><img src="/html/images/b_delete.gif" width=13 height=13 alt="Remove from playlist" title="Remove from playlist"></a>
		</div>
	</div>
</div>
<div  class="even" >
		<a href="/songinfo.html?item=29306&amp;player=aa%3Aaa%3Aaa%3A76%3A0c%3A4c" target="browser">Tabee (feat. Diggy Dex)</a>
			from
				<a href="/clixmlbrowser/clicmd=browselibrary+items&amp;mode=albums&amp;linktitle=Album%20(Grootste%20Hits)&amp;album_id=1583&amp;player=aa%3Aaa%3Aaa%3A76%3A0c%3A4c/index.html?index=0" target="browser">Grootste Hits</a>
		 by <a href="/clixmlbrowser/clicmd=browselibrary+items&amp;mode=albums&amp;linktitle=Artist%20(Guus%20Meeuwis)&amp;artist_id=8467&amp;&amp;artwork=1&amp;player=aa%3Aaa%3Aaa%3A76%3A0c%3A4c/" target="browser" class="browseItemLink"><span style="display:inline">Guus Meeuwis</span></a>
		</span>
			<a href="/status_header.html?p0=playlist&amp;p1=jump&amp;p2=7&amp;start=0&amp;player=aa%3Aaa%3Aaa%3A76%3A0c%3A4c" target="status"><img src="/html/images/b_play.gif" width=13 height=13 alt="Play" title="Play"></a>
			<a href="/status_header.html?p0=playlist&amp;p1=move&amp;p2=7&amp;p3=%2B1&amp;start=0&amp;player=aa%3Aaa%3Aaa%3A76%3A0c%3A4c" target="status"><img src="/html/images/b_down.gif" width=13 height=13 alt="Down" title="Down"></a>
			<a href="/status_header.html?p0=playlist&amp;p1=move&amp;p2=7&amp;p3=%2D1&amp;start=0&amp;player=aa%3Aaa%3Aaa%3A76%3A0c%3A4c" target="status"><img src="/html/images/b_up.gif" width=13 height=13 alt="Up" title="Up"></a>
			<a href="/status_header.html?p0=playlist&amp;p1=delete&amp;p2=7&amp;start=0&amp;player=aa%3Aaa%3Aaa%3A76%3A0c%3A4c" target="status"><img src="/html/images/b_delete.gif" width=13 height=13 alt="Remove from playlist" title="Remove from playlist"></a>
		</div>
	</div>
</div>
<div class="odd"  >
		<a href="/songinfo.html?item=31475&amp;player=aa%3Aaa%3Aaa%3A76%3A0c%3A4c" target="browser">False Alarm</a>
			from
				<a href="/clixmlbrowser/clicmd=browselibrary+items&amp;mode=albums&amp;linktitle=Album%20(Starboy)&amp;album_id=1721&amp;player=aa%3Aaa%3Aaa%3A76%3A0c%3A4c/index.html?index=0" target="browser">Starboy</a>
		 by <a href="/clixmlbrowser/clicmd=browselibrary+items&amp;mode=albums&amp;linktitle=Artist%20(The%20Weeknd)&amp;artist_id=8008&amp;&amp;artwork=1&amp;player=aa%3Aaa%3Aaa%3A76%3A0c%3A4c/" target="browser" class="browseItemLink"><span style="display:inline">The Weeknd</span></a>
		</span>
			<a href="/status_header.html?p0=playlist&amp;p1=jump&amp;p2=8&amp;start=0&amp;player=aa%3Aaa%3Aaa%3A76%3A0c%3A4c" target="status"><img src="/html/images/b_play.gif" width=13 height=13 alt="Play" title="Play"></a>
