Python Plugin: Broadlink RM2 V3
NomenNescio
- Domoticz version: v4.9700
Re: Python Plugin: Broadlink RM2 V3
Using Rafal's method I manage to get the Broadlink RM2 with Kodi remote in Domoticz.
I can see the temp of the Broadlink RM2 but however I can switch the learning mode on nothing happens after putting the receiver on (with remote).
The according folder is created in Windows (C:\BroadlinkRM2 with the two subfolders, but it stays empty.
I'm on windows home server 2011.
Domoticz version: 3.8025
Build Hash: 37b51336
Compile Date: 2017-06-28 06:32:47
Broadlink is working fine with e-Control on android
Domoticz works fine with milights.
If install Python 3.4.0 install of Pycrypto fail withrafal wrote:Andree wrote:i'm becoming crazy.
Install same package and configuration of Rafal and now i have same problem of your previus post!
error: Unable to find vcvarsall.bat
Cleaning up...
Command C:\Python34\python.exe -c "import setuptools, tokenize;__file__='C:\\Users\\andre\\AppData\\Local\\Temp\\pip_build_andre\\pycrypto\\setup.py';exec(compile(getattr(tokenize, 'open', open)(__file__).read().replace('\r\n', '\n'), __file__, 'exec'))" install --record C:\Users\andre\AppData\Local\Temp\pip-swj86p1y-record\install-record.txt --single-version-externally-managed --compile failed with error code 1 in C:\Users\andre\AppData\Local\Temp\pip_build_andre\pycrypto
Storing debug log for failure in C:\Users\andre\pip\pip.log
Uninstall ALL version of python, then restart windows and with admin right install python 3.4.0 then with admin right pycrypto and setup. If dosen't work try do the same configuration on different windows or machine
- Phantom
- Domoticz version: 4.11652
i don't know why it keeps failing for me, i uninstalled all 3 plugins (crypto, broadlink and pyaes) and also deleted the directory's.
Then installed all 3 again:
i even re-installed python3.
pi@raspberrypi:~ $ sudo pip3 install Crypto
Collecting Crypto
Using cached crypto-1.4.1-py2.py3-none-any.whl
Requirement already satisfied: shellescape in /usr/local/lib/python3.5/dist-packages (from Crypto)
Requirement already satisfied: Naked in /usr/local/lib/python3.5/dist-packages (from Crypto)
Requirement already satisfied: pyyaml in /usr/local/lib/python3.5/dist-packages (from Naked->Crypto)
Requirement already satisfied: requests in /usr/local/lib/python3.5/dist-packages (from Naked->Crypto)
Requirement already satisfied: certifi>=2017.4.17 in /usr/local/lib/python3.5/dist-packages (from requests->Naked->Crypto)
Requirement already satisfied: chardet<3.1.0,>=3.0.2 in /usr/local/lib/python3.5/dist-packages (from requests->Naked->Crypto)
Requirement already satisfied: urllib3<1.22,>=1.21.1 in /usr/local/lib/python3.5/dist-packages (from requests->Naked->Crypto)
Requirement already satisfied: idna<2.6,>=2.5 in /usr/local/lib/python3.5/dist-packages (from requests->Naked->Crypto)
Installing collected packages: Crypto
Successfully installed Crypto-1.4.1
pi@raspberrypi:~ $ sudo pip3 install broadlink
Collecting broadlink
Collecting pyaes==1.6.0 (from broadlink)
Installing collected packages: pyaes, broadlink
Successfully installed broadlink-0.5 pyaes-1.6.0
pi@raspberrypi:~ $ sudo pip3 install pyaes
Requirement already satisfied: pyaes in /usr/local/lib/python3.5/dist-packages
pi@raspberrypi:~ $ sudo cp -r /usr/local/lib/python3.5/dist-packages/crypto/ /usr/lib/python3.5/
pi@raspberrypi:~ $ sudo cp -r /usr/local/lib/python3.5/dist-packages/broadlink /usr/lib/python3.5/
pi@raspberrypi:~ $ sudo service domoticz restart
pi@raspberrypi:~ $ sudo cp -r /usr/local/lib/python3.5/dist-packages/pyaes /usr/lib/python3.5/
pi@raspberrypi:~ $
pi@raspberrypi:~ $ sudo pip3 show broadlink
Version: 0.5
Summary: Python API for controlling Broadlink IR controllers
Home-page: http://github.com/mjg59/python-broadlink
Author: Matthew Garrett
Author-email: [email protected]
License: UNKNOWN
Requires: pyaes- Phantom
Strange thing is.
