NodeMCU and ESPEasy
krizzz
NodeMCU and ESPEasy
I just flashed my NodeMCU with the ESPeasy firmware, which was exactly like the name states. It's easy!
I also managed to connect a pulsecounter and add it as a device within my ESPeasy. I also the that it COUNTS pulses. Fakes one, because the pulses were triggered by the flash of my mobile phone. But anyway, so far so good. The only problem I am having is that my virtual device within Domoticz is not updating. So something is not communicating. Let's start with the beginning. Do I even have the correct virtual device? I have chosen for "Counter" virtual device and I know see this device mentioned as a "RFXmeter counter". Is this correct?
Is it mandatory to fill in within the ESPeasy software the "user" id for my domoticz? I am just testing the setup within my testing setup. For this pi running domoticz i do not even have a user setup within domoticz. So i was curious if I could have the field just not filled in.
Somebody with some other tips?
- Westcott
Re: NodeMCU and ESPEasy
User ID?
If you mean "Controller User:" then no, you don't need it.
I'm sure you've set the device IDX to match Domoticz.
Does the ESPeasy log show anything?
randytsuch
Maybe start with something really easy, like a switch.
First make a virtual switch in domoticz and get the index number for your virtual switch.
Setup a GPIO as a switch in ESP Easy, change states and see if it works.
If you look at the ESP Easy log, you will see it change states there.
Then go over the domo, and see if it changes there.
So far, I've implemented switches, relays and temp sensors, nothing too complicated, but works great.
Randy
Randy
krizzz
Thanks for the pointers.Westcott wrote:User ID?
So now I deleted in the lines "Controller User" any info. It now looks like this.
@randytsuch
It does log within ESPeasy, I does just not post to domoticz.
The values were inputted today.
Then no action on the device. And I just do not understand why.
mvzut
NodeMCU and ESPEasy
Maybe a stupid question, but did you enable "Send Data" in the device configuration screen? Here's an example of my pulse counter device:
krizzz
Too bad, wanted to connect to my NodeMCU and it wasn't onlin anymore. Pressed the rst button on the device. Never came back to life. Decided to flash again. No problems there during the flash process. But, when done. I press rst and the device never comes back online to the ESP_0 open wifi network.
But this is so weird to me, the flash goes perfect but the restart and the wifi just arent there. Maybe a faulty unit? I do not have a 2nd one to test unfortunately.
- Westcott
It should remember the last IP address it was set to.
Perhaps try to find it with an IP scanner?
- heggink
- Domoticz version: 12451
Had a similar issue with a bad power supply.
DASHTICZ 🙃
P1 meter & solar panel
DASHTICZ 🙃
randytsuch
I was having problems with an ESP-01, and tried to reload it with ESP Easy.
I did get it working, but after reloading, it never did the ESP_0 thing, it remembered the setup information, and rejoined my wifi network.
So it seems reloading ESP Easy doesn't erase the setup information.
And in the end it was a wiring mistake I made, didn't pull up all the pins I needed to.
At bootup, GPIO 0 and 2 have to be high, and GPIO15 has to be low. If not, it won't boot up, well it boots up in the wrong state, so it looks like it hasn't booted up.
I've also had problems with GPIO16 (had to disconnect to boot up) and I've not been able to figure out why.
Randy
Randy
freijn
- Domoticz version: Stable
Are you sure your domoticz server is in 192.168.0.1 ?
"Normally" (good practise ) you use this address as the default Gateway.
But i read you have other issues now..
Using 4 espEasy in my house. 4 temp sensors 1 IR sensor
Very happy with the performace of these !
Cheers,
Frank
Cheers,
Frank
krizzz
I deleted the latest number of the ip-adress so it must looks a little bit strange in the picture.freijn wrote:Are you sure your domoticz server is in 192.168.0.1 ?
Cheers,
Frank
I threw away the nodemcu I had. After trying various USB cables and also power adapters nothing worked. I am sure this was just a faulty one. I ordered New ones drom Aliexpress and I will report back in probably 2-3 weeks
.Verzonden vanaf mijn iPhone met Tapatalk
krizzz
Update:
I received my new NodeMCU's and flashed ESPEasy without any problems. Attached the sensor and got it working because I can see values coming in.
Double checked the info for the Domoticz installation. So IP adress is correct and the device IDX also. Still nothing is coming into Domoticz. I even checked the "send data" toggle if it is on. it is!
