Heating control Script not switching
jkimmel
Domoticz version: 2021.1
Post by jkimmel »
Here comes my script which I thought is quite close to dannyblue's example.
-- assumptions:
local BOILER_DEVICE = 'FB 41 Heizkreis Gaestebad' -- switch device
local SETPOINT_DEVICE = 'Setpoint Gaestebad' -- selector dummy device
local TEMPERATURE_SENSOR = 'Gaestebad'
local HYSTERESIS = 0.5 -- temp has to drop this value below setpoint before boiler is on again
local SMOOTH_FACTOR = 3
local LOGGING = true
		['timer'] = {
			'every minute',
		devices = {
			TEMPERATURE_SENSOR,
			SETPOINT_DEVICE
	data = {
		temperatureReadings = { history = true, maxItems = SMOOTH_FACTOR }
	active = true,
	execute = function(domoticz, device, triggerInfo)
		local avgTemp
		local temperatureReadings = domoticz.data.temperatureReadings
		-- first check if the sensor got a new reading or the setpoint was changed:
		if (triggerInfo.type == domoticz.EVENT_TYPE_DEVICE) then
			local sensor = domoticz.devices(TEMPERATURE_SENSOR)
			local setpoint =  domoticz.devices(SETPOINT_DEVICE)
			if (sensor.changed) then
				-- sensor just reported a new reading
				-- add it to the readings table
				local tcurrent = sensor.temperature
                if LOGGING then domoticz.log('tcurrent = ' .. tcurrent) end
				if (tcurrent ~= 0 and tcurrent ~= nil) then
					temperatureReadings.add(tcurrent)
					-- no need to be here, weird state detected
					domoticz.log('Strange sensor reading.. skiping', domoticz.LOG_ERROR)
					return
			elseif (setpoint.changed) then
				-- a new setpoint was set
				local scurrent = setpoint.setPoint
				if LOGGING then domoticz.log('Setpoint was set to ' .. scurrent) end
				-- no business here, bail out...
				return
		-- now determine what to do
		local boiler = domoticz.devices(BOILER_DEVICE)
		if (scurrent == nil or scurrent == 0) then
			boiler.switchOff()
			return -- we're done here
		-- determine at which temperature the boiler should be
		-- switched on
		local switchOnTemp = scurrent - HYSTERESIS
		-- don't use the current reading but average it out over
		-- the past <SMOOTH_FACTOR> readings (data smoothing) to get rid of noise, wrong readings etc
		local avgTemp = temperatureReadings.avg(1, SMOOTH_FACTOR)
		if LOGGING then
			domoticz.log('Average: ' .. avgTemp, domoticz.LOG_INFO)
			domoticz.log('Setpoint: ' .. scurrent, domoticz.LOG_INFO)
			domoticz.log('Current boiler state: ' .. boiler.state, domoticz.LOG_INFO)
			domoticz.log('Switch-on temperature: ' .. switchOnTemp, domoticz.LOG_INFO)
		if (avgTemp >= scurrent and boiler.state == 'On') then
			if LOGGING then domoticz.log('Target temperature reached, boiler off') end
			boiler.switchOff()
		if (avgTemp < scurrent and boiler.state == 'Off') then
			if (avgTemp < switchOnTemp) then
				if LOGGING then domoticz.log('Heating is required, boiler switched on') end
				boiler.switchOn()
				if LOGGING then domoticz.log('Average temperature below setpoint but within hysteresis range, waiting for temperature to drop to ' .. switchOnTemp) end
Rfxcom
Raspi 4
dannybloe
Re: Heating control Script not switching
Post by dannybloe »
Yes, that's also fixed in the next pull request :)
Sorry again for that. This is the updated code:
-- assumptions:
-- the setpoint is set by a selector dummy device where the values are numeric temperatures
-- but you can easily change it to a setpoint device
local BOILER_DEVICE = 'Boiler' -- switch device
local SETPOINT_DEVICE = 'Setpoint' -- selector dummy device
local TEMPERATURE_SENSOR = 'Temperature'
		['timer'] = {
			'every minute',
		devices = {
			TEMPERATURE_SENSOR,
			SETPOINT_DEVICE
	data = {
	active = true,
		local avgTemp
		local current = sensor.temperature
				if (current ~= 0 and current ~= nil) then
					temperatureReadings.add(current)
					return
			elseif (domoticz.devices(SETPOINT_DEVICE).changed) then
				if LOGGING then domoticz.log('Setpoint was set to ' .. device.state) end
				return
		if (setpoint.state == nil or setpoint.state == 'Off') then
			boiler.switchOff()
		local setpointValue = tonumber(setpoint.state)
		-- switched on
		local switchOnTemp = setpointValue - HYSTERESIS
		local avgTemp = temperatureReadings.avg(1, SMOOTH_FACTOR, current) -- fallback to current when history is empty
		if LOGGING then
			domoticz.log('Setpoint: ' .. setpointValue, domoticz.LOG_INFO)
		if (avgTemp >= setpointValue and boiler.state == 'On') then
			boiler.switchOff()
		if (avgTemp < setpointValue and boiler.state == 'Off') then
				boiler.switchOn()
Try to find the differences ;)
jkimmel
Post by jkimmel »
Only difference I found is about averaging. So because I didn't understand the logic behind I deleted averaging.
