Domoticz App
Re: Domoticz App
Hi Galadril,you have PM!
bdormael
Re: Domoticz App
PM coming your way
- galadril
- Domoticz version: latest
Re: Domoticz App
Thanks all!
I've enough testers for this first version now
Domoticz Android app:
https://play.google.com/store/apps/deta ... s.domoticz
- galadril
Re: Domoticz App
screenshot spam >
https://user-images.githubusercontent.c ... 18b754.png
https://user-images.githubusercontent.c ... 2c5390.png
https://user-images.githubusercontent.c ... 355435.png
https://user-images.githubusercontent.c ... 27bd3e.png
marcotrumpet
Re: Domoticz App
I sent you a PM if you want I can test it too
Inviato dal mio iPhone utilizzando Tapatalk
- galadril
Re: Domoticz App
So the app came available in testflight last night..
What are your first thoughts
- galadril
Re: Domoticz App
Added a section 'TestFlight Feedback' on the first post
marcotrumpet
Re: Domoticz App
Graphics is much nicer than android app (that I use on my android phone).. No real problem form now.. I'll try alarm panel in the morning. Watch at the image here. When I switch a light the bottom banner seem to not fit the entire bar and there are big 3 lines menu at the top right in temperature stats. Awesome work man!!! Thank you so much!!!galadril wrote:So the app came available in testflight last night..
What are your first thoughts:)
- galadril
Re: Domoticz App
Great!marcotrumpet wrote: Graphics is much nicer than android app (that I use on my android phone).. No real problem form now.. I'll try alarm panel in the morning.
Thats an menu item that's weird scaled.. its added to my fix list thanksmarcotrumpet wrote: and there are big 3 lines menu at the top right in temperature stats. wesome work man!!!
Thanks ill look into that.. also there should be a small ad's bar at the bottom of the screen.....marcotrumpet wrote:When I switch a light the bottom banner seem to not fit the entire bar
marcotrumpet
Re: Domoticz App
I hope there will be a paied release in the future without adsgaladril wrote:Great!marcotrumpet wrote: Graphics is much nicer than android app (that I use on my android phone).. No real problem form now.. I'll try alarm panel in the morning.
Now I only see a soft grey barInviato dal mio iPhone utilizzando Tapatalk
- G3rard
- Target OS: -
- Domoticz version: No
Domoticz App
Nice job! The app is really looking good.galadril wrote:So the app came available in testflight last night..
Some first points, tested on iPhone 7 with iOS 10.3.1:
* When connecting to the server, I got a message that connection is ok, but could not proceed, see screenshot. After restarting the app I could proceed
* I think it's good to show some bullets on the intro pages, so you know that there are more pages and you can swipe to them
* The last seen time is now shown as 21 hours, 24 minutes. I would change that to hh:mm:ss, that makes more sense. Also currently when something is last seen at for example 00:01:10, then the hours aren't shown.
* Also show the date on last seen when it's another date then today, otherwise it's not clear what the actual last seen moment is.
* The switches tab is empty. Could be a connection issue as I have a VPN connection to the server, and I sometimes had an error message in the app when loading other tabs.
Will do some more testing in the coming days.
Keep up the good work!
Not using Domoticz anymore
- galadril
Re: Domoticz App
yes.. there will be a premium in-app payment, to remove ads and unlock specific featuresmarcotrumpet wrote: I hope there will be a paied release in the future without adsNow I only see a soft grey bar
- galadril
Re: Domoticz App
G3rard wrote: Nice job! The app is really looking good.
All valid points.. I'll happely collect all feedback.G3rard wrote: Some first points, tested on iPhone 7 with iOS 10.3.1
I'm going on a (well earned) holiday of 3 weeks this weekend..
marcotrumpet
Re: Domoticz App
Import/export settings seems doesn't work
- galadril
Re: Domoticz App
Thanks, added to the list (was working on emulator, so maybe some rights issue..)marcotrumpet wrote:Import/export settings seems doesn't work
marcotrumpet
Re: Domoticz App
Yeah.. Can I write here or do I need to use feedback on testflight app?galadril wrote:Thanks, added to the list (was working on emulator, so maybe some rights issue..)marcotrumpet wrote:Import/export settings seems doesn't work
- galadril
Re: Domoticz App
You can write here
marcotrumpet
Re: Domoticz App
Alarm panel work perfectly.
The time under evry switch doesn't refresh if I use one of them
- galadril
Re: Domoticz App
I think i did that to minimise all the data calls...marcotrumpet wrote:The time under evry switch doesn't refresh if I use one of them
marcotrumpet
Re: Domoticz App
Okgaladril wrote:I think i did that to minimise all the data calls...marcotrumpet wrote:The time under evry switch doesn't refresh if I use one of them
I think the gcm notification doesn't work (I use it in alarm panel when triggered)
P.s. sorry for my bad english I hope you can use your imagination to understand what I mean
