Low cost window/door sensor
Keptenkurk
Re: Low cost window/door sensor
Post by Keptenkurk »
Nope, still on it's way (i hope)...
/paul
Derik
Post by Derik »
Raspberry Piet wrote:
sstolk wrote:@Raspberry Piet,
What is your jumper setting? And is it complete impossible to send on commands?
Jumper settings:
You can choose setting 1.5m 3.3m 4.7m
Choose 3.3m
Setting for different ID's A0-A7 i think.
My setting now is A1 High wich gives ID 075555
Have not checked all possibilities.
Without hardware tweaks i think it will not send on commands.
What are your settings now?
Please a printscreen..
Raspberry Piet
Post by Raspberry Piet »
bizziebis wrote:When you open a door, it sends a off command. What about when you close the door, does it send another off command?.
No only when you open the door it sends an off signal.
When you close the door it doesn't send a signal.
Raspberry Piet
Derik wrote:
Keptenkurk wrote:It could take some time before the door sensor arrives but then i will check with my SDR receiver and see the transmission time.
/paul
Paul..
Do you now more?
Well i did check it with my sdr dongle and sdrsharp.
Transmission time is short as we already knew.
Derik wrote:What are your settings now?
printscreen :?:
Raspberry Piet
Last edited by Raspberry Piet on Wednesday 07 May 2014 21:39, edited 1 time in total.
Derik
Post by Derik »
@ Piet
A printscreen of your jumpers...
sstolk
Post by sstolk »
The sensors are here and working but indeed no ON command...
What could be an possibility to tweak this device to send a on command?
I will try it to manage it but no clue where to start. I'm not afraid for some soldering but where...
sstolk
Post by sstolk »
@Derik,
The settings for the jumpers as topicstarter mentioned.
Keptenkurk
My two door sensors arrived yesterday and i did some tests.
The device will transmit the Off signal (only) for about 2 seconds which is equally long as the LED on the device lights.
Compared it to a AMST-606 which transmits twice as long. Not a real big deal for a door sensor but i surely wouldn't want that as PIR.
Recorded the experiment on youtube.
/paul
Raspberry Piet
http://www.domoticz.com/forum/viewtopic ... 179#p13603
Got the PIR today.
It does send ARC codes.
BigDog
Domoticz version: V3.9269
Post by BigDog »
if you want to let the door sensor switch someting wil it work or must it be made with a script becose the off command it gives..
and if it must be a script can someone help me a little bit :)
Greetz Bob
1X Raspberry4B : Domoticz Version 2023.1 [Linux 5.10.63-v7l+ armv7l]
1X Conbee II : 2.25.3 - 26720700
1X RFXtrx433 USB Firmware:183
1X Mysensors Gateway 1.5 -3
6X ESP8266: Tosmota firmware
Zigbee : 6 Operators, 13 Sensors
Ritmeester
Post by Ritmeester »
BigDog wrote:if you want to let the door sensor switch someting wil it work or must it be made with a script becose the off command it gives..
It is simple: :-)
BigDog
Post by BigDog »
ohhh but the door sensor is off when it is going to send a signal off it stil off
but if it is this simple :P oke nothing sayed :P :lol: :P :lol:
bizziebis
Domoticz version: 3.8805
Post by bizziebis »
If you do it like this it's actually switching a 'ON' switch to 'OFF' so it makes a little more sense:
The first time you activate the blocky event it will switch ON the light and change the switch status to ON. Every time you open the door it wil switch back the contact to OFF, the light will go ON for 1 minute and the contact is set back to ON.
drogert
Post by drogert »
Hi, I'm new here and I have read this thread.
I've ordered 4 of these door sensors to implement into my domotica system. I will let you know how this will work out for me. I've ordered them yesterday from ebay so they will take a while to get in Rotterdam. :lol:
RPI 3b+, PiFace 2, RFcom, Aeon Zwave USB, Aeon Home Energy Meter Gen 5, several Shelly switches, several ESP8266 sensors.
bizziebis
Post by bizziebis »
I recieved my 2 door sensors like the one the topic starter has. The big difference is that they report as lighting 4 and they send only a ON command.
Even better then I expected :D
Bought these: http://www.ebay.com/itm/181185686979
2 pieces for € 5,29
12 days delivery time
Dynamic
Post by Dynamic »
I received also the 2 sensors I've ordered 3 weeks ago. I'll try them this week! I hope my sensors will also report an 'on'-state.
Ritmeester
bizziebis wrote:I recieved my 2 door sensors like the one the topic starter has. The big difference is that they report as lighting 4 and they send only a ON command.
2 pieces for € 5,29
Hmmm, this is strange. I have the same sensors and they send the “Off” command. Maybe jumper settings?
BigDog
Post by BigDog »
Witch jumper have you set bizziebis can you make a picture?
bizziebis
Post by bizziebis »
Exactly like this:
sstolk wrote:@Derik,