when i run the discover with the RM3 mini off i get no fault message:
2017-07-02 17:08:57.735 User: Admin initiated a switch command (126/RM3 mini - Discover/On)
2017-07-02 17:08:57.740 (RM3 mini) Calling message handler 'onCommand'.
2017-07-02 17:08:57.740 (RM3 mini) onCommand called for Unit 1: Parameter 'On', Level: 0 , Connected : False
2017-07-02 17:08:57.740 (RM3 mini) All plugin system is on pause for 5s...
2017-07-02 17:09:02.748 (RM3 mini) Found 0 broadlink devices
2017-07-02 17:09:02.748 (RM3 mini - Discover) Updating device from 0:'Off' to have values 1:'Found : 0 device'.
2017-07-02 17:09:03.096 (RM3 mini) Update 1:'Found : 0 device' (RM3 mini - Discover)
2017-07-02 17:09:07.253 (RM3 mini) Calling message handler 'onHeartbeat'.
2017-07-02 17:09:37.301 (RM3 mini) Calling message handler 'onHeartbeat'.
Only when the RM3 is on:
2017-07-02 17:08:39.123 User: Admin initiated a switch command (126/RM3 mini - Discover/On)
2017-07-02 17:08:39.146 (RM3 mini) Calling message handler 'onCommand'.
2017-07-02 17:08:39.146 (RM3 mini) onCommand called for Unit 1: Parameter 'On', Level: 0 , Connected : False
2017-07-02 17:08:39.147 (RM3 mini) All plugin system is on pause for 5s...
2017-07-02 17:08:44.154 (RM3 mini) Found 1 broadlink devices
2017-07-02 17:08:44.167 Error: (RM3 mini) 'onCommand' failed 'TypeError':'sequence item 0: expected str instance, bytes found'.
2017-07-02 17:08:44.167 Error: (RM3 mini) ----> Line 210 in /home/pi/domoticz/plugins/BroadlinkRM2/plugin.py, function onCommand
2017-07-02 17:08:44.167 Error: (RM3 mini) ----> Line 397 in /home/pi/domoticz/plugins/BroadlinkRM2/plugin.py, function Discover
2017-07-02 17:08:44.167 Error: (RM3 mini) ----> Line 203 in /usr/lib/python3.5/broadlink/__init__.py, function auth
2017-07-02 17:08:44.167 Error: (RM3 mini) ----> Line 258 in /usr/lib/python3.5/broadlink/__init__.py, function send_packet
2017-07-02 17:08:44.167 Error: (RM3 mini) ----> Line 162 in /usr/lib/python3.5/broadlink/__init__.py, function encrypt_pyaes
zak45
- Domoticz version: V2024.4
Try by removing pyaes. Looks like problem with it, just keep Crypto.Phantom wrote:Strange thing is.
zak45
@andree
try 3.5.3 x86 and pycrypto-2.6.1-cp35-none-win32.whl on dropbox.
had worked for me.
had worked for me.
zak45
post your log.NomenNescio wrote:Using Rafal's method I manage to get the Broadlink RM2 with Kodi remote in Domoticz.
- Phantom
i used pip3 to uninstall pyaes and also removed the directory, but then i get this message:zak45 wrote:Try by removing pyaes. Looks like problem with it, just keep Crypto.Phantom wrote:Strange thing is.
2017-07-02 18:32:23.729 User: Admin initiated a switch command (126/RM3 mini - Discover/On)
2017-07-02 18:32:30.718 Error: RM3 mini hardware (9) thread seems to have ended unexpectedly
What pyaes version are you using?
