Which can cause issues (collisions) with other devices sending at the same time.scottydj2 wrote:Commands seem to be sent 3 times each.
Low cost window/door sensor
SweetPants
Re: Low cost window/door sensor
sammyke007
- Domoticz version: 2022.1
Anyone with a link to working on AND off sensors with RFLink please?
SweetPants
AMST606 (KaKu) sends both on/and off and work with RFLink. But they also send long signals which may interfere with other signals
holdestmade
I have purchased the sensors below and can't get them to work with RFXCOM I've tried Lighting4 and ARC. It does say on the listing that the oscillator resistor can be 330K, any ideas where to put it ? Is it the empty space where it says R5 or maybe the 4 headers GTRV ? The chip markings is STC15W101.
Thanks in advance
free web hosting images
https://www.aliexpress.com/item/5pcs-43 ... 342db4972e
Thanks in advance
ArieKanarie
Did you try to disable all other protocols on your rfxcom when pairing these devices?
WIth mine it worked that way, apparently there were protocols interfering or somethiing.
AFter pairing you can enale the other protocols again.
holdestmade
Thanks ArieKanarie, that got them recognised but it detected 6 devices - 2 for each of the tamper, closed and open.
But it only works intermittently and not consistently between the 2 pairs. I tried it in RFXmngr (see below for example only tamper output) and same occurs, it is recognised but only 1 in approx 20 actions and varies between the 2 outputs.
Did notice the pulse is 458usec is this correct ? thought it needed to be 350. Do I need to change this with a resistor and where do I add it ?
Cheers
Packettype = Lighting4
subtype = PT2262
Sequence nbr = 23
Code = BCF907 decimal:12384519
S1- S24 = 1011 1100 1111 1001 0000 0111
Pulse = 449 usec
Signal level = 7 -64dBm
subtype = PT2262
Sequence nbr = 24
Code = 3CF907 decimal:3995911
S1- S24 = 0011 1100 1111 1001 0000 0111
Pulse = 449 usec
Cheers
subtype = PT2262
Sequence nbr = 23
Pulse = 449 usec
subtype = PT2262
Sequence nbr = 24
Pulse = 449 usec
holdestmade
Interestingly, if I enable X10 at same time as Lighting4 I get this output, again, intermittently:
ON DOOR CLOSE:
Packettype = Security1
subtype = X10 security
Sequence nbr = 36
id1-3 = BCF900 decimal:12384512
status = Motion
battery level = Low
ON DOOR OPEN:
Sequence nbr = 37
status = Alarm
battery level = Low
ON TAMPER:
Sequence nbr = 43
status = Alarm
battery level = OK
ON DOOR CLOSE:
Sequence nbr = 36
status = Motion
battery level = Low
ON DOOR OPEN:
Sequence nbr = 37
status = Alarm
battery level = Low
ON TAMPER:
Sequence nbr = 43
status = Alarm
battery level = OK
holdestmade
Spotted another setting "undec on". If I have this and ARC on, it responds to every event but varies between 3-7 codes:
ON DOOR CLOSE:
Packettype = UNDECODED RF Message
UNDECODED ARC:2779F21C072B
UNDECODED ARC:2779F21C0722
UNDECODED ARC:2779F21C06FD
ON DOOR OPEN:
UNDECODED ARC:2779F214072B
UNDECODED ARC:2779F2140734
UNDECODED ARC:2779F21C0734
ON TAMPER:
UNDECODED ARC:2779F20E0707
UNDECODED ARC:2779F20E072C
UNDECODED ARC:2779F20E0735
UNDECODED ARC:2779F20E0710
UNDECODED ARC:2779F20E073E
UNDECODED ARC:28BCF9070735
UNDECODED ARC:2779F20E06FD
ON DOOR CLOSE:
ON DOOR OPEN:
ON TAMPER:
ArieKanarie
I finally received mine, they work perfect, at least 3 of them, the other 2 won't be recognised.
Strangely I had that same problem with my previous sensors, which after sending them to rfxcom and back worked without any changes. So going to try them later again.
Since when are those sensors/switches automaticly added as security device, no matter wat device I suggest when pairing?
Now I cannot change the picture anymore, and for my old sensors (only on signal) I miss the on and off delay?
- svenalkalaj
I bought a DS-4 V1.0 low cost door sensor from Aliexpress, and now get it working as it should in Domoticz (openmediavault plugin) + RFLINK (R45 firmware).
I posted a video on how to proceed:
https://www.youtube.com/watch?v=Oq-hN-RJ2sA
if that helps.
if that helps.
“Sans progrès, il n’y a pas de paix possible. Sans paix, il n’y a pas de progrès possible.” Kofi Annan
Derik
- Domoticz version: BETA
did buy yourself a Xiaomi smarthome sensor..
Works great and is very smal/nice....
No mods needed, just install en working for months on a battery...
http://www.dx.com/nl/p/original-xiaomi- ... Ud3LWiLSUk
You need a bridge..
You need a bridge..
- svenalkalaj
Could you be more specific :
- what frequency is this device using (433Mhz?)?
- what type of device is OK with xiaomi ? RFXCOM or RFLINK?
What do you mean by you need a bridge ?
Thanks.
Thanks.
Derik
mmm
Sorry is gateway ..
iso bridge
https://nl.aliexpress.com/wholesale?cat ... +home+door
Search the forum for xiaomi
Sorry is gateway ..
- svenalkalaj
OK, looks good, but for people who already have a low cost rflink (homemade with prototyping pcb and chinese arduino reflashed), the gateway price could be a killer.
~30€ only for a gateway to control xiaomi devices, when with a cheap rflink you can interact with much more devices brands...
However, designwise xiaomi is much more interesting.
- Eddiever
I am wondering if there is any way around this.ArieKanarie wrote:.....
ArieKanarie
Yes. Disabling de X10 protocol beore pairing.Eddiever wrote:I am wondering if there is any way around this.ArieKanarie wrote:.....
If lucky (like in my case) the sensors will be paired with another protocol.
tonbor
Nice if you had said that the unused sensor1 may not be revoked, spend an hour to find outsvenalkalaj wrote:Hi,
if that helps.
chbla
Hi there,
I'm also looking for a cheap and compact door sensor that I can use with the RFXTRX433 - as there a lot of uncertainties and unsupported devices in the discussion; can anyone suggest one from Aliexpress that supports Open/Close signals?
Thanks a lot for your help
b_weijenberg
- Target OS: -
The Kerui D026 is supported, enable Lighting4 + X10 and the sensor is received as X10 security sensor.
https://www.aliexpress.com/item/6pcs-lo ... 26744.html
RFX-433, RFX-433EMC, RFX-868
chbla
Does it support Open AND Close? The Kerui seem to be rather expensive
Otherwise I found which were posted in the video above, they work too I assume.
https://de.aliexpress.com/item/5pcs-433 ... Title=true
These would be cheaper, first two use a coin cell:
https://de.aliexpress.com/item/3pcs-hot ... autifyAB=0
(Edit: sends only Open, according to the seller)
https://de.aliexpress.com/item/5pcs-Mar ... autifyAB=0
But no word about open/close support..
