How to read/write a list (array) into a variable?
I want to read, update and store some sensor values in my LUA script. By storing the whole list in one variable, adding a sensor is easy, without the need for extra variables. Just add another list item.
In dzVents with it's global variables this task would be easier. But until dzVents is supported in a stable Domoticz release, I have to use LUA.
- Westcott
Re: How to read/write a list (array) into a variable?
If it's a dict-type list, write/read it as JSON.
Otherwise perhaps as a Lua list string "{val1, val2, ...}"
thank you.
With JSON no experience, but with help from this page I've got it working. The joined string goes to the string variable.
Result:
2017-07-25 00:07:23.806 LUA: test: starttest
2017-07-25 00:07:23.806 LUA: test: the original elements:
2017-07-25 00:07:23.807 LUA: test: **********************
2017-07-25 00:07:23.807 LUA: test: 1:PIR_woonkamer/172800/1
2017-07-25 00:07:23.807 LUA: test: 4:PIR badkamer/172800/2
2017-07-25 00:07:23.808 LUA: test: the joined string:
2017-07-25 00:07:23.808 LUA: test: **********************
2017-07-25 00:07:23.809 LUA: test: PIR_woonkamer;172800;1;PIR badkamer;172800;2
2017-07-25 00:07:23.810 LUA: test: the join+split elements:
2017-07-25 00:07:23.810 LUA: test: **********************
2017-07-25 00:07:23.810 LUA: test: 1:PIR_woonkamer/172800/1
2017-07-25 00:07:23.810 LUA: test: 4:PIR badkamer/172800/2
function meld (melding,prio)
if (not prio) then print ('<font color="purple">test: E R R O R geen prio meegegeven') end
if debug==1 then print ('<font color="purple">test: '..melding) end
if prio~=99 then
commandArray[index]={['SendNotification']='test#'..melding..'#'..prio}
index = index + 1
function split(str, pat)
local t = {} -- NOTE: use {n = 0} in Lua-5.0
local fpat = "(.-)" .. pat
local last_end = 1
local s, e, cap = str:find(fpat, 1)
while s do
if s ~= 1 or cap ~= "" then
table.insert(t,cap)
last_end = e+1
s, e, cap = str:find(fpat, last_end)
if last_end <= #str then
cap = str:sub(last_end)
table.insert(t, cap)
return t
l = { -- timeout for each device, in seconde.
'PIR_woonkamer', 172800, 1, -- 2 dagen
'PIR badkamer',172800, 2 -- 2 dagen
debug=1
meld ('starttest',99)
i=1
meld ('the original elements:',99)
meld ('**********************',99)
while l[i] do
meld (i..':'..l[i]..'/'..l[i+1]..'/'..l[i+2],99)
i = i + 3
s=table.concat(l, ";")
meld ('the joined string:',99)
meld (s,99)
l=split (s,';')
i=1
meld ('the join+split elements:',99)
while l[i] do
i = i + 3
return commandArrayResult:
Aaarghhh:
Domoticz string variable maximum size is 200 bytes
Source: https://www.domoticz.com/wiki/User_variables
(For now) I don't want to check size and spread over multiple variables.
Can you tell me more about the JSON option?
mivo
if you are on stable Domoticz version, you can still use dzVents version 1.x, which also has persistent variables.
https://github.com/dannybloe/dzVents
I think it is easier way than create JSON, store to file etc.
My toys:
Raspberry Pi 3 + UPS PIco HV3.0 A Stack
Minibian (Raspbian Jessie) + Domoticz beta
RFLink 433 Gateway, 1wire DS18B20 temp sensors (GPIO)
RaZberry module + 2x Comet Z-Wave + Z-wave socket
Plugins: WeMo Switch, UPS PIco HV3.0A on GitHub