I also changed from dummy selector to thermostat hoping this won't spoil anything.
Anyway there still is no switching, log entries don't show up as well as debugging (using MS Edge)
Seems to me I haven't seen the differences :?
local BOILER_DEVICE = 'FB 21 Heizkreis Salon' -- switch device
local SETPOINT_DEVICE = 'Setpoint Salon' -- Setpoint thermostat
local TEMPERATURE_SENSOR = 'Salon'
      ['timer'] = {
         'every minute',
      devices = {
         TEMPERATURE_SENSOR,
         SETPOINT_DEVICE
   active = true,
      local tcurrent --= sensor.temperature
      local setpoint --= domoticz.devices(SETPOINT_DEVICE)
			domoticz.log('Temp was set to ' .. tcurrent)
            return
      if (scurrent == nil ) then
         boiler.switchOff()
      -- switched on
      if LOGGING then
      if (tcurrent >= scurrent and boiler.state == 'On') then
         boiler.switchOff()
      if (tcurrent < scurrent and boiler.state == 'Off') then
         if (tcurrent < switchOnTemp) then
            boiler.switchOn()
            if LOGGING then domoticz.log(' temperature below setpoint but within hysteresis range, waiting for temperature to drop to ' .. switchOnTemp) end
Edit:
Is this
['timer'] = {
still allowed?
Obviously scurrent is nil although I used
Thermostat set point[edit]
setPoint: Number.
from the Wiki, because when I change
			boiler.switchOff()
to
if (scurrent == nil and boiler.state == 'On' ) then
			boiler.switchOff()
there is no permanent swichOff command anymore as I realized in the log of the switches
Rfxcom
Raspi 4
jkimmel
Post by jkimmel »
This one is switching now, tried to be closer to danyblue's example
local RUECKLAUF_SENSOR = 'WP Ruecklauf'
local HYSTERESIS = 0.005
		timer = {
			'every 1 minute',
		devices = {
			TEMPERATURE_SENSOR,
	data = {
	active = true,
	  local avgTemp
	  local ruecklauf = domoticz.devices(RUECKLAUF_SENSOR)
      -- experimenting with ruecklauf.temperature purpose avoiding wet walls
      local ruecklaufT = ruecklauf.temperature + 2
               return
			local dewpoint = sensor.dewPoint
		-- switched on
		local switchOnTemp = dewpoint + HYSTERESIS
		if LOGGING then
			domoticz.log('Dewpoint: ' ..dewpoint, domoticz.LOG_INFO)
		if ((avgTemp <= dewpoint or ruecklaufT <= dewpoint) and boiler.state == 'On') then
			boiler.switchOff()
            boiler.switchOn()
            	if LOGGING then domoticz.log('Temperature to high cooling, boiler on') end
Rfxcom
Raspi 4
HvdW
Domoticz version: 2023.2
Post by HvdW »
I tried the original script from Github.