Same Zak...in domoticz log persistzak45 wrote:@andree
had worked for me.
2017-07-02 19:05:50.975 EventSystem - Python: Failed dynamic library load, install the latest libpython3.x library that is available for your platform.
ToneStrife
I couldn't see in the wiki. Is it possible to have several remotes? MAybe adding several hardwares with the same broadlink.
And the most important, I've tried everything I read in the wiki for the remote, I have added the ini and everything. And still in Off. I have a raspi and the broadlink is workin. Any hint?
zak45
yes, multiple hw should works.ToneStrife wrote:I couldn't see in the wiki. Is it possible to have several remotes? MAybe adding several hardwares with the same broadlink.
Have you clicked on the remote to put it 'On' ???
zak45
I do not have pyaes. these are my modules:Phantom wrote: i used pip3 to uninstall pyaes and also removed the directory, but then i get this message:
zak45
@Phantom
looks like this is related to your problem :
https://github.com/mjg59/python-broadlink/issues/107
- Phantom
Thanks i will go trough it tomorrow and try some things out.zak45 wrote:@Phantom
- Phantom
i was just to curious to see.
I have manged to get it to work, i really want thank you a lot for your assistance. This plugin is awesome.
So this is what i did.
when i installed broadlink again and also crypo and copied both to the /usr/lib/python3.5 i noticed that the one in the 3.5 has no capitol C for Crypto
i tried to rename it but that did not work.
Then i looked in the folder /usr/lib/python3/dist-packages/ and there is saw Crypto with a lot more files then in the 3.5 one.
So i copied that one "sudo cp -r /usr/lib/python3/dist-packages/Crypto/ /usr/lib/python3.5/" restarted Domoticz and everything works.
zak45
@Phantom
great.nice to see this work for you know.
ToneStrife
Off option is not possible. I have added a .ini file with the number (idx) of the remote control created by broadlink. Probably I made something worng, but I can't find what is it.zak45 wrote:yes, multiple hw should works.ToneStrife wrote:I couldn't see in the wiki. Is it possible to have several remotes? MAybe adding several hardwares with the same broadlink.
The ini file is plugin_remote_38.ini
( 38 Broadlink 000800FE 254 Broadlink - Remote)
The code inside is :
[Custom]
command = 37,36-
zak45
@ToneStrife
if I have understand well, you have give the wrong idx.
this should be the Hardware Id provided by Domoticz for the RM2 plugin e.g
Hi,i'm here!
Domoticz 3.8x - Python 3.4 setup.exe not work
Domoticz 3.8x- Python 3.5.3 setup.exe work but don't see HW in Domoticz and in Log "EventSystem - Python: Failed dynamic library load, install the latest libpython3.x library that is available for your platform."
Domoticz 3.8x - Python 3.6.1 setup.exe non work but in Domoticz "PluginSystem: Started, Python version '3.6.1'."
and now update..
Domoticz 3.8x - Python 3.5.3 and 3.6.1 installed (both with all user sure) - Setup Work , In Log " PluginSystem: Started, Python version '3.6.1'." and in HW i see HW Broadlink with Kodi Remote but if configure it no device appears and in LOG
and now update..
" 2017-07-07 10:06:57.550 Error: (BroadlinkRM2) failed to load 'plugin.py', Python Path used was 'C:\Program Files (x86)\Domoticz\plugins\BroadlinkRM2\;C:\Program Files (x86)\Python36-32\python36.zip;C:\Program Files (x86)\Python36-32\Lib\;C:\Program Files (x86)\Python36-32\DLLs\;C:\Program Files (x86)\Domoticz'.
2017-07-07 10:06:57.550 Error: (Broadlink Sala) Module Import failed, exception: 'ModuleNotFoundError'
2017-07-07 10:06:57.551 Error: (Broadlink Sala) Module Import failed: ' Name: broadlink' "-
zak45
@Andree
try:
open cmd as Administrator
execute : pip install broadlink
try:
