Dashticz - Module - Spotify (new version!)
- EdwinK
- Domoticz version: BETA
Re: Dashticz - Module - Spotify
Btw.. Nice it doesn't require a premium account
jmvdijk
I have the same problem. Is there a solution for this problem?vgr2 wrote:I mean, empty playlist
barbaar
Re: Dashticz - [BETA]Module - Spotify
I got around this by opening Spotify itself once on the same machine..
But later I found I cannot get this to work in my Tablet using Fully Kiosk Browser. I keep seeing the "INVALID_CLIENT: Invalid redirect URL" error, even after I logged in op developer.spotify.com.
It would be very cool if we got this module to work, and extend a little (play music on other device!)
would be nice also for me......barbaar wrote:I got around this by opening Spotify itself once on the same machine..
robgeerts
- Domoticz version: 3.7067
I assume you're using the same url on windows and tablet?
For example, some people are using http://localhost/dashticz on windows and http://192.168.1.3/dashticz on another device.
Maybe there is a missunderstanding on my side. At the moment I have to open / or the spotify web api opens Spotify in parallel. Means I have to install on all of the tablets spotify also. My understanding from spotify web api is that should be normaly not needed.
robgeerts
Indeed, it opens Spotify, but I agree it should play in webbrowser...
Let me get into this!
Derik
mmm looks very great...
Only on what speakers do you play this music??
On the tablet very bad...
Other options?
xxx
Other options?
xxx
robgeerts
Well, it should open Spotify-app (at least on windows, didnt test on tablet yet).
Playing via browser is not supported by the Spotify API...
pollefinario
Rob, pointed me to this thread. I will check it tonight. Also using Fully Kiosk Browser, did you check any (advanced) settings also?barbaar wrote:I got around this by opening Spotify itself once on the same machine..
konix
- Domoticz version: 2020.2
Hi vgr2,vgr2 wrote:Rob, now I have to loging to Spotify parallel, otherwise it will not work.
How did you do to see your playlist finally? I have the button "show playlist" but no popup that opens anything?
Raspberry PI 2 whith Domoticz (Master)
Raspberry PI B+ whith Domoticz (Slave)
Raspberry PI B+ whith OSMC
RFLINK - ZWAVE - TELEINFO - 1 WIRE
Have you installed last beta?
konix
Hi vgr2,vgr2 wrote:Have you installed last beta?
I try again and now it's works .....
D'rMorris
Just so that it might help others: if you only created a Spotify account so that you could test this plugin (like I did), please be aware that you indeed first have to actually play something. I created an account, enabled the developer API, created 2 playlists, got the Spotify login page when refresjng Dashticz, but nothing showed when I clicked playlists. Then I installed the Spotify app on my Android tablet (from which I'm now accessing Dashticz), played a song and all of a sudden the plugin appeared in Dashticz!
ArieKanarie
Is it still necessary to install spotify on the domoticz device?
Because as far as i know spotify cannot be installed on raspberry..
robgeerts
Yes, i'm sorry, it is.
freakshock
A possible alternative is using Logitech media server with a Spotify plugin (I use Spotty).
This way you can use a standard mediaplayer block in Dashticz. That way you can use back, stop, play/pause and next buttons.
I also made a selector switch that can choose playlist within Spotty (all manual config unfortunately).
Of course you would need a server to run LMS.
Amazing plugin!
Is it possible to have the following features:
- If you click on "Select Playlists", also show the playlist label (name). Now there is only a album picture showing.
- Is it possible to show the available songs within a playlist? So you can navigate directly to the correct song?
- Is it possible to have a search field to use the search library within Spotify? So we can play songs outside our playlists?
Very pleased to have spotify now within Domoticz, thanks!!
robgeerts
First 2 suggestions are new in latest version, check it out!!
Great!! It is working.robgeerts wrote: Wednesday 09 August 2017 16:30 First 2 suggestions are new in latest version, check it out!!![]()
