There is a web interface, where is possible to access nearly all important functions.
I want to control (if it is possible with feedback):
on/off state
http://dreambox/web/powerstate? to check Powerstate
http://dreambox/web/powerstate?newstate={powerstate_number}
0 = Toogle StandbyCode: Select all
Volume Requests:
Get current Volume: http://dreambox/web/vol oder http://dreambox/web/vol?set=state
Set Volume to 23: http://dreambox/web/vol?set=set23
Increase Volume: http://dreambox/web/vol?set=up
Decrease Volume: http://dreambox/web/vol?set=down
Switch Mute: http://dreambox/web/vol?set=mute
Result:
<?xml version="1.0" encoding="utf-8"?>
<e2volume>
<e2result>True</e2result>
<e2resulttext>state</e2resulttext>
<e2current>5</e2current>
<e2ismuted>False</e2ismuted>
</e2volume>
Parameter:
result = True if command successful, False otherwise
resulttext = textbased description of what succeeded/went wrong
current = current Volume - Value between 0 and 100
ismuted = True if muted, False if not
