towel rail if statement
markjgabb
Domoticz version: 3.8153
Post by markjgabb »
hi guys
im currently trying to write a dzvents to control my towel rail
the scenario is
i have a wemo switch in the bathroom on the powerpoint for the towel rail
if its switched on manually at the switch (which is the most likely)
it doesnt update in domoticz
so i would like to set a switch that checks every 10 minutes using the phyton command wemo status (ouixmux)
which returns something like ('Switch:', 'Wemo', '\t', 0) off
or ('Switch:', 'Wemo', '\t', 1) on
this is where ive gotten so far...im stuck on the script return part....and the end in the middle.... line 27
-- Check the wiki at
-- http://www.domoticz.com/wiki/%27dzVents%27:_next_generation_LUA_scripting
	-- 'active' controls if this entire script is considered or not
	active = false, -- set to false to disable this script
	-- trigger
	-- can be a combination:
		timer = {
			-- timer triggers.. if one matches with the current time then the script is executed
			'every 10 minutes'
	data = {
	    towelrailontime = {domoticz.device('towel rail').lastUpdate.raw}
	    wemo_state = {initial=off}
	-- actual event code
	-- in case of a timer event or security event, device == nil
		-- check for if switch is manually turned On
		--need somthing to run script and report if switch is on or off and report back to wemo_state
		if  domoticz.data.wemo_state == 'off'then
		    goto end
	elseif domoticz.data.wemo_state == 'on' then
		--turn on towel rail without triggering on script
		domoticz.device('towel rail').switchOn(true)
		--actual off switch
		if (domoticz.device('towel rail').state == 'On') and domoticz.time.raw - domoticz.data.towelrailontime > 45 then
			domoticz.device('towel rail').switchOff()
V 2020.2 RPI 3
RFlink 334 mhz
mysensors
broadlink
Mirabella Genio Globes
dannybloe
Re: towel rail if statement
Post by dannybloe »
Ok, there are a couple of problems with this script.
First of all, it isn't syntactically correct Lua as it is now. Apart from the logic of your script. The data section is missing comma's and the off needs quotes otherwise it is a variable instead of the string 'off'. Also, you cannot initialize a variable using the domoticz.object.
Also, the data section needs to be terminated with a comma as well, separating data from execute.
Then some other remarks.
You cannot use the silent switching just yet as it is not available in 2.2.0. Until then you can use
domoticz.device('towel rail').update(0, 'Off')
Also, you cannot compare domoticz.time.raw and do calculations with it as it is a string representation of the time.
And finally, I'm not sure what you try to do with your script as the two data variables (towelrailontime and wemo_state) never seem to get a value in your script. The data section is only for initializing and declaring the variables. In your execute function you manipulate them.
Oh, and your question: you can end your function by using the 'return' statement. But in your script you don't need it if you make your if-statement logic different (just create an if-statement that does something when you need to, then you don't need an else part and no return statements are needed).
So, before you go and change the logic of your script, this version is more what you intended (syntactically):
		timer = {
			'every 10 minutes'
	data = {
		towelrailontime = { initial = nil }, -- you cannot use domoticz object here
		wemo_state = { initial = 'off' }, -- off must be a string otherwise it's a variable called off
		if domoticz.data.wemo_state == 'off' then
			return
			--domoticz.device('towel rail'). switchOn(true) -- true doesn't work just yet in 2.2.0!!
			domoticz.device('towel rail').update(0, 'Off') -- switch off without triggering scripts
			--actual off switch
			if (domoticz.device('towel rail').state == 'On' and domoticz.time.raw - domoticz. data. towelrailontime > 45) then
That said, there is a better way to compare timestamps with dzVents by using a data variable with history=true:
	data = {
		onTime = {history = true, maxItems = 1 }
Then every time you give it a value:
domoticz.data.onTime.set('On')
It will automatically time-stamp the value. So at a later stage, when you want to see when the switch was switched on you can check when exactly that was:
local lastValue = domoticz.data.onTime.get()
if (lastValue.value == 'On' or lastValue.time.secondsAgo() > 45) then --just an example!
But again, think about the rest of your logic.
