Python plugin: Sony Bravia TV
markcame
Re: Python plugin: Sony Bravia TV
Post by markcame »
Try to :
disable the plugin
delete the cache folder inside your sony plugin folder
restart the system
than re-enable the plugin.
I have the same issue... hope this can be fixed
G3rard
Domoticz version: No
Post by G3rard »
Which other Python plugins are you using? Then I can install these as well on my system to see what is causing the error.
The Sony plugin is running for more than a day now without any issues on my system.
Not using Domoticz anymore
vgr2
Post by vgr2 »
markcame wrote:Try to :
disable the plugin
restart the system
How can I do this???
markcame
Post by markcame »
disable the plugin
restart the system
i have the same issues after this for now the system is again up.
after disabling the plugin from hardware panel in domoticz, delete the folder __pycache__ inside your sony plugin installation folder
the i rebooted and i have re enabled the plugin....
for now the system say up
markcame
Post by markcame »
Nothing to do after 49 minutes domoticz stop working
vgr2
Post by vgr2 »
Sorry I could not support you. I'm not an expert but would be nice if the plugin rans without errors
markcame
Post by markcame »
I've tryed everithing but domoticz after a while crash no error was reported on the log ! there's a way to debug ?
i've no others plugins running in domoticz
markcame
Post by markcame »
here the log of domoticz
2017-07-01 16:21:04.909  Error: Domoticz received fatal signal 11 !...
2017-07-01 16:21:04.912  Error:   /home/pi/domoticz/domoticz() [0x1ccd8c]
2017-07-01 16:21:04.912  Error:   /home/pi/domoticz/domoticz(_Z14signal_handleri+0x58) [0x1cce44]
2017-07-01 16:21:04.912  Error:   /lib/arm-linux-gnueabihf/libc.so.6(__default_sa_restorer_v2+0) [0x76ac8180]
febalci
Post by febalci »
@G3rard, thank you very much for the plugin. Beginner for Domoticz here. Using your plugin with Android Bravia KD55XD8505. Everything works except for the "Switch on" command. I was an openhab user and was using a Simple IP binding for my Bravia and it was working well. Are there any plans for a Simple IP plugin or should i use an LUA script for my condition or is your plugin Simple IP already?
Thanks again ...
G3rard
Post by G3rard »
markcame wrote:here the log of domoticz
That is a generic error which is seen at other Python plugins as well, see the following posts.
https://www.domoticz.com/forum/viewtopi ... 05#p139741
https://www.domoticz.com/forum/viewtopi ... 13#p139528
I cannot fix this in the code of the plugin. I think this has to be fixed in the Python framework.
Also seems this only occurs on a Pi, as I don't have this error on my Ubuntu 14.04 server which is running the Sony Bravia and Sonos plugins for 5 days now.
Maybe @Dnpwwo can have a look at this?
G3rard
Post by G3rard »
febalci wrote:@G3rard, thank you very much for the plugin. Beginner for Domoticz here. Using your plugin with Android Bravia KD55XD8505. Everything works except for the "Switch on" command. I was an openhab user and was using a Simple IP binding for my Bravia and it was working well. Are there any plans for a Simple IP plugin or should i use an LUA script for my condition or is your plugin Simple IP already?
Thanks again ...
Your welcome :D
Can you try the latest version 1.0 of the plugin and use "Android" as your MAC address?
Maybe the switch on then works. See also this post. I updated the code according to that post.
I have no plans to use the Simple IP control since it is a lot of work to migrate to that and it has no extra features that I would like to use.
febalci
Post by febalci »
Wow, i was using version 1.0 already and i might swear i tried "Android" as MAc yesterday and it didn't worked. But today magically it worked... I guess there might be some problem with the switch in the Dashboard, it barely works (i simply have no idea how) since in Switches page it always works.
Thanks again
markcame
Post by markcame »
I think you are right, the issue is in the framework, i hope this can be fixed, for now i have disabled the plugin for now, if i can help i'm available.
lmet
Domoticz version: v4.9700
Post by lmet »
Sorry for this beginner question but it would be very nice if someone could help me.
I'm trying to use this plugin for my Sony Bravia TV
Python seems to be Ok
2017-08-05 18:25:02.759 PluginSystem: Started, Python version '3.4.2'.
On "Setup" "Hardware" I see a Sony Bravia TV (with Kodi remote)
But nothing about changing parameters like IP address PSK ...
So i choose to clic "add" and in the list button setup does nothing.
In the log in can find :
2017-08-05 18:32:59.264 Error: () failed to load 'plugin.py', Python Path used was ':/usr/lib/python3.4/:/usr/lib/python3.4/plat-arm-linux-gnueabihf:/usr/lib/python3.4/lib-dynload'.
2017-08-05 18:32:59.264 Error: (Sony) Module Import failed, exception: 'ImportError'
2017-08-05 18:32:59.264 Error: (Sony) Module Import failed: ' Name: plugin'
2017-08-05 18:34:00.734 Error: Sony hardware (25) thread seems to have ended unexpectedly
If i try localtest.py I get
No reaction of TV, assumed is off
TV status : off
I've done all the setup on my TV a KDL-50W755c
Thanks in advance
simon_rb
Post by simon_rb »
lmet wrote:Hi,
TV status : off
Thanks in advance
I have just updated and have the exact same error. Any idea's anyone?
Cheers :D
G3rard
Post by G3rard »
@lmet, @simon_rb,
Please download plugin.py and bravia.py from https://github.com/gerard33/sony-bravia ... evelopment to see if that works for you.
That version works here without the error message on startup.
Edit: @simon_rb confirmed that version works, so I have pushed those changes to the master brance. The latest version of the plugin is now version 1.2.
lmet
Post by lmet »
@G3rard same issue,
Changing type of device to Sony Bravia TV (with Kodi remote) then Update always return to Awox SmartPlug
Thanks for your help
G3rard
Post by G3rard »
@lmet, that looks like a browser cache issue. Can you clear browser cache and appcache?
Or open Domoticz in incognito tab to see if it solves this issue.
lmet
Post by lmet »
@G3rard you were right Thanks a lot
The only thing that does'nt works is power on tv with the plugin. May be here :
The address is entered in the file
G3rard
Post by G3rard »
Do you have an Android tv?
Then enter 'Android' (without the quotes) in the PSK field in Domoticz hardware.
