I had a 6th button already installed for a future RTS motor. That button had already been set with Somfy ID 3.
I now have the 6th RTS motor , so I programmed it with a new button with that same Somfy ID. That did the trick, and I got a message from Domoticz that that ID was already programmed, so I canceled.
The previous installed 6th Button works fine in Domoticz, Up, Down and Stop.
So in Domoticz with my RFXCOM everything works fine, all 6 RTS motors. Hand controllers work fine too.
Now I am facing a challenge.
I had some scripts running close the roller shutters at night and opening them at the morning, etc.
That script worked perfect. I changed the name of the 6th Button to something else and changed the script accordingly.
The script still works fine except for the 6th roller shutter. In all kinds of logging I see the the script executes fine.
Where normaly on all 5 buttons I see after the scripts executes, logging, something like: (RFXCOM) RFY (Achterdeur)
But with the 6th button, no response from Domoticz.
I looked at the API output from working buttons and the malfunctional, the is NO difference except, name time etc...
I looked in the Domoticz database and see NO difference between the 5 working and the malfunctional buttons.
Normal API command work fine too on all buttons, like in Domoticz self.
I am out of ideas
What is dzVents sending to Domoticz?
