Domoboard - Bug reports
Domoboard is a dashboard for Domoticz based on Python Flask.
Moderators: leecollings, wez3
Forum rules
Before posting here, make sure you are using the latest Beta or Stable version.
In order to fix issues or add features these have to be reported on the Domoboard Github pages.
This makes it possible to keep track of issues/features on a centralized place.
Refer to the issue of the github tracker when possible.
This subforum is meant to discuss issues and/or feature requests, or anything else related to Domoboard.
jaccov
Re: Domoboard - Bug reports
Post by jaccov »
pi@Domoticz:~/domoboard/bin $ sudo /home/pi/domoboard/bin/python /home/pi/domoboard/server.py -d -c /home/pi/domoboard/home.conf
Error occured during loading imports for the plugin afvalwijzer: No module named BeautifulSoup. Install it with 'easy_install BeautifulSoup' or 'pip install BeautifulSoup'
squandor
Domoticz version: 3.5837
Post by squandor »
Ok so could you try the following. Run /home/pi/domoboard/bin/python than after that try: import BeautifulSoup
jaccov
Post by jaccov »
pi@Domoticz:~/domoboard/bin $ /home/pi/domoboard/bin/python
Python 2.7.9 (default, Sep 17 2016, 20:26:04)
[GCC 4.9.2] on linux2
Type "help", "copyright", "credits" or "license" for more information.
File "<stdin>", line 1, in <module>
ImportError: No module named BeautifulSoup
squandor
Post by squandor »
Ow I see it already you where still using the pip of the os could you try the following command sudo /home/pi/domoboard/bin/pip install BeautifulSoup --upgrade
jaccov
Post by jaccov »
Yes it is running now but.....
when I open a browser I get
IOError
IOError: [Errno 2] No such file or directory: 'VERSION.md'
Traceback (most recent call last)
File "/home/pi/domoboard/lib/python2.7/site-packages/flask/app.py", line 2000, in __call__
return self.wsgi_app(environ, start_response)
File "/home/pi/domoboard/lib/python2.7/site-packages/flask/app.py", line 1991, in wsgi_app
response = self.make_response(self.handle_exception(e))
File "/home/pi/domoboard/lib/python2.7/site-packages/flask/app.py", line 1567, in handle_exception
reraise(exc_type, exc_value, tb)
File "/home/pi/domoboard/lib/python2.7/site-packages/flask/app.py", line 1988, in wsgi_app
response = self.full_dispatch_request()
File "/home/pi/domoboard/lib/python2.7/site-packages/flask/app.py", line 1641, in full_dispatch_request
rv = self.handle_user_exception(e)
File "/home/pi/domoboard/lib/python2.7/site-packages/flask/app.py", line 1544, in handle_user_exception
File "/home/pi/domoboard/lib/python2.7/site-packages/flask/app.py", line 1639, in full_dispatch_request
rv = self.dispatch_request()
File "/home/pi/domoboard/lib/python2.7/site-packages/flask/app.py", line 1625, in dispatch_request
return self.view_functions[rule.endpoint](**req.view_args)
File "/home/pi/domoboard/lib/python2.7/site-packages/flaskext/auth/auth.py", line 186, in decorator
return func(*args, **kwargs)
File "/home/pi/domoboard/server.py", line 55, in generatePage
version = webconfig.getVersion(),
File "/home/pi/domoboard/modules/webconfig.py", line 23, in getVersion
f = open('VERSION.md', 'r')
squandor
Post by squandor »
Hmm strange what you could try is remove in the plugins folder afvalwijzer.py in template remove afvalwijzer and in docs remove the readmy from afvalwijzer and try to start domoboard again en try to install it again
jaccov
Post by jaccov »
Removed it all but the result is the same :cry:
squandor
Post by squandor »
Even if you didn't try to install afvalwijzer?
jaccov
Post by jaccov »
I removed it, didn't install it again.
Browser says the same IOError.
squandor
Post by squandor »
jaccov wrote:I removed it, didn't install it again.
hmm could you see if there is an VERSION.md in you domoboard folder?
jaccov
Post by jaccov »
Yes it is there.
jaccov
Post by jaccov »
Well it is very strange, I restart the raspberry a couple of times.
And now it is working....
but after reboot again, still IOerror :oops:
squandor
Post by squandor »
Hmm what you could try is remove the version.md and create it again with the values from the github
jaccov
Post by jaccov »
when I start it in home/pi/domoboard/ it is working perfect
when i start it in home/pi/ then I get the IOerror
squandor
Post by squandor »
Strange we will look into that but now it will start normally right?
jaccov
Post by jaccov »
Yes it is., thanks for the support :)