It stumbles on line 30 of the script.
I did try the script @dannybloe posted 3 posts before (Friday 14 July 2017 8:02 )
Then I changed
		['timer'] = 'every minute',
		TEMPERATURE_SENSOR,
		SETPOINT_DEVICE
to
        devices = {TEMPERATURE_SENSOR, SETPOINT_DEVICE},
        timer = {'every 10 minutes'}
(don't even know if this change is necessary for dzVents 2.4)
It's running perfect now.
 2019-05-13 23:27:41.651 Status: EventSystem: reset all device statuses...
2019-05-13 23:27:41.748 Status: dzVents: Info: Handling events for: "Thermostaat-setpoint", value: "20.80"
2019-05-13 23:27:41.748 Status: dzVents: Info: ------ Start internal script: Verwarming: Device: "Thermostaat-setpoint (Dummy)", Index: 184
2019-05-13 23:27:41.750 Status: dzVents: Info: Setpoint was set to 20.80
2019-05-13 23:27:41.750 Status: dzVents: Info: Average: 20.89999961853
2019-05-13 23:27:41.750 Status: dzVents: Info: Setpoint: 20.8
2019-05-13 23:27:41.750 Status: dzVents: Info: Current boiler state: On
2019-05-13 23:27:41.750 Status: dzVents: Info: Switch-on temperature: 20.3
2019-05-13 23:27:41.750 Status: dzVents: Info: Target temperature reached, boiler off
2019-05-13 23:27:41.751 Status: dzVents: Info: ------ Finished Verwarming
2019-05-13 23:27:41.752 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
Thankyous and praises given hereby to @dannyblue
Bugs bug me.
HvdW
Post by HvdW »
Now that @dannybloe's thermostat is running fine I want to ask for some help.
I checked this project because I want to make our 20 year old Nefit Ecomline HR a 'smart' boiler.
A VPN connection from outside is established and then Domoticz is accessed.
Editing the Thermostat setpoint every time to switch on or off the boiler is a bit difficult.
How can the code be adapted or the Thermostat setpoint be changed that I can switch off the boiler easily.
A slider or some presets like 12, 14, 16, 18, 19, 20, 21, 22 would be perfect.
Bugs bug me.
rrozema
Post by rrozema »
You have probably figured it out by now, but for anyone still looking how to make the thermostat script 'look and feel' as good as it controls your boiler: Add a dummy thermostat setpoint to your domoticz devices and use this from the script. Here are the steps:
1 - Add the 'Dummy' hardware (if you haven't got it installed yet):
Add dummy hardware & start adding a dummy device.png (81.28 KiB) Viewed 578 times
  • Click Instellingen (Setup)
  • Click Hardware
  • If your hardware list already contains the Dummy hardware, go to (2). You only need it installed once.
  • In the bottom half of the screen, enter a name for your hardware. I suggest to use 'Dummy'.
  • Behind 'Type', select "Dummy (Does nothing, use for virtual switches only)".
  • Click the Toevoegen (Add) button.
2 - Add a thermostat setpoint device
Add dummy thermostat setpoint device.png (12.23 KiB) Viewed 578 times
  • On the hardware list, find the line for your Dummy hardware.
  • Click the button 'Maak virtuele sensoren' (Create virtual sensor). A dialog 'Create Virtual Sensor' opens.
  • In the "Naam:" (Name) field, enter a name for your setpoint device. Remember this name -exactly, including any capitals and spaces-. You'll need it in your script later on.
  • In the "Sensor Type" field, select "Thermostat Setpoint".
  • Click "OK"
3 - Use your new device in the script
Thermostat device name.png (3.48 KiB) Viewed 578 times
  • On the line that says "local SETPOINT_DEVICE = 'Setpoint'", change the text SetPoint into the name you entered for your virtual sensor.
  • Click the "Opslaan" (Save) button
4 - Change the temperature for your room/house
  • Click the "Overige" (Others) tab
  • Find your thermostat device (It's probably in the bottom if you haven't dragged it yet)
  • Click the flame icon
  • Enter the new value or use the up and down arrows to select one
  • Click "Instellen" (Set)
