Error log does not appear as error (dzVents 2.0)
dlefol
Post by dlefol »
I'm working on moving my scripts from dzVents 1 to 2 and while doing that I noticed that the following error message output by dsVent appears as a normal log (All tab) and not as an error log (Error tab):
"2017-07-10 21:36:00.204 Error: dzVents: Error: There is no device with that name or id: Mydevice"
The error message is not the problem (the script is a work in progress...) but I would have expected the message to appear in the error tab.
Thanks for all the good work on dzVents by the way :)
dannybloe
Re: Error log does not appear as error (dzVents 2.0)
Post by dannybloe »
Mmm. I think it's a disturbance in the Force. As you can see the log entry it is clearly marked as an error as the first 'Error:' marker is created by Domoticz and only when it is indeed flagged as an error entry. So the fact that it's not showing up in the error tab is perhaps something wrong in filtering in the browser at this point. No idea but not something I can fix.
