I have a question. It it possible to retrieve the device IDX that is responsible for the actual trigger? Like in this little script:
active = true,
devices = { 'SENSOR_*' } ( or perhaps in something like this: "devices = {74, 21, 71, 164}" )
execute = function(domoticz, sensoren)
if sensoren.state == 'Open' then
domoticz.devices('Magneetsensors').switchOn()
domoticz.log('<font color="red">Een deur- of raamsensor is geactiveerd.</font>', domoticz.LOG_INFO)
I would like to use the activated sensor in another script or put the value in a variable.
Thanks again for all the excellent work!
Regards, Rob
Question about the use of activated device
dannybloe
Re: Question about the use of activated device
The second parameter (device) is the device that has been changed:
print(device.id) -- this is the triggered/changed device.
Reason: I wasn't correct.
schulpr
Thanks! I didn't know it was that easy
dannybloe
That's why there is 'easy' hidden in 'dzVents'
