logging problem
heistje
Domoticz version: 2023.2
logging problem
Post by heistje »
could use some help with enabling/finding the logfile.
Running Domoticz on a Qnap (Ubuntu 16.04)
Enabled the Domoticz.sh file (removing the # before DAEMON_ARGS="$DAEMON_ARGS -log /tmp/domoticz.txt")
restarted Domoticz
but no succes, can't find the domoticz.txt-file...
thx for any suggestion!
Bullseye on RPI 4
Aeotec Z-Wave Plus Z-Stick Gen5
Zwave-JS-UI
RFXtrx433E
Eth8020
P1 USB
Shellys
ESP8266
SweetPants
Re: logging problem
Post by SweetPants »
If you start Domoticz as a service this /home/pi/domoticz/domotcz.sh is not used. You should change /etc/init.d/domoticz.sh
heistje
Re: logging problem
Post by heistje »
Thx for your reply!
I'm browsing/searching with WinSCP and I can browse the whole Ubuntu system but
The problem is that I can't find an other domoticz.sh file.
Not even in /etc/init.d/domoticz.sh
The only domoticz.sh I've found is the one in /home/'my name'/domoticz/
Thx for your help!
Bullseye on RPI 4
Zwave-JS-UI
RFXtrx433E
Eth8020
P1 USB
Shellys
ESP8266
SweetPants
Re: logging problem
heistje wrote:I'm browsing/searching with WinSCP and I can browse the whole Ubuntu system but
Are you sure you can browse the whole system? /etc/init.d/domoticz.sh is owned by root, I don't think you can sudo in WinSCP!!!
Try logging in with ssh and your username and excute ls -lia /etc/init.d/domoticz.sh. I get this on my Ubuntu system:
<yourname>@nuc:/$ ls -lia /etc/init.d/domoticz.sh
525065 -rwxr-xr-x 1 root root 3986 Mar 6 16:01 /etc/init.d/domoticz.sh
heistje
Re: logging problem
Post by heistje »
Sorry for my late reaction (long holiday :D )
Thx for your reply!
Tried your suggestion (with Putty) and got this:
Bullseye on RPI 4
Zwave-JS-UI
RFXtrx433E
Eth8020
P1 USB
Shellys
ESP8266
heistje
Re: logging problem
Post by heistje »
took a little lesson on Putty and this are all files that I can find in the directory:
no trace of domoticz.sh ....
Bullseye on RPI 4
Zwave-JS-UI
RFXtrx433E
Eth8020
P1 USB
Shellys
ESP8266