So, if anyone else has any ideas. Let me know. I am currently thinking that the "dummy device" created is not the correct one. It keeps mentioning at the "Type: RFXMETER, RFXMETER counter". Maybe wrong?
freijn
Please make screenshots of all your config. (easyesp as well as Domoticz )
What sensor is attached ? Where do you see values ?
Anything in the logfiles of the Domoticz ?
mayyam
- Domoticz version: 4.11333
Controller user and password?
_______________
- Dell FX-160 / Ubuntu 16.04
- RFLink 433Mhz / NRF 2.4GHz
- 2x Xiaomi Gateway
- different species of ESP8266
- 2x Xiaomi Gateway
krizzz
Ok, Here it is. So it is a Wemos D1 v3 flashed with ESP Easy. Attached is a light sensitive sensor for arduino/wemo purposes bought through Aliespress, like this one.freijn wrote:Please make screenshots of all your config. (easyesp as well as Domoticz )
As you can see in the 2nd picture, the sensor has produced variables. But it will just don't update the device within domoticz.
freijn
Can't see any mis-configurations here.
I am switching to basic now... and sorry if you did it already....
I can see you can connect to the Domoticz as well as to the Esp but.....
- Are you sure the ESPEasy can reach the Domoticz server?
- Can you please share the ip address of the ESPEasy ?
- Can you ping the ESP from the Domoticz ?
Is there nothing in the logfiles of domoticz ????
Please see the logs of the ESP anything in there???
krizzz
Thanks for the help! It is driving me crazyfreijn wrote:Can't see any mis-configurations here.
Here is the results of the ESP logfile
Log
165490693 : WD : Uptime 2758 ConnectFailures 0 FreeMem 28400
165520694 : WD : Uptime 2758 ConnectFailures 0 FreeMem 28400
165550695 : WD : Uptime 2759 ConnectFailures 0 FreeMem 28400
165580696 : WD : Uptime 2759 ConnectFailures 0 FreeMem 28400
165610697 : WD : Uptime 2760 ConnectFailures 0 FreeMem 28400
165640698 : WD : Uptime 2760 ConnectFailures 0 FreeMem 28008
165670699 : WD : Uptime 2761 ConnectFailures 0 FreeMem 28008
165700700 : WD : Uptime 2761 ConnectFailures 0 FreeMem 27456
165730701 : WD : Uptime 2762 ConnectFailures 0 FreeMem 27456
165760702 : WD : Uptime 2762 ConnectFailures 0 FreeMem 27824-
freijn
The only diff I see with my config is the unti number.
Please make the unit number 1
this is my logfile :
608437841 : DHT : Temperature: 22.30
608437841 : DHT : Humidity: 63.40
608440369 : WD : Uptime 10129 ConnectFailures 0 FreeMem 28344
608444644 : DS : Temperature: 47.31 (28-80-af-26-0-0-80-5d)
608451651 : DS : Temperature: 42.44 (28-2e-11-27-0-0-80-70)
608470370 : WD : Uptime 10129 ConnectFailures 0 FreeMem 28344
608497901 : DHT : Temperature: 22.30
608497901 : DHT : Humidity: 63.40
608500371 : WD : Uptime 10130 ConnectFailures 0 FreeMem 28344
608504704 : DS : Temperature: 48.31 (28-80-af-26-0-0-80-5d)
Can you make an event ( counter) and see if you can see it in the logfile ?
Please be aware the logfile does refresh every 2 sec or so. So you have to monitor it all time ....
krizzz
I was very frustrated with this issue the last couple of weeks and the fact that I couldnt find out what was causing the problem. I left it powerless this last period.
Therefore i started up the Wemos today and thought I would just try everything, but I found the problem within minutes. Appearently in the device tab of ESPeasy i can select the counter type. And all this time it was selected on Delta/Total/Time. After selecting the other possibility here --> Delta the device in my Domoticz setup was beding updated ! So Eureka, finally some succes. Now to find out how to setup correctly
Verstuurd vanaf mijn SM-T580 met Tapatalk
mjdb
- Domoticz version: all beta
When you have flashed the ESP8266, connect it to a external power-suply (not a computer) for the next steps.
I found that this makes the process with the setup work.
2 x Domoticz on Raspberry Pi; 2 x RFXtrx433; Aeotec Z-Stick
KlikAanKlikUit ICS-2000 as Relay
Aeotec MultiSensors 6; Danfoss Z Thermostats 014G0013; Kaku Switches, Z-wave Switches
