- EdwinK
- Domoticz version: BETA
I think option 2 would be best
robgeerts
- Domoticz version: 3.7067
Ok, will do!
- HansieNL
I also prefer option 2.EdKo66 wrote:I think option 2 would be best
Blah blah blah
Onrust
- Domoticz version: 4.10717
Regarding the selector switch: I've hidden the 0 level ("Off") in Domoticz, but Dashticz still shows it. Would be good to have it hidden in Dashticz as well.
sebasjuh
I added the moonphases module to my dashticz v2 screen only I got nog everyday from weather underground a message that I exceeded the 500 calls in a day. And when I look at the log of domoticz I see that every minute the script_time_moon.lua is executed to collect the data from:
http://api.wunderground.com/api/XXXXXX/ ... Zwaag.json
I changed the local checktime in the script_time_moon.lua from 3600 to 7200 but after the change the script is still being executed every minute.
How can I change that so that the script will be executed every hour and not see that script being executed every minute in domoticz log ?
- EdwinK
I have it run every 1800 seconds (30 min), and with the following settings and never got those emails.
The log will still show it runs every minute, but because of the setting of 1800 it will only connect to the server once the time has past.
sebasjuh
Thanks EdKo66, i solved it with the following script:
http://domoticz.com/forum/viewtopic.php?f=38&t=8979
I now set it up that the script only runs every 60 minutes (in my opinion more than enough) and my WU api likes it also, no more messages anymore that I exceeded the limit.
I have created two on/off buttons.
One is an off button to turn all lights (hue) off in my house.
One is an on button to turn all lights (hue) on in my house.
They both work in the domoticz environment.
Downside is that the on button does not work in Dashticz.
Anyone a suggestion, clue or a solution?
Thx in advance.
Thx in advance.
Bigted
- Domoticz version: 2020.1
Re: New Dashboard Design v2, custom positioning and multiple screens
I'v read most of the posts on this thread, is there a solution to this issue?SuperMouse wrote:
But is it able to make the 'vandaag' default?
I also noticed that after a refresh of the screen this is also set to the first option.
blacksn0w
Just submitted a pull request for solving this, after merge and an update of your Dashticz you should see a new option in the settings menu under "Screen"Bigted wrote:I'v read most of the posts on this thread, is there a solution to this issue?SuperMouse wrote:
Bigted
Perfect thanks for the fast responseblacksn0w wrote: Just submitted a pull request for solving this, after merge and an update of your Dashticz you should see a new option in the settings menu under "Screen"
robgeerts
I will merge this later today!
- EdwinK
Just did a git pull:
remote: Counting objects: 8, done.
remote: Compressing objects: 100% (2/2), done.
remote: Total 8 (delta 6), reused 8 (delta 6), pack-reused 0
Unpacking objects: 100% (8/8), done.
From https://github.com/robgeerts/dashticz_v2
b66d5e9..0d14407 Beta -> origin/Beta
Your configuration specifies to merge with the ref 'refs/heads/beta'
from the remote, but no such ref was fetched.
Did I do something wrong?
robgeerts
No, something went wrong on my side...
Branch is now called Beta, instead of beta
- EdwinK
Ah... So just to ignore it
robgeerts
Yeah but did it get the latest version??
You can recognize it by new files in lang-folder like: 'nl_NL.json'
- EdwinK
Yes, got those nl.json files
raymond
- Domoticz version: V4.10232
Same here, got the language files, but I keep getting this error (if it is an error at all?)
I'm not sure if I need to do something to merge? Or just leave it alone?
Cheers,
Ray
remote: Counting objects: 25, done.
remote: Compressing objects: 100% (12/12), done.
remote: Total 25 (delta 16), reused 22 (delta 13), pack-reused 0
Unpacking objects: 100% (25/25), done.
172b844..1a881c1 Beta -> origin/Beta
Your configuration specifies to merge with the ref 'beta'
from the remote, but no such ref was fetched.Cheers,
Ray
robgeerts
Leave it alone if you have those files.
You can always do a clean install with the Beta
