Amazon Echo to Domoticz Bridge: switches, sensors & more
Alexa, Google Home and Siri
Madgeni
Re: Amazon Echo to Domoticz Bridge: switches, sensors & more
Post by Madgeni »
WAN port on https.
heggink
Domoticz version: 12451
Post by heggink »
Unfortunately I am too dependent on alexa to test and fail (and suffer the wrath of 3 women in the house). I shall have to buy another echo dot for test purposes the week after next when I will be in Washington. I can run these side by side and give them different activation words. Given how dependent we are getting to be, maybe rename from alexa to domonatrix haha .
P1 meter & solar panel
Madgeni
Post by Madgeni »
Well, if it's working, don't change it :)
Feedback so far is it works identically (backend is same), but without hassle of setup
heggink
Post by heggink »
Great to hear. In terms of new sw versions, how does that work?
Madgeni
Post by Madgeni »
there's the rub - if the complete solution goes live, which requires no effort from users, i'd look to stop developing both, and focus on the new one
Freemann
Domoticz version: >=Béta
Post by Freemann »
OK, looks like the Lambda testing of "TurnOffRequest" and "TurnOnRequest" actions are working, but the Discovery isn't working...
Skill discovery finds my Hue lights, but not the Domoticz devices. Also running the Lamba test for discovery still returns the 1sec timeout.
Anybody an idea?
This is the logoutput of the Lambda test discovery;
START RequestId: 7e2a4560-5d91-11e7-8f71-11428d14354e Version: $LATEST
2017-06-30T12:41:52.741Z	7e2a4560-5d91-11e7-8f71-11428d14354e	http://???:????@???.???:???:???:XXX/json.htm?type=devices&filter=all&used=true&order=Name
END RequestId: 7e2a4560-5d91-11e7-8f71-11428d14354e
REPORT RequestId: 7e2a4560-5d91-11e7-8f71-11428d14354e	Duration: 1002.10 ms	Billed Duration: 1000 ms 	Memory Size: 128 MB	Max Memory Used: 38 MB
2017-06-30T12:41:53.675Z 7e2a4560-5d91-11e7-8f71-11428d14354e Task timed out after 1.00 seconds
Going to:
"http://???:????@???.???:???:???:XXX/json.htm?type=devices&filter=all&used=true&order=Name" (offcourse with the appropriate IP/Port number)
Then I see the big JSON (maybe to big JSON ? )
Domotica/graphs "freak" :)
NUC8i3BEH(8gb/250gb),
Lubuntu 19.04,
Aeotec Z-Stick S2(Gen5)
HarmonyElite
HUE(5 bulbs, 2 blooms)
NetAtmo(complete setup)
MiLight iboxV6(2 MiLightBulbs)
IP-Cam
https://www.frijduurzaam.nl
Madgeni
Post by Madgeni »
hi - without wanting to get too stuck into this, can you first try running domoticz against https ?
If the url is correct (and it looks it), it's possible (probable) the error is around the connection, rather than the JSON payload being too big. If that was the case, which is hugely unlikely, the connection time would be bigger.
also generally i'd recommend any comms should run over https
Madgeni
Post by Madgeni »
Also, and this is totally my fault - you need to have the devices you want to be discovered in Room Plans in Domoticz first
I've just updated the manual, and put this in bold in big font at the beginning.
Freemann
Post by Freemann »
Great update!
Question;
Whats the best practice for Lambda region, Dot language and Dot address?
I live in The Netherlands and my preferred Alexa language is English(UK).
Based on my Location I would say the Lambda should be hosted in Ireland.
But does it madder to which address I register the Dot to and on which language I set the Dot?
If so, whats for my situation the best combination of settings and is it possible to make a matrix for other users to ?
Lubuntu 19.04,
HarmonyElite
IP-Cam
Madgeni
Post by Madgeni »
lambda and language of skill need to be the 'same' - so it's easy:
host in Virginia - use English (US) in the skill;
host in Ireland - use English(UK) in the skill;
can't say about language of the Dot, my continental friends can probably help :)
Freemann
Post by Freemann »
OK thanks again!
For me only the combination "Virginia <> English US" is working.
Tried the "Ireland <> English (UK)", but that's just not working (for me) and as soon as I switch to Virginia; It works.....
Lubuntu 19.04,
HarmonyElite
IP-Cam
borcon
Post by borcon »
@madgeni,
your current version on github does not find any scenes or groups from domoticz.
Madgeni
Post by Madgeni »
Hey @borcon - There was an issue previously, where it was including any scenes/groups not just those in Room Plans, this line:
if (device.planID === '0' || device.planID === ' ') { continue }
*Should * fix that, ignoring devices/scenes & groups NOT in a plan. Can someone else corroborate that this is not working?
borcon
Post by borcon »
Hey madgeni,
now it's working. I had only devices in room plans.
I thought the room plan restriction is only for devices. :-)
Madgeni
Post by Madgeni »
it wasn't supposed to be, but i just missed the scene logic out ages ago!
borcon
Post by borcon »
@madgeni,
if I ask Alexa "what is the temperature" in my room, then she speaks the temperature as a date.
I think the point in the temperature (26.5) from domoticz is the issue.
Can you help me to add a line in the alexa code to replace the dot with a comma? 26.5 --> 26,5
I hope this solves the issue.
Madgeni
Post by Madgeni »
Hi there - is this the continental use of the comma for decimals? The issue is more with this being for the US/UK with Alexa, which use the full stop.
I'll do some tests
Madgeni
Post by Madgeni »
Looking at the doc, it expects a floating point -
"temperatureReading.value Floating point number that indicates the temperature in degrees."
borcon
Post by borcon »
@madgeni
yes, this is the continental use of the comma for decimals
Madgeni
Post by Madgeni »
think we might need to await the release into DE :(