			<a href="/status_header.html?p0=playlist&amp;p1=move&amp;p2=8&amp;p3=%2B1&amp;start=0&amp;player=aa%3Aaa%3Aaa%3A76%3A0c%3A4c" target="status"><img src="/html/images/b_down.gif" width=13 height=13 alt="Down" title="Down"></a>
			<a href="/status_header.html?p0=playlist&amp;p1=move&amp;p2=8&amp;p3=%2D1&amp;start=0&amp;player=aa%3Aaa%3Aaa%3A76%3A0c%3A4c" target="status"><img src="/html/images/b_up.gif" width=13 height=13 alt="Up" title="Up"></a>
			<a href="/status_header.html?p0=playlist&amp;p1=delete&amp;p2=8&amp;start=0&amp;player=aa%3Aaa%3Aaa%3A76%3A0c%3A4c" target="status"><img src="/html/images/b_delete.gif" width=13 height=13 alt="Remove from playlist" title="Remove from playlist"></a>
		</div>
	</div>
</div>
<div  class="even" >
		<a href="/songinfo.html?item=30712&amp;player=aa%3Aaa%3Aaa%3A76%3A0c%3A4c" target="browser">Black Betty</a>
			from
				<a href="/clixmlbrowser/clicmd=browselibrary+items&amp;mode=albums&amp;linktitle=Album%20(Q%20Music%20Rock%20100)&amp;album_id=1676&amp;player=aa%3Aaa%3Aaa%3A76%3A0c%3A4c/index.html?index=0" target="browser">Q Music Rock 100</a>
		 by <a href="/clixmlbrowser/clicmd=browselibrary+items&amp;mode=albums&amp;linktitle=Artist%20(Ram%20Jam)&amp;artist_id=8731&amp;&amp;artwork=1&amp;player=aa%3Aaa%3Aaa%3A76%3A0c%3A4c/" target="browser" class="browseItemLink"><span style="display:inline">Ram Jam</span></a>
		</span>
			<a href="/status_header.html?p0=playlist&amp;p1=jump&amp;p2=9&amp;start=0&amp;player=aa%3Aaa%3Aaa%3A76%3A0c%3A4c" target="status"><img src="/html/images/b_play.gif" width=13 height=13 alt="Play" title="Play"></a>
			<a href="/status_header.html?p0=playlist&amp;p1=move&amp;p2=9&amp;p3=%2B1&amp;start=0&amp;player=aa%3Aaa%3Aaa%3A76%3A0c%3A4c" target="status"><img src="/html/images/b_down.gif" width=13 height=13 alt="Down" title="Down"></a>
			<a href="/status_header.html?p0=playlist&amp;p1=move&amp;p2=9&amp;p3=%2D1&amp;start=0&amp;player=aa%3Aaa%3Aaa%3A76%3A0c%3A4c" target="status"><img src="/html/images/b_up.gif" width=13 height=13 alt="Up" title="Up"></a>
			<a href="/status_header.html?p0=playlist&amp;p1=delete&amp;p2=9&amp;start=0&amp;player=aa%3Aaa%3Aaa%3A76%3A0c%3A4c" target="status"><img src="/html/images/b_delete.gif" width=13 height=13 alt="Remove from playlist" title="Remove from playlist"></a>
		</div>
	</div>
</div>
	</div>
</div>
</body>
</html>
  </body>
</html>
If a dev needs access to the web interface, I can arrange that.
Hardware: Raspberry Pi 2B | RFXCOM RFXtrx433E v1 | Synology DS213+ | KaKu Clones | Conrad RSL switches | KAKu Doorbell Clone | USB Webcam | ICY Thermostat | Resol DL2 | Imatic Relay Board | Eminent 6230 | Eminent 6220 | iMatic 16 ports Relay Board
capman
Post by capman »
Thanks 4 helping me out here.
I get some different html pages when I put some url's in my browser.
http://192.168.178.29:9002/music/current/cover.jpg?player=b8%3A27%3Aeb%3A29%3A3c%3A50
Give me the cover from what is current playing , like you say :D . And
Give me the status page with debuger code >
<html>
  <head>
    <title>Squeezebox-muzieksysteem Keuken </title>
  </head>
	<h3>Squeezebox-muzieksysteem Keuken</h3>
  	<form method="get" action="/index.html" target="_top">Huidig muzieksysteem: <select name="player">
<option  value="b8:27:eb:2f:cc:69">Badkamer</option>
<option selected value="b8:27:eb:29:3c:50">Keuken</option></select><input class="stdclick" type="submit" value="Change"></form>
    Speelt nu
    4 van 4:
   </div>
   <div class="playingSong"><a href="/songinfo.html?item=-164403984&amp;player=b8%3A27%3Aeb%3A29%3A3c%3A50" target="browser">IRON AND WINE - Call it dreaming</a>
    <span class="playingSongControls"><a href="status.html?p0=playlist&amp;p1=delete&amp;p2=3&amp;player=b8%3A27%3Aeb%3A29%3A3c%3A50&amp;start=0"><span>(Verwijderen)</span></a></span>
   </div>
<hr><a href="status.html?p0=playlist&amp;p1=jump&amp;p2=-1&amp;player=b8%3A27%3Aeb%3A29%3A3c%3A50">Vorige</a>
<a href="status.html?p0=playlist&amp;p1=jump&amp;p2=%2b1&amp;player=b8%3A27%3Aeb%3A29%3A3c%3A50">Overslaan</a>
    <b>Afspelen</b>
    <a href="status.html?p0=pause&amp;player=b8%3A27%3Aeb%3A29%3A3c%3A50">Pauzeren</a>
    <a href="status.html?p0=stop&amp;player=b8%3A27%3Aeb%3A29%3A3c%3A50">Stoppen</a>
<br>Herhalen:
<b>uit</b>/<a href="status.html?p0=playlist&amp;p1=repeat&amp;p2=1&amp;player=b8%3A27%3Aeb%3A29%3A3c%3A50&amp;start=0">één</a>/<a href="status.html?p0=playlist&amp;p1=repeat&amp;p2=2&amp;player=b8%3A27%3Aeb%3A29%3A3c%3A50&amp;start=0">alle</a>
<br>Willekeurig:
<b>uit</b>/<a href="status.html?p0=playlist&amp;p1=shuffle&amp;p2=1&amp;player=b8%3A27%3Aeb%3A29%3A3c%3A50&amp;start=0">liedjes</a>/<a href="status.html?p0=playlist&amp;p1=shuffle&amp;p2=2&amp;player=b8%3A27%3Aeb%3A29%3A3c%3A50&amp;start=0">albums</a>
<br>
    Muzieksysteem:
               <b>aan</b>/<a
               target="_top" href="index.html?player=b8%3A27%3Aeb%3A29%3A3c%3A50&amp;p0=power&amp;p1=0">uit</a>
<br><br>
Volume:
  <b>1</b>
  <a href="status.html?p0=mixer&amp;p1=volume&amp;p2=10&amp;player=b8%3A27%3Aeb%3A29%3A3c%3A50&amp;start=0">2</a>
  <a href="status.html?p0=mixer&amp;p1=volume&amp;p2=20&amp;player=b8%3A27%3Aeb%3A29%3A3c%3A50&amp;start=0">3</a>
  <a href="status.html?p0=mixer&amp;p1=volume&amp;p2=30&amp;player=b8%3A27%3Aeb%3A29%3A3c%3A50&amp;start=0">4</a>
  <a href="status.html?p0=mixer&amp;p1=volume&amp;p2=40&amp;player=b8%3A27%3Aeb%3A29%3A3c%3A50&amp;start=0">5</a>
  <a href="status.html?p0=mixer&amp;p1=volume&amp;p2=50&amp;player=b8%3A27%3Aeb%3A29%3A3c%3A50&amp;start=0">6</a>
  <a href="status.html?p0=mixer&amp;p1=volume&amp;p2=60&amp;player=b8%3A27%3Aeb%3A29%3A3c%3A50&amp;start=0">7</a>
  <a href="status.html?p0=mixer&amp;p1=volume&amp;p2=70&amp;player=b8%3A27%3Aeb%3A29%3A3c%3A50&amp;start=0">8</a>
  <a href="status.html?p0=mixer&amp;p1=volume&amp;p2=80&amp;player=b8%3A27%3Aeb%3A29%3A3c%3A50&amp;start=0">9</a>
  <a href="status.html?p0=mixer&amp;p1=volume&amp;p2=90&amp;player=b8%3A27%3Aeb%3A29%3A3c%3A50&amp;start=0">10</a>
  <a href="status.html?p0=mixer&amp;p1=volume&amp;p2=100&amp;player=b8%3A27%3Aeb%3A29%3A3c%3A50&amp;start=0">11</a>
<div>
	<div id="playList">
					<div class="draggableSong selectorMarker " id="playlistSong0" onmouseover="Main.playlist.Highlighter.highlight(this);">
	<div class="browsedbListItem itemWithCover">
			<span class="playlistCover">
				<img src="http://www.mysqueezebox.com/public/imageproxy?w=50&h=50&u=http%3A%2F%2Fcdn-radiotime-logos.tunein.com%2Fs2611q.png" width="50" height="50" onLoad="resize(this, 50)">
			</span>
			<div class="playlistSongDetail">
				<a href="/songinfo.html?item=-131028008&amp;player=b8%3A27%3Aeb%3A29%3A3c%3A50" target="browser" class="browseItemLink"><span>Bryan Adams - (Everything I Do) I Do It For You (VRT Studio Brussel 100.6)</span></a>
			</div>
			</div>
					100.6 | VRT Studio Brussel (Euro Hits)
				</div>
			<img onclick="SqueezeJS.UI.setProgressCursor();Main.playlist.request('index', 'playlistSong0')" src="/html/images/b_play.gif" width="17" height="17" alt="Afspelen" title="Afspelen">
			<img onclick="SqueezeJS.UI.setProgressCursor();Main.playlist.request('delete', 'playlistSong0')" src="/html/images/b_delete.gif" width="17" height="17" alt="Uit playlist verwijderen" title="Uit playlist verwijderen"></a>
				<img src="/html/images/b_mmmix.gif" width="17" height="17" alt="" title="">
			</a>
		</div>
	</div>
</div>
					<div class="draggableSong selectorMarker " id="playlistSong1" onmouseover="Main.playlist.Highlighter.highlight(this);">
				<img src="/plugins/RadioTime/html/images/icon_50x50.png" width="50" height="50" onLoad="resize(this, 50)">
			</span>
				<a href="/songinfo.html?item=-95310504&amp;player=b8%3A27%3Aeb%3A29%3A3c%3A50" target="browser" class="browseItemLink"><span>100.2 | Radio FG (Electronic-Dance)</span></a>
			</div>
			</div>
			<img onclick="SqueezeJS.UI.setProgressCursor();Main.playlist.request('index', 'playlistSong1')" src="/html/images/b_play.gif" width="17" height="17" alt="Afspelen" title="Afspelen">
			<img onclick="SqueezeJS.UI.setProgressCursor();Main.playlist.request('delete', 'playlistSong1')" src="/html/images/b_delete.gif" width="17" height="17" alt="Uit playlist verwijderen" title="Uit playlist verwijderen"></a>
			</a>
		</div>
	</div>
</div>
					<div class="draggableSong selectorMarker " id="playlistSong2" onmouseover="Main.playlist.Highlighter.highlight(this);">
			</span>
				<a href="/songinfo.html?item=-164709912&amp;player=b8%3A27%3Aeb%3A29%3A3c%3A50" target="browser" class="browseItemLink"><span>99.4 | Top Radio Belgium (Euro Hits)</span></a>
			</div>
			</div>
			<img onclick="SqueezeJS.UI.setProgressCursor();Main.playlist.request('index', 'playlistSong2')" src="/html/images/b_play.gif" width="17" height="17" alt="Afspelen" title="Afspelen">
			<img onclick="SqueezeJS.UI.setProgressCursor();Main.playlist.request('delete', 'playlistSong2')" src="/html/images/b_delete.gif" width="17" height="17" alt="Uit playlist verwijderen" title="Uit playlist verwijderen"></a>
			</a>
		</div>
	</div>
</div>
					<div class="draggableSong selectorMarker currentSong" id="playlistSong3" onmouseover="Main.playlist.Highlighter.highlight(this);">
			</span>
				<a href="/songinfo.html?item=-164403984&amp;player=b8%3A27%3Aeb%3A29%3A3c%3A50" target="browser" class="browseItemLink"><span>VRT Radio 1 94.2 (Gesproken)</span></a>
			</div>
			</div>
			<img onclick="SqueezeJS.UI.setProgressCursor();Main.playlist.request('index', 'playlistSong3')" src="/html/images/b_play.gif" width="17" height="17" alt="Afspelen" title="Afspelen">
			<img onclick="SqueezeJS.UI.setProgressCursor();Main.playlist.request('delete', 'playlistSong3')" src="/html/images/b_delete.gif" width="17" height="17" alt="Uit playlist verwijderen" title="Uit playlist verwijderen"></a>
			</a>
			<img src="/html/images/spacer.gif" class="nowPlayingIcon"/>
		</div>
	</div>
</div>
				<div id="offset" style="display:none">0</div>
	</div>
	<div id="playlistTab" class="infoTab">
		<div id="playlistCommands">
			<table id="playlistCommandSpacer"><tr>
				<td><span id="btnPlaylistToggleArtwork"></span></td>
				<td width="100%"><div id="current_playlist_summary">
					<span id="total_playtime"></span>&nbsp;
					<span id="current_playlist_name">
					&nbsp;
					</span>
				</div></td>
 				<td><span id="btnPlaylistSave" ></span></td>
				<td><span id="btnPlaylistClear"></span></td>
			</tr></table>
		</div>
	</div>
</div>
  </body>
</html>
I also found a site with some info about this subject. http://tutoriels.domotique-store.fr/con ... -http.html
But the main question is how to integrate this in the dashticz frontpage. I can copy some html code , but where should I past this ? Once I know how this works , I'm set to start. ;)
freakshock
I'm too much of a noob to do this, but it would be great if we could get something like the Spotify plugin, with album cover, playlist selection and perhaps also volume control. Shouldn't be too hard to make a slider like element that calls the volume url's.
What I did manage to do is find links for my Spotty plugin playlists with inspect element in chrome.
Example:
http://192.168.1.73:9002/plugins/spotty/index.html?action=playall&index=7.2&player=cc%3Acc%3Af4%3A24%3Ae7%3A21&sess=&start=&_dc=1501273859963
I made a selector switch in Domoticz and pasted a few URL's of my favorite playlists in there. That way I can choose a few playlists from within Dashticz:
capman
Post by capman »
Okayyy , getting something here 8-) Have made a selector switch with two url's to my playlist with each a radio station.
http://192.168.178.29:9002/status.html?p0=playlist&p1=play&p2=RadioFG&p3=b8:27:eb:29:3c:50
and
http://192.168.178.29:9002/status.html?p0=playlist&p1=play&p2=StuBru&p3=b8:27:eb:29:3c:50
Just like freakshock say. Thanks freakshock!
Now I just have 2 make a selector switch in dashticz and we have control about my player (stop , play). And a selector with some favorites in.
Next thing to do , volume control :D .
Thanks 2 everybody 4 all help so far !
pvm
Post by pvm »
